Guest TheyCalled Paul Report post Posted 06/02/2011 12:17 AM HI, I have seen this before but attached is my log, the last call did this. a) A call comes in we place an outbound call c) we record the call 1800 second timeout Share this post Link to post
SupportTeam Report post Posted 06/02/2011 10:31 AM Please update system to latest version of VoiceGuide v7 and post traces if this problem occurs with the latest version. 164001.026 18 2 1 ev CallState GCEV_DISCONNECTED, crn=28400be, iEvent=2 ,16384,0,64,,,]. vgEngine v7.1.3777.39220 (2010-05-05 20:47:20.42) 164001.026 18 2 1 qScr add evCallState 2 GCEV_DISCONNECTED 164001.026 6 2 1 qScr run evCallState sCode=[GCEV_DISCONNECTED] iActionID=0, crn=28400be[16384|0|64|0|0][|||||] 164001.026 6 2 1 LineEvCallState eLineStateThisEvent=Disconnected 164001.026 6 2 1 LineEvCallState ScriptState=LS_XFER_9_WAITENDCALL_DialingSide 164001.026 6 2 1 ls set Disconnected (scriptstate=LS_XFER_9_WAITENDCALL_DialingSide) 164001.026 6 2 1 yLineStateAppPov: Disconnected crn=28400be,ev=2,GCEV_DISCONNECTED,0, sParam1= 164001.026 6 67 23 qScr add evScriptEvent 0 OTHER_LEG_Disconnected 164001.026 6 2 1 LineEvCallState LINECALLSTATE_DISCONNECTED begin 164001.026 6 2 1 in LINECALLSTATE_DISCONNECTED iState=LS_XFER_9_WAITENDCALL_DialingSide 164001.026 6 2 1 qScr add evScriptEvent 9250 DISCONNECTED 164001.026 6 2 1 HangupCall, source=LINECALLSTATE_DISCONNECTED, WorkModeScript=Running_Normal, yLineStateAppPov=[Disconnected], lPlayId=0, lRecId=0 164001.026 6 2 1 moduleTitle=[Hangup] 164001.026 6 2 1 ScriptWorkingMode set Stopping, (called from HangupCall) 164001.026 6 2 1 state Hanging up... [LINECALLSTATE_DISCONNECTED] 164001.026 6 2 1 rv add [Hangup Source]{LINECALLSTATE_DISCONNECTED} 164001.026 6 2 1 GoOnHoook_IssueDropCall start (hCall_crn=28400be) 164001.026 6 2 1 t timer set 10 sec : EV_TIMEOUT_WAITFORIDLEAFTERDropCall 164001.026 6 2 1 timer set completed lTimeLeft250msUnits=40, iTimeoutCode=9101 164001.026 6 2 1 qTel add cmd_DropCall [0,0,0,0,0][||||] 164001.026 6 2 1 GoOnHoook_IssueDropCall end 164001.026 6 67 23 qScr run evScriptEvent sCode=[OTHER_LEG_Disconnected] iActionID=0, crn=0[16384|0|64|0|0][|||||] 164001.026 6 67 23 scriptevent OTHER_LEG_Disconnected param1:, param2:, param3: 164001.026 6 67 23 LsPlayMsgFinished EV_UNKNOWN_0,OTHER_LEG_Disconnected, [ ], [ ], [] 164001.026 6 67 23 path {OTHER_LEG_Disconnected} not found 164001.026 6 2 1 qScr run evScriptEvent sCode=[DISCONNECTED] iActionID=0, crn=0[0|64|0|0|0][|||||] 164001.026 6 2 1 scriptevent DISCONNECTED param1:, param2:, param3: 164001.026 6 2 1 LsEndingCall DISCONNECTED 0 164001.026 7 2 1 qTel run cmd_DropCall 164001.026 18 2 1 ev Dialogic 2053,GCEV_DROPCALL, crn=28400be, 2053,0,0,,, 164001.026 18 2 1 qScr add evScriptEvent 2053 GCEV_DROPCALL 164001.026 18 2 1 ev CallState GCEV_DROPCALL, crn=28400be, iEvent=2 ,1,0,32,,,]. vgEngine v7.1.3777.39220 (2010-05-05 20:47:20.42) 164001.026 6 2 1 qScr run evScriptEvent sCode=[GCEV_DROPCALL] iActionID=0, crn=28400be[2053|0|0|0|0][|||||] 164001.026 18 2 1 qScr add evCallState 2 GCEV_DROPCALL 164001.026 6 2 1 scriptevent GCEV_DROPCALL param1:, param2:, param3: 164001.026 6 2 1 LsEndingCall GCEV_DROPCALL 2053 164001.026 6 2 1 qScr run evCallState sCode=[GCEV_DROPCALL] iActionID=0, crn=28400be[1|0|32|0|0][|||||] 164001.026 6 2 1 LineEvCallState eLineStateThisEvent=Idle 164001.042 6 2 1 LineEvCallState ScriptState=LS_ENDINGCALL 164001.042 6 2 1 ls set Idle (scriptstate=LS_ENDINGCALL) 164001.042 6 2 1 yLineStateAppPov: Idle crn=28400be,ev=2,GCEV_DROPCALL,0, sParam1= 164001.042 6 67 23 qScr add evScriptEvent 0 OTHER_LEG_Idle 164001.042 6 2 1 LineEvCallState LINECALLSTATE_IDLE begin 164001.042 6 2 1 t timer clear (force=True) 164001.042 6 2 1 CallData.dateCallStartTime=6/1/2011 4:39:00 PM 164001.042 6 2 1 rv add [CallHangupTime]{2011-06-01 16:40:01} 164001.042 6 2 1 WriteCDRlogs: begin (campaign=, CallData.iLineId=2) 164001.042 6 2 1 writing CDR logs 164001.042 6 2 1 cdr.sDisposition=ANSWERED 164001.042 6 2 1 NOTE strDialoutTelNbr=12814980491, strCallerIdNbr= 164001.042 6 2 1 vg.ini/Log/CDR_LastData_SaveRv=0 - RVs XML will NOT be saved in LastApplicationData CDR field. 164001.042 6 2 1 ScriptWorkingMode set Idle_WaitingForNextCall, (called from AllScritpsCompleted_Cleanup) 164001.042 6 2 1 logs not written as LogEntryWritten=1 164001.042 6 2 1 LineState_Reinit_AndReleaseCall: crn=28400be 164001.042 6 2 1 LineState_Reinit_CleanLineState : begin 164001.042 6 2 1 ls set Null_InGuardTimeAfterEndOfCall (scriptstate=LS_ENDINGCALL) 164001.042 6 2 1 ScriptWorkingMode set Idle_WaitingForNextCall, (called from LineState_Reinit_CleanLineState) 164001.042 6 2 1 linestate reinit iConferenceOtherLegLid=67 164001.042 6 2 1 rvns add [TsRoutedTo]{} 164001.042 6 67 23 rvns add [TsRoutedTo]{} 164001.042 6 2 1 TsReset [dtiB1T1][dtiB1T23] MATCH_ call 164001.042 6 qTel add cmd_TsReset [0,0,0,0,0][dtiB1T1||dtiB1T23||] 164001.042 7 qTel run cmd_TsReset 164001.042 6 2 1 TaskQue_ktTel_TsReset_Enqueue returned: 164001.042 6 2 1 LineState_Reinit_CleanLineState: not calling HangupCall on other line (2) explicitly. Suitable event should have been sent to that line already. 164001.042 6 2 1 strThisCallIsInboundOrOutbound clear. (LineState_Reinit_CleanLineState) 164001.042 6 2 1 qTel add cmd_ReleaseCall [0,0,0,0,0][||||] 164001.042 6 2 1 t timer set 3 sec : EV_TIMEOUT_AFTERIDLE_ALLOWOUT 164001.042 6 2 1 timer set completed lTimeLeft250msUnits=12, iTimeoutCode=9013 164001.042 6 2 1 state Waiting for a call... 164001.042 6 2 1 ScriptWorkingMode set Idle_WaitingForNextCall, (called from LineState_Reinit_AndReleaseCall) 164001.042 6 67 23 qScr run evScriptEvent sCode=[OTHER_LEG_Idle] iActionID=0, crn=0[1|0|32|0|0][|||||] 164001.042 6 67 23 scriptevent OTHER_LEG_Idle param1:, param2:, param3: 164001.042 6 67 23 LsPlayMsgFinished EV_UNKNOWN_0,OTHER_LEG_Idle, [ ], [ ], [] 164001.042 6 67 23 path {OTHER_LEG_Idle} not found Share this post Link to post
