If Else Function
How to simply determine action like function if, elseif, else
I need to determine different action comparing values of var.
example:
if var is NULL go to module A
elseif var is smaller than ccc go to module B
else go to module C
Can You write example of if else function?
I need to follow action diverse route
var<0 - route A
var=0 - route B
var>0 - route C
