Guest TheyCalled Paul Report post Posted 05/26/2011 05:20 PM We have been running 2 T-1's into our VG6. I moved the 2nd T-1 into a another card and this voiceguide still things it has 48 lines. We have a screen running and it has problems calling out ConfigLine.zip Share this post Link to post
SupportTeam Report post Posted 05/26/2011 08:25 PM Please see attached file. We removed the <Channel> entries for channels 24-46 (ie. the ports on the second span). If you still have issues dialing out then check whether the T1 is plugged into the 1st port, or whether you have it plugged into the 2nd port. Config.zip Share this post Link to post
