Vg Dialer Can't Do It?
Hi!
>>You need VG Dialer to use "Dial and Conference".
if i'm use Call Transfer module with "Dial and Conference" option, isn't consider
use VG Dialer already?, Need to special enable the VG Dialer at Telephone Number Loader page? If yes, then how to link up it to call flow?
>>Call tracking is done by looking at $RV_CALLLENGTH after the calls have hung
So, how to get the $RV_CALLLENGTH in the callflow 5 as below?
Please explain it in details.
Are you able to do the simple call flow to approve that
your Voice Guide VG Dialer can do the transfer call and record the timing?
EG. Simply Call Flow :
1. Start at "Welcome to Voice Guide VG Dialer Transfer Call or Dialout & Conference Call Test Module",
Press 1 to Transfer Call to External line
Press 2 to Dialout & Conference Call to External line
Press 3 to End the call
2. For Press 1, use VG Dialer Transfer Call to call any External line was speciafied.
3. For Press 2, use VG Dialer Dialout & Conference Call to call any External line was speciafied.
5. If calling(from 1 or 2) to External line was fail or busy,
goto voice mail/ sound out "Line fail/Call busy"
4. If calling(from 1 or 2) to External line was success connected, goto record the start call time.
5. After the talk in 4, When any one side end the call, goto record the end call time and calculate the
call length and store in file/database/events log/sound the call length. Then end call.
Regards,
Alex Aw
-------Message-------
The "Dial and Conference" option in the Call Transfer module places a call
on second line and connects two lines together.
up.
Regards,
Adam
----- Message -----
> Hi!
> I\'m just go throught the details of the your VG Dialer feature.
> I\'m not think your VG Dialer can do the transfer call was describe in
> call_flow_chart.doc was attached last time.
> Please read carefully the call flow in call_flow_chart.doc
> Your VG Dialer basically feature are: Outbound calls can be scheduled
using:
> - Telephone Number Loader program,
> - Send Phone Message module in a VoiceGuide script
> - Creating a list of numbers to be called and saving this list in a \'Out
> Dial file\',
> - Adding dial entries directly to the OutDialQue.mdb database.
> Where to get the \"Call Technicians\" page in the \"Send Phone Message\"
> section in the help file?
> How to apply the Dialer_OutDialQueAdd command was describe in the help.
> EG. If i has ten external line for each department and was stored at the
> Telephone Numbers Loader v5.0.2000 at OutDialQue.mdb database or Phone
> number list file.
> So, how to make the transfer call to the external line was describe in
> call_flow_chart.doc?
> Unless, i\'m need to write the special program to call the Telephone
> Numbers Loader automatically for dialout/transfer to other telephone line
> when the my client(caller) was call in and selected the services was need
> to transfer the call to external line of one of my external department.
> Then, how track the call timing?
> Please explain it in details. Please reply ASAP.
> Thanks, AlexAw
> ----- Message -----
> Hi!
> We are looking at your VG product and wonder what kind of support you
> would provide should we purchase it? Some queries about your
> services/product.
> Questions:
> 1. are you system do the call flow was attached (call_flow_chart.doc)?
> KT: Had a look at it and yes, it can all be implemented
> 2. Can Calculate call timing, record timing, caller phone no and receiver
> phone no to database (eg.mysql)?
> Start time(when the success connect to Services A); End time(when the
> connect end between Services A and Caller)
> KT: Yes, all of these.
> 3. Can forward the call to external line? Need purchase VG Dialer add-on
> option to do it? Isn\'t requested PABX system? Isn\'t request 2 line to
> one customer to make the forward the call to external line? KT: Yes. If no
> PBX \"call transfer\" feature. then you will need VG Dialer. 4. Any
> technical support in Singapore? For the analog dialogic card, how to make
> sure, it workable in Singapore telephone line (SingTel tele com
> provider-www.singtel.com). Eg, Intel dialogic card, if it certified can
> use in Singapore, isn\'t not problem to using it? KT: You can purchase
> Dialoigc in singapore and then just use it.... Dialoigc/Intel in
> Sigapore\'s phone number is 62131000 We just work with one IVR
> vendor(oversea vendor, local re-saler), their system able to handler the
> call flow(call_flow_chart.doc) completely. KT: Which vendor? But, it was
> fail cause by the Intel dialogic card was order not sure can use in
> Singapore or not, but it\'s work fine in US. The local re-saler don\'t
> want to take the risk to test dialogic card in Singapore. 5. Normally, how
> much is cost for one dialogic card with 4 port? Eg. Intel dialogic card?
> KT: About US$600 for D4PCI 6. Based on the call flow was attached. Isn\'t
> we need to buy : a. Enterprise version(1 line-$248, 4 line 449) plus b. VG
> Dialer add-on option(1 line-$129, 4 line 449) C. Analog dialogic card
> (Intel dialogic card - $$??) Isn\'t 1 line enough to do all the job for
> one customer call? KT: One line should be enough if you only handle one
> call at a time. but in no PBX then you will need 2 lines - 2nd line for
> outgoing call. That\'s all. Thanks. Pls reply me asap.
Regards, Alex Aw
if i'm use Call Transfer module with "Dial and Conference" option, isn't consider use VG Dialer already?
Yes, it is. I'm just saying you will need to VG Dialer license on the system.
You should use the $RV_CALLLENGTH in the "On Hangup" script - see the "Call Finish" section of VoiceGuide Help file.
Ok. Thank a lot...
For the intel D/41JCT-LS analog card for Dial and Conference.
isn't use the same driver of the intel D4PCI?
I'm only have 1 CD of the driver was give by the card Vendor.
Not ahs user manual to install the driver, isn't is the same
procedure as intel D4PCI?
Yes, it's the same procedure. You will need to make sure that you are using SR5.1.1 - if you have a different version of the Dialogic's System Release drivers then you should download SR5.1.1 from:
http://resource.intel.com/telecom/support/...ntary/index.htm
D/41JCT-LS analog card was install succesfully.
But, still can't use Call Transfer module with "Dial and Conference" option.
Can't transfer call out.
Logs and the program as attached. Please help to find the problems.
Logs find in included all the option in Call Tranfer.
i was change the parameter in VG.INI
[PBX]
TransferControl_TelBoards=TAPI
Thkx.
test_voice_guide.zip
use telephone number loader to dial : use the script(in your sample script) in sequence as below:
1.C:\Program Files\VoiceGuide\Scripts\more sample scripts\MakeCallAndPassParams\MakeCall.vgs
2.C:\Program Files\VoiceGuide\Scripts\more sample scripts\MakeCallAndPassParams\MakeCallOriginator.vgs
3.C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayGetAmount.wav
C:\Program Files\VoiceGuide\Scripts\test_voice_guide\call_list.txt
it was success call up my handphone, but my handphone can't
do the intergrate with the telephone number loader?
Log file attached.. Pls take a look...
log_error_telephone_number_loader.log
Hi!
This is the log for the D4PCI card with transfer call module with
PBX blink option, seek like not error, but not call transfer out.
Isn't because the setting in the PBX command Strings?
What is the min and max value of the hookflash parameters?
If i'm try one by one, are you think i can match one at the end?
012106.89 9 ring 2
012106.89 9 Answer the call at 10/17/2003 1:21:06 AM
012106.89 9 lineAnswer(66509) => 66526
012107.44 9 callstate CONNECTED 66509,1,0
012107.44 9 WorkingModeTAPI@Connected=
012107.44 9 WorkingModeScript@Connected=
012107.47 9 Inband detection not enabled
012107.48 9 StartLoadedVgs at 10/17/2003 1:21:07 AM
012107.48 9 tapi Reply (LineEvReply) ok 66526 0
012107.48 9 [welcome] Playing
012107.48 9 [welcome] Playing (C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayYouArePaying.wav)
012107.53 9 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayYouArePaying.wav]
012107.53 9 RunModule PLAY end
012109.42 9 wb(30517100)
012110.44 9 Play End line[9] (id=305171)
012110.44 9 LsPlayMsg EV_PLAY_FINISHED
012114.36 9 dtmf 1 (66509,49,2)
012114.36 9 LsPlayMsgFinished 1
012114.70 9 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
012114.70 9 [Transfer Call 4] Blind Transfer to 6596527369 (Generate)
012114.70 9 tapic lineGenerateDigits(66509,5,0) => 0
012114.86 9 generate LINEGENERATETERM_DONE
012115.92 9 LsXferStart EV_TAPI_GENERATE
012117.02 9 LsXferPlayVts EV_HOOKFLASHFINISHED
012117.02 9 tapic lineGenerateDigits(66509,6596527369,0) => 0
012118.53 9 generate LINEGENERATETERM_DONE
012119.55 9 LsXferPlayVts EV_TAPI_GENERATE
012120.64 9 LsXferPlayVts EV_TIMEOUT_HANGUP
012120.64 9 Hanging up call...
012120.64 9 RecSoundStop ok
012120.64 9 PlaySoundStop ok
012120.64 9 fnHangupCall end
012120.67 9 linedevstate 2048 0 0
012120.67 9 callstate IDLE 66509 0 0
012120.67 9 WorkingMode@Idle=
012120.72 9 tapi Reply (LineEvReply) ok 66322 0
012121.73 9 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
012121.73 9 ReinitTelephony due to IDLE start
012121.73 9 tapic lineDeallocateCall(MainCall:66509) 0
012121.88 9 lineOpen(9) => 0
012121.88 9 Waiting for a call...
012121.88 9 lineOpen(9)LineHandle=66287
If the hookflash transfer does not work then either the hookflash length is wrong, or the phone line attached does not support hookflash transfers.
Form our previous discussions I think you should be concentrating on getting the "Dial and Conference" working with the D41JCT-LS card - it's a lot easier to set up....
Ok. Thank!
So, can you answer the
question(previous 2 question) was posted
Oct 17 2003, 12:22 AM
and
Oct 17 2003, 12:38 AM
The log file and program script was attached.
Thanks...
[PBX]
AND
Thnks.
We can see in the trace that there is an error when doing the Dial and Conference with the version of VoiceGuide installed.
Please uninstall the current version you have installed, then see the below link:
http://voiceguide.com/forums/index.php?showtopic=701
and download from there the newly released v5.1 Beta3 on the update.
Install v5.1 Beta 3, and then unzip the update and copy the files in the update into the VoiceGuide's directly, overwriting existing files.
Please then try the "Dial and Conference" again.
Alex Aw wrote:
I'm was unsintall and reinstall the new version + new patch files twice times.
But, still can dial and conference the call out. The log track was list as below.
Same error.....
193513.84 8 ERROR 5.1.2304 Error_ScriptEventCode: 0:9: Subscript out of range code:9012
alex
193503.53 8 linedevstate 2048 0 0
193503.53 8 callstate OFFERING 65962 0 4
193503.55 8 callinfo CALLEDID
193503.55 8 callinfo ORIGIN
193503.55 8 ring 0
193509.55 8 ring 2
193509.55 8 Answer the call at 10/18/2003 7:35:09 PM
193509.55 8 lineAnswer(65962) => 65945
193510.08 8 callstate CONNECTED 65962,1,0
193510.08 8 WorkingModeTAPI@Connected=
193510.08 8 WorkingModeScript@Connected=
193510.09 8 Inband detection not enabled
193510.09 8 StartLoadedVgs at 10/18/2003 7:35:10 PM
193510.09 8 tapi Reply (LineEvReply) ok 65945 0
193510.09 8 [welcome] Playing
193510.09 8 [welcome] Playing (C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayPress1ifOK.wav)
193510.20 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayPress1ifOK.wav]
193510.20 8 RunModule PLAY end
193513.33 8 dtmf 1 (65962,49,2)
193513.33 8 LsPlayMsg 1
193513.38 8 PlaySoundStop ok
193513.83 8 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
193513.83 8 [Transfer Call] Dial and Conference to 96527369 (TAPI)
193513.84 8 Hanging up call... [Error_ScriptEventCode]
193513.84 8 RecSoundStop ok
193513.84 8 PlaySoundStop ok
193513.84 8 fnHangupCall end
193513.89 8 linedevstate 2048 0 0
193513.89 8 callstate IDLE 65962 0 0
193513.89 8 WorkingMode@Idle=
193513.91 8 tapi Reply (LineEvReply) ok 65928 0
193514.95 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
193514.95 8 ReinitTelephony due to IDLE start
193514.95 8 tapic lineDeallocateCall(MainCall:65962) 0
193515.00 8 lineOpen(8) => 0
193515.00 8 Waiting for a call...
193515.00 8 lineOpen(8)LineHandle=65911
193518.89 0 sys cleanup Start
193518.89 0 sys cleanup End
This error can be caused if no free line for making the 2nd call can be found.
Please update the 5.1Beta3 install with the attached .EXE and run the script again. This new .EXE has more logging around the critical areas of the "Dial and Conference" section which will allow to better see what is going on. Please post the trace from this new .EXE
VgMulti.zip
Hi!
075156.83 6 [Transfer Call] Dial and Conference to 96527369 (TAPI)
075156.83 0 Search for free lines in range [6-6]
075156.83 6 Could not find free line to place outgoing call.
You are right. The error cause by no free line for making the 2nd call.
But, it was have 2 line there, but seek like can't detect it properly.
The Card have 4 port, first 2 port have 2 line, first line(67361358), second line
(67383065). This 2 port was testing can receive the call.
On Call Transfer module Setting, at "Dial & Conference" tab,
at "Wihich lines to use make the outbound call. I'm try both,
1. special the 2nd line 67383065 for outbound call.
2. the it blank to use any line which available.
But, both failed to call out and message could not find free line to place outgoing call????
How to fix this?? Please guide me....
Thanks.
log track :
075143.06 6 linedevstate 2048 0 0
075143.06 6 callstate OFFERING 65538 0 4
075143.06 6 callinfo CALLEDID
075143.06 6 callinfo ORIGIN
075143.06 6 ring 0
075149.06 6 ring 2
075149.06 6 Answer the call at 10/19/2003 7:51:49 AM
075149.06 6 lineAnswer(65538) => 65982
075149.61 6 callstate CONNECTED 65538,1,0
075149.61 6 WorkingModeTAPI@Connected=
075149.61 6 WorkingModeScript@Connected=
075149.63 6 Inband detection not enabled
075149.63 6 StartLoadedVgs at 10/19/2003 7:51:49 AM
075149.63 6 tapi Reply (LineEvReply) ok 65982 0
075149.63 6 [welcome] Playing
075149.63 6 [welcome] Playing (C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayYouArePaying.wav)
075149.63 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayYouArePaying.wav]
075149.63 6 RunModule PLAY end
075151.44 6 wb(89829600)
075152.45 6 Play End line[6] (id=898296)
075152.45 6 LsPlayMsg EV_PLAY_FINISHED
075156.42 6 dtmf 1 (65538,49,2)
075156.42 6 LsPlayMsgFinished 1
075156.83 6 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
075156.83 6 [welcome] Playing
075156.83 6 [welcome] Playing (C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayYouArePaying.wav)
075156.83 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayYouArePaying.wav]
075156.83 6 RunModule PLAY end
075158.67 6 wb(90550000)
075159.69 6 Play End line[6] (id=905500)
075159.69 6 LsPlayMsg EV_PLAY_FINISHED
075205.05 6 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
075205.05 6 [welcome] Playing (C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayYouArePaying.wav)
075205.05 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayYouArePaying.wav]
075206.84 6 wb(91371800)
075207.86 6 Play End line[6] (id=913718)
075207.86 6 LsPlayMsg EV_PLAY_FINISHED
075208.19 6 dtmf 1 (65538,49,2)
075208.19 6 LsPlayMsgFinished 1
075208.63 6 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
075208.63 6 [Transfer Call] Dial and Conference to 96527369 (TAPI)
075208.63 0 Search for free lines in range [6-6]
075208.63 6 Could not find free line to place outgoing call.
075208.63 6 [welcome] Playing
075208.63 6 [welcome] Playing (C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayYouArePaying.wav)
075208.63 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayYouArePaying.wav]
075208.63 6 RunModule PLAY end
075210.44 6 wb(91729600)
075211.45 6 Play End line[6] (id=917296)
075211.45 6 LsPlayMsg EV_PLAY_FINISHED
075217.09 6 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
075217.09 6 [welcome] Playing (C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayYouArePaying.wav)
075217.09 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayYouArePaying.wav]
075217.50 6 Hanging up call... [Loop Current Drop detected]
075217.50 6 RecSoundStop ok
075218.52 6 PlaySoundStop ok
075218.52 6 fnHangupCall end
075218.53 6 callstate DISCONNECTED 65538,0,0
075218.53 6 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
075218.53 6 Hanging up call...
075218.53 6 RecSoundStop ok
075218.53 6 PlaySoundStop ok
075218.53 6 fnHangupCall end
075218.53 6 tapi Reply (LineEvReply) err 66000 LINEERR_OPERATIONFAILED [80000048]
075218.56 6 linedevstate 2048 0 0
075218.56 6 callstate IDLE 65538 0 0
075218.56 6 WorkingMode@Idle=
075218.58 6 tapi Reply (LineEvReply) ok 66068 0
075219.63 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
075219.63 6 ReinitTelephony due to IDLE start
075219.63 6 tapic lineDeallocateCall(MainCall:65538) 0
075219.67 6 lineOpen(6) => 0
075219.67 6 Waiting for a call...
075219.67 6 lineOpen(6)LineHandle=66085
075226.03 0 sys cleanup Start
075226.03 0 sys cleanup End
If there are two lines available can you try calling in on the 2nd line and see if the same problem occurs?
The debug was not actually showing the correct line range - the attached vgmulti.exe shows correct range.
Please leave both text boxes on the "Dial and Conference" tab blank for now.
VgMulti.zip
Thanks. I've leave the office. May be back after 10 hours later, then test again using your new files.
>>If there are two lines available can you try calling in on the 2nd line and see if >>the same problem occurs?
Already try it. Ya, same error. But in difference range, if not forgot is [7-7]..
075156.83 0 Search for free lines in range [7-7]
Are both lines controlled by VoiceGuide at the same time, or are you configuring VoiceGuide to only control one line at a time?
What happens when you allow VoiceGuide to control all 4 lines?
Plase set in VG.INI :
[TraceLog]
LogToFile=1
TraceLevel=10
and then restart VG, do the test and post the trace file created in VoiceGuide's log subdirectory. This fuller trace will cover logging at startup so that we can better see this systems configuration.
>>Are both lines controlled by VoiceGuide at the same time, or are you configuring >>VoiceGuide to only control one line at a time?
Don't know. Sure be VoiceGuide controls 1 line or 2 line as the same time? How to configuring this? Thanks....
Please use the "VoiceGuide Configuration Wizard" and select all 4 lines on the Dialogic cards, assigning to them the script that they should execute.
When VG is started all 4 lines should be listed... Please send screenshot of what is show when you are running VoiceGuide (when there is a call on the system).
Also please post log that we mentioned in our previous post.
