Simple Ms Access Database Query
I have a very simple application that queries a MS Access DB and speak the results. I would like to use a voice modem as a single line is all I require.
According to the info I will need a Professional License. What is the minimum amount of line-licenses that I need to purchase? Ideally I could use v5 but this does not support DB access
For non-personal versions the minimum order is 4 lines (as stated on order form).
v5 is old software designed for older versions of Windows. It uses OLE DB to access databases, an you need to ensure that Microsoft Data Access Components (MDAC) is installed on the system.
We recommend all new installations use VoiceGuide v7.
