Guest Tim Report post Posted 11/04/2003 05:01 PM I have a "capture entered number" module. The path is set so that "on star key" move to the next module. So the user might type in 123* for example. If I then use $RV to read the value of the module, it only returns the star. Is this a bug? Is there a work around? thank you Tim Share this post Link to post
SupportTeam Report post Posted 11/05/2003 12:12 AM Please use an on {success} goto .... path. If you have an on {*} goto .... path then when a * key is pressed then it is an exact match for that path and that path will be taken. * is often used in IVR systems to indicate that a caller wants to go back up a menu, or does not want to enter anything in this module. Usually to finish entering a number users should be asked to press the # key. Share this post Link to post
