Unexpected Error V5 Windows 7
Hallo Voice Guide Team,
I try to install the VoiceGuide V5 Enterprise + Dialer software on a WINDOWS 7 Pro 32 Bit system. When I start the VgMulti.exe then I get the errormessage: “unexpected error; quitting”
Attached the errormessage.
Have you any idea what I can do???
Best regards
Frank
error.rtf
v5 is not supported on Win7/Win2008. The UnimodemV that is required to use voice modems has been discontinued in those versions.
Are you trying to use a Voice Modem or some other TAPI/Wave device?
I try to use a comISDN Tapidriver and a primux ISDN card S0.
The Board manufacturer is GERDES AG.
Best regards
Frank
Could you please post a copy of VoiceGuide's Debug Trace which captures the startup, this will allow us to see what happened.
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=10
SapiWrapOcx=0
If no traces are created then use depends.exe (http://www.dependencywalker.com/) to check if all requiried DLLs are present on your system.
Hello voiceguide team,
i have deactivated the uac (user access control) of WINDOWS 7.
It seems to work.
I will test it now.
Best regards
Frank
