Insert Into Mysql
I use SIP for outbound campaign.
I would like to write responses to MySQL database.
Look pleasy into attached file, where I specified Querry Database module.
Is it correct?
What else should I check?
Database Querry.zip
I managed to have connection with my database.
The problem is there are no any answers. Records are coming to database but they are null.
Please look into log file - there is a line like that:
134219.421 6 3 1 state [save Responses] DB Query
134219.421 6 3 1 rv replace start [iNSERT INTO results (resp1, resp2, resp3, resp4) VALUES ('$RV[Question 1]', '$RV[Question 2]', '$RV[Question 3]', '$RV[Question 4]')]
134219.437 6 rv dbg rv_retrieve did not find [Question 1] ( 51 75 65 73 74 69 6f 6e 20 31)
134219.437 6 rv dbg rv_retrieve did not find [Question 2] ( 51 75 65 73 74 69 6f 6e 20 32)
134219.437 6 rv dbg rv_retrieve did not find [Question 3] ( 51 75 65 73 74 69 6f 6e 20 33)
134219.437 6 rv dbg rv_retrieve did not find [Question 4] ( 51 75 65 73 74 69 6f 6e 20 34)
what means I think there is another issue.
0731_1341_vgEngine.zip
In your script the module names that are used are Question1 - Question4
There is no space between 'Question' and the number.
But in the $RVs in SQL query there are spaces between 'Question' and the number. - so VG cannot find any values for them, so the are null at insertion.
Change
INSERT INTO results (resp1, resp2, resp3, resp4) VALUES ('$RV[Question 1]', '$RV[Question 2]', '$RV[Question 3]', '$RV[Question 4]')
to:
INSERT INTO results (resp1, resp2, resp3, resp4) VALUES ('$RV[Question1]', '$RV[Question2]', '$RV[Question3]', '$RV[Question4]')
