No Lines Showing Up In Line Status, All Of The Sudden
For some reason the status monitor does not show any lines at all. It has been working perfectly fine until just now. I've rebooted and even powered down and up. See attached logs.
Please advise.
0730_0006_vgEngine.zip
Logs show that the Dialogic service did not start:
001002.958 204 Timed out trying to start the Dialogic system service. Please contact your System Administrator
Does the Dialogic Configuration Manager show that the Dialogic card is detected?
Suggest you stop VoiceGuide service and then resolve the Dialogic service startup issue first.
I went to the Dialogic manager and it was not started. I started it. Why does this happen? I has been working fine for the last week since I've installed it on this new computer? Why doesn't a reboot take care of that?
Not sure why the card would not startup after a system reboot. You would need to contact the card supplier and through them Dialogic to debug this.
