Incoming Calls Randomly Hanging Up
We have client who uses VG 6.0.3386 and they are receiving complaints from customers of incoming calls randomly hanging up.
Here is the log from one that I was able to capture and I was hoping you can tell me why it is happening
091806.59 2 state [say Acc Description] Playing (C:\Program Files\VoiceGuide\temp\tts_2_8.wav)
091806.59 2 timer clear bForceClear=False
091806.61 2 play start ok, lPlayId=773149
091809.11 2 tw DialogicEvent 134,TDX_CST,192,0,0,DE_TONEON,DISCONNECT_TAPI1,
091809.11 2 event DISCONNECT_TAPI1, iCode=134 state=1100
091809.11 2 LsPlayMsg EV_UNKNOWN_134,DISCONNECT_TAPI1
091809.11 2 path {DISCONNECT_TAPI1} not found
091809.11 2 HangupCall start (Default Handler 20: DISCONNECT_TAPI1)
091809.11 2 rv add [Hangup Time]{5/04/2011 9:18:09 AM}
091809.11 2 state Hanging up call... [Default Handler 20: DISCONNECT_TAPI1]
091809.11 2 HangupCall_Common hCall=2
091809.13 2 play PlayStop ok
091809.13 2 timer set 1 EV_TIMEOUT_DOLINEDROP
091809.13 2 fnHangupCall end
091809.13 2 event TDX_CST, iCode=134 state=900
091809.13 2 LsAwaitingCalls EV_UNKNOWN_134
091809.13 2 tw PlayEnd 2 773149
091809.13 2 play end id=773149, (current ID)
091809.13 2 event EV_PLAY_FINISHED, iCode=8001 state=900
091809.13 2 LsAwaitingCalls EV_PLAY_FINISHED
091809.13 2 tw DialogicEvent 129,TDX_PLAY,773149,0,0,,,
091809.13 2 event TDX_PLAY, iCode=129 state=900
091809.13 2 LsAwaitingCalls EV_UNKNOWN_129
Trace shows that the Dialogic card reported hearing the tone DISCONNECT_TAPI1 about 3 seconds after the sound file tts_2_8.wav started playing.
When VoiceGuide is advised that a Disconnect type tone has been heard on the line it will assume the call was ended and it will then hang up the call as well.
Tone definitions can be changed in the ConfigLine.xml file. On analog lines the Disconnect tone should be closely matched to the actula disconnect tone(s) played by your telco. Please read: http://www.voiceguide.com/vghelp/source/html/disconnectiondetect.htm
You can also delete the DISCONNECT_TAPI1 entry altogether if you's like.
