Visual Basic Script Result Variables
Hi:
Is the only way to access results of VB script is by using VGRUNRESULT_LineNumber.TXT or SHLRESLT.TXT file?
If my VB module is called 'vbchange' can I play the variable $RV[vbchange] in the next module?
Thanks a lot!
If you want to return some information from your VB Script to be used by VoiceGuide later in the callflow you must save this data in a 'Result File'.
Once the VB Script finishes running all the variables in it are destroyed and VoiceGuide cannot see them... that's why you must save results in a file and then VoiceGuide reads them in after VBScript completes.
We will soon make available a set of functions you can use in the VB Script to simplify this process but in the meantime you must use the 'Results File'.
I have saved the data in a File but now I want to read the first Line.
1.- How can I read of the file row by row?
2.-what variables must I use?
3.-does exist any function that convert of number to string?
regards
josé
Have you tried using Text-to-speech ?
You can specify a text file to be spoken (using TTS) in the "Sound file" text field.
