invoso.com Report post Posted 08/26/2011 11:52 AM In Capture Entered Number module i checked option: Play back entered number and ask caller to confirm and VG playing poor quality prompt. I use same prompts in other part of script and his quality is OK. prompt example attached. 1.wav Share this post Link to post
SupportTeam Report post Posted 08/26/2011 01:17 PM What format is the sound file? If sound multiple sound files are concatenated (and they are when numbers are played back to caller) then all sound files must be in same format. This includes the "you have entered the following number" and "press 1 to confirm etc." prefixes and suffixes. What format are the VoiceGuide system sound files GetNbrsConfirmIntro.wav and GetNbrsConfirmMenu.wav on your system? If you still have issues please post the ktTel trace capturing system startup and the call. Share this post Link to post
invoso.com Report post Posted 08/29/2011 06:21 AM You're right. System prompts is 64 kbps rated and my prompts are 128 kbps. After changing transmission both files to 128 kbps VG playback prompts properly. Thanks a lot. Share this post Link to post
