Egor Report post Posted 06/21/2011 11:42 PM My client experiences large number of calls been dropped in the middle of the script, which force users to call multiple times. Large number of the disconnects have "Loop Current Drop (non-xfer vgm)" as a Hangup Source. I do need your assistance to identify the source of the issue. Please review attached log files. As example please review following calls made at 1. 2011-06-21 18:58:55 2. 2011-06-21 19:06:13 P.S. SendDisconnectOnLoopCurrentDrop is set with default value '0' Thank you 0620_2200_vgEngine.zip 0620_ktTel.zip Share this post Link to post
SupportTeam Report post Posted 06/22/2011 07:38 AM The vgEngine file attached does not cover the times mentioned. We would need to see the vgEngine file to see what happened on the call. Please post the other vgEngine files for that day and we can then advise what happened on the system. Share this post Link to post
Egor Report post Posted 06/22/2011 09:46 PM Files that include examples have been added. Thank you 0621_ktTel.zip 0621_0001_vgEngine.zip Share this post Link to post
Egor Report post Posted 06/23/2011 07:15 PM I need to escalate the priority of this issue. The hangup issues are coming in series right now and calls been disconnected within the seconds after been answered. I have attached additional log files, please review date range 06/23/2011 09:38 - 06/23/2011 09:56; all calls within the date range (total of 8) been dropped. 0623_ktTel.zip 0623_0555_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 06/24/2011 11:40 AM Traces show that the Dialogic card reported that loop current was dropped and VG ended the call as a result. If these loop current drops were not reported as a result of caller hanging up then you should check the wiring. As a workaround you can set in VG.INI file: [CallControl] LoopCurrentDrop=IGNORE 094035.494 6 1 1 state [Timeout] Playing wav (C:\VoiceGuideScripts\FemWavs\Timeout.wav) 094035.494 6 1 1 t timer clear (force=False) 094035.494 6 1 1 qTel add cmd_PlayStart [0,0,0,0,0][||||] 094035.494 6 1 1 play start ok, playId=963562 094035.494 7 1 1 qTel run cmd_PlayStart 094040.025 18 1 1 ev Dialogic 134,TDX_CST, crn=10000121, 3401,0,0,DE_LCOF,, 094040.025 18 1 1 qScr add evScriptEvent 134 DE_LCOF 094040.025 6 1 1 qScr run evScriptEvent sCode=[DE_LCOF] iActionID=0, crn=10000121[3401|0|0|0|0][DE_LCOF|||||] 094040.025 6 1 1 scriptevent DE_LCOF 3401|0|0 DE_LCOF|| 094040.025 6 1 1 LsPlayMsg EV_UNKNOWN_134,DE_LCOF 094040.025 18 [CallControl]:LoopCurrentDrop = 094040.025 6 1 1 path {DE_LCOF} not found 094040.025 18 1 1 HangupCall, source=Loop Current Off (non-xfer vgm), WorkModeScript=Running_Normal, yLineStateAppPov=[Connected], lPlayId=963562, lRecId=0 094040.025 18 1 1 moduleTitle=[Timeout] 094040.025 18 1 1 ScriptWorkingMode set Stopping, (called from HangupCall) 094040.025 18 1 1 ls set Disconnect_Pending (scriptstate=LS_ENDINGCALL) 094040.025 18 1 1 state Hanging up... [Loop Current Off (non-xfer vgm)] Share this post Link to post
Egor Report post Posted 07/06/2011 04:23 PM As a result of additional troubleshooting, "possible solution" have been identified. We have requested to replace the telephone cable that was coming from the jack to the server, as result the occurrence of the issue was reduced by 98%. From time to time the issue is still re-occurring, therefore I have updated VG.INI file by un-commenting out line "LoopCurrentDrop=IGNORE" and will monitor the situation for a next week or so. Thank you for all your help. Share this post Link to post
SupportTeam Report post Posted 07/07/2011 02:01 AM OK, thanks for letting us know. Share this post Link to post
