Verify Entered Number In Get Numbers Module
Hi There,
When I using VBS to Verify Entered Number, How can I return "verify_passed" back to VoiceGuide by using TXT file?
The license we have is Professional license, which means we can't use COM like "vg.Run_ResultReturn $RV_LINEID, sResult"
All of our other VBS Modules are using text files to return variables or FAIL, however, it seems Verify Entered Number in Get Numbers Module doesn't looking for value stored in text files.
Best regards,
Sasha
Log:
133603.67 9 eng copy of verification script ran: vbs_9_2_0825133603.vbs
133603.70 9 Run Script waiting. iRunWait=1 (shellid=2712, process=1804)
133603.70 9 timer set 1 EV_TIMEOUT_CHECKONSTATE
133604.72 9 timer fired EV_TIMEOUT_CHECKONSTATE
133604.72 9 ScriptEventCode 9007 iLineState=1301
133604.72 9 LsGetNbrsRxDigits EV_TIMEOUT_CHECKONSTATE
133604.72 9 task completed (shellid=2712, process=1804)
133604.72 9 eng verify task did not return any data. This is an immediate failure.
VBS Script for return passed:
If GAwks < 30 And GAdys < 7 Then
strResVar = "verify_passed"
Else
strResVar = "verify_failed"
End If
iRet = WriteResultFile(strResVar)
function WriteResultFile(strResult)
const ForReading=1, ForWriting=2, ForAppending=8
Dim fso, ts, filename
filename = "VGRUNRESULT_$RV_LINEID.TXT"
set ts = fso.OpenTextFile(filename, ForWriting, True)
ts.WriteLine(strResult)
ts.Close
WriteResultFile = 0
end function
