allstatesmed Report post Posted 06/04/2011 10:10 PM How can I run a vbscript or application or sql command after hangup. What I would like to do is: 1. If a call recipient hangs up during a call, I want to make sure that the $RV are entered into a text file 2. If voicemail picks up, I want to insert certain $RV into a text file. I can't use the CDR info since it does not contain all of the $RV info Share this post Link to post
SupportTeam Report post Posted 06/05/2011 10:26 AM How can I run a vbscript or application or sql command after hangup. Please see: http://www.voiceguide.com/vghelp/source/html/call%20finish.htm If voicemail picks up, I want to insert certain $RV into a text file. I can't use the CDR info since it does not contain all of the $RV info What information do you want to insert int your log file? Do you want to attach some RVs to the call at time when it is loaded, and then save this info if call is answered by answering machine? Share this post Link to post
allstatesmed Report post Posted 06/06/2011 02:49 PM Thanks for the response. What information do you want to insert int your log file? Do you want to attach some RVs to the call at time when it is loaded, and then save this info if call is answered by answering machine? Yes. I haven't created the voicemail script yet, but to give you an idea, I've attached the human answer script so you can see the $RVs I am trying to capture. TS-Responses-Human.zip Share this post Link to post
SupportTeam Report post Posted 06/06/2011 08:40 PM From the Voicemail script you would write data to file in the same way that you are writing it in your current script. (you may want to play some message first, sop that something is left on the answering machine). In your current script you are saving this to data file: "$RV[PATIENTID], VOICEGUIDE, Times per day?: $RV[input_Test_Frequency] - Uses Insulin?: $RV[insulin_Input] - Supplies exhausted?: $RV[Wants_TS] - called: $RV_CIDNUMBER - DOS: $RV[campaignname] $RV_STARTTIME - $RV[OutDial_Result] - $RV[Record_Message_EndRecCause]" so you would probably want to save something like: "$RV[PATIENTID], called: $RV_CIDNUMBER - DOS: $RV[campaignname] $RV_STARTTIME - ANSWERING MACHINE MESSAGE LEFT - $RV[OutDial_Result]" Share this post Link to post
allstatesmed Report post Posted 06/07/2011 12:58 AM Perfect, thank you! That worked. Share this post Link to post
