Guest David Sergeant Report post Posted 10/22/2003 03:17 PM Following on my questions about fax integration... I need information to guide my purchasing. The client definately wants to receive faxes. So I will go with two phone lines. One for the voice menu stuff (voiceguide) and one just for faxes. Do I get two modems? Or can I get a Dialogic D4/PCIUF and route one line to VoiceGuide and a second line to a fax program? Is it splittable? Likewise, if I have a D4/PCIUF can I just buy a 1 line VoiceGuide? I guess I'm just curious if the dialogic card shows up as 4 modems in the computer (win2k) so I can select the different lines with different applications. Thanks! Dave Share this post Link to post
SupportTeam Report post Posted 10/23/2003 01:14 AM Best way is to just assign a different number to be a fax number and receive faxes on a separate line - whether it be a modem controlled by fax software, or a standalone fax machine - and it sounds like that is now the intended setup. Best to use a modem - you will be hard pressed to find inexpensive fax software which will work with D/4PCIUF. Likewise, if I have a D4/PCIUF can I just buy a 1 line VoiceGuide? Yes, and just use one of the D/4PCIUF's lines. I guess I'm just curious if the dialogic card shows up as 4 modems in the computer (win2k) so I can select the different lines with different applications. It doesn't show up as a modem - it's a telephony card and is not controlled like a modem (no AT commands etc...) Share this post Link to post
