brianlala Report post Posted 08/04/2011 03:00 AM I am using Axon Virtual PBX and try to register VG (HMP) to the Virtual PBX. VG service can be started successfully but i cannot see any registration message in my PBX log. It seems the registration process is failed. 0804.zip0804.zipWhen I look at the _ktTel.txt, I found the following error: 104346.803 4644 IPT_BOARD_COUNT = 1 104346.803 4644 gc_Start &gclib_start call 104349.350 4644 ERROR gc_start 104349.350 4644 2 StartDialogicGlobalCall returned -1 Please help~ Thank you very much. Br, Brian Share this post Link to post
SupportTeam Report post Posted 08/04/2011 03:49 AM Looks like Dialogic HMP did not start properly on this system. Probably best thing to do would be to first concentrate on getting HMP working properly. Dialogic HMP installs some demo apps in it's \demo\ subdirectory. Recommend that you try running the IpMediaServer.exe from the \demo\IpMediaServer\Release\ direcctory. You will need to run it from the Command Prompt. (or from the C:\ProgramData\Dialogic\HMP\demos\ sudirectory. C:\ProgramData may be a 'hidden' folder. Use Control Panel > Folder Options > View Tab > Select Show hidden folders.) Then try to call into this system from another SIP phone or SIP softphone from another computer. If HMP is working then you should be able to hear IpMediaServer answer and play the 'Main Menu' prompt. Once you have HMP working then you can move onto starting the VoiceGuide service. Share this post Link to post
SupportTeam Report post Posted 08/04/2011 04:07 AM A successful running of the IPMediaServer demo should look like this in the Command Prompt window: C:\Program Files\Dialogic\HMP\demos\IPMediaServer\Release>ipmediaserver ************************************************************ * * * IP Media Server - Media services over IP Demo Program. * * Copyright ⌐ 2003 Intel Corporation. * * * ************************************************************ DTMFMode inband TxCoder[0] Capability: g711mulaw Type: 2 Direction: 1 Payload_type: 255 FramesPerPacket: 20 VAD: 0. RxCoder[0] Capability: g711mulaw Type: 2 Direction: 2 Payload_type: 255 FramesPerPacket: 20 VAD: 0. [info] CEventRouter::Init: Initializing channels...may take a few seconds! <<Number of Fax (& Voice) boards found: 1 >> <<Number of Voice (& Fax boards) found: 1 >> <<Number of IPT boards found: 1>> <<Number of IPM boards found: 1>> Waiting for key: 'Q' - to quit CIPDevice::processEvent -> receive GCEV_UNBLOCKED on :N_iptB1T1:P_IP:M_ipmB1C1 IP: Process GCEV_OFFERED event in Null state The protocol name is CALLPROTOCOL_SIP IP:enter OFFERED state IP: Process GCEV_EXTENSION in OFFERED state GetExtensionCmpltInfo IP: Process GCEV_ANSWERED in OFFERED state IP:enter CONNECTED state destination = 2, channelId = 0 CVoiceStateMachine::NullUsrconnected: process USR_CONNECTED in NULL state CVoiceStateMachine::NullUsrconnected: play mainmenu CVoiceStateMachine::ChangeState: MAIN_MENU state IP: Process GCEV_DISCONNECTED in CONNECTED state IP:enter DROPPING state destination = 2, channelId = 0 CVoiceStateMachine::GeneralDisconnect: GeneralDisconnect CVoiceStateMachine::ChangeState: NULL state IP: Process GCEV_DROPCALL in DROPPING state IP:enter RELEASING state IP: Process GCEV_RELEASECALL in RELEASING state IP:enter NULL state CVoiceStateMachine::NullImplementation: not implemented The above shows startup and a call successfully answered by IPMediaServer demo. Share this post Link to post
SupportTeam Report post Posted 08/04/2011 04:10 AM And attached the is the WireShark trace showing the SIP pacekt trace of successful call to HMPs IPMediaServer demo. It shows call being answered by HMP and caller hanging up soon afterwards. IPDemo_Capture.zip Share this post Link to post
brianlala Report post Posted 08/04/2011 06:16 AM Thanks for your prompt reply!!! I got IPT boards error when i run IPMediaServer.exe How can I fix this problem??? C:\Program Files\Dialogic\HMP\demos\IPMediaServer\Release>IPMediaServer.exe ************************************************************ * * * IP Media Server - Media services over IP Demo Program. * * Copyright ?2003 Intel Corporation. * * * ************************************************************ DTMFMode inband TxCoder[0] Capability: g711mulaw Type: 2 Direction: 1 Payload_type: 255 FramesPerPacket: 20 VAD: 0. RxCoder[0] Capability: g711mulaw Type: 2 Direction: 2 Payload_type: 255 FramesPerPacket: 20 VAD: 0. [info] CEventRouter::Init: Initializing channels...may take a few seconds! <<Number of Fax (& Voice) boards found: 2 >> <<Number of Voice (& Fax boards) found: 2 >> <<Number of IPT boards found: 1>> Error: CIPTBoard::Init -> gc_OpenEx failed to get IPT board handle for :N_iptB1:P_IP Error: CIPModule::Init -> failed to initialize IPT board :N_iptB1:P_IP <<Number of IPM boards found: 1>> Waiting for key: 'Q' - to quit Here is the screen cap. of Dialogic Configuration Manager Share this post Link to post
SupportTeam Report post Posted 08/04/2011 06:57 AM Can you tell us more about your system? CPU, version of Windows, are you using any visualization? Further information about the system requirements is in the HMP Installation Guide: http://www.dialogic.com/manuals/hmp30win/release_install.pdf Share this post Link to post
brianlala Report post Posted 08/04/2011 08:08 AM I am using WindowsXP sp3, Intel Core 2 CPU I got this result now~ Is HMP installed properly? C:\Program Files\Dialogic\HMP\demos\IPMediaServer\Release>IPMediaServer ************************************************************ * * * IP Media Server - Media services over IP Demo Program. * * Copyright ?2003 Intel Corporation. * * * ************************************************************ DTMFMode inband TxCoder[0] Capability: g711mulaw Type: 2 Direction: 1 Payload_type: 255 FramesPerPacket: 20 VAD: 0. RxCoder[0] Capability: g711mulaw Type: 2 Direction: 2 Payload_type: 255 FramesPerPacket: 20 VAD: 0. [info] CEventRouter::Init: Initializing channels...may take a few seconds! <<Number of Fax (& Voice) boards found: 2 >> <<Number of Voice (& Fax boards) found: 2 >> <<Number of IPT boards found: 1>> <<Number of IPM boards found: 1>> Waiting for key: 'Q' - to quit CIPDevice::processEvent -> receive GCEV_UNBLOCKED on :N_iptB1T1:P_IP:M_ipmB1C1 CIPDevice::processEvent -> receive GCEV_UNBLOCKED on :N_iptB1T2:P_IP:M_ipmB1C2 Share this post Link to post
SupportTeam Report post Posted 08/04/2011 08:39 AM That looks much better. Did you reinstall HMP using an 'Administrator' account? Or did you make some other changes? Share this post Link to post
brianlala Report post Posted 08/05/2011 02:31 AM Originally, my virtual PBX and VG are installed in the same computer. Once I move the virtual PBX to another PC, VG can register to the PBX successfully!!! Thank you for your help~ Br, Brian Share this post Link to post
SupportTeam Report post Posted 08/05/2011 02:55 AM OK, so looks like HMP was not starting up as another application was using the SIP port already. Thanks for letting us know that's sorted out, please let us know if there are any other issues that you encounter in future. Share this post Link to post
shimmer Report post Posted 05/31/2014 10:18 PM I have a server and I run voiceguide on it using port 5060 and I also run 3CX TELEPHONE SYSTEM IP PBX AND RUN IT ON PORT 5062. It took me about a month router needs 1 to 1 Nat programming to assign a outside static ip to each network card on my server and it rock's Share this post Link to post
