Voiceguide Saving 20 Sec Wav As 1kb
Hello,
We have just moved our dialogic card into a new server and copied the scripts across, everything is working except for the recording. Each WAV file is being saved as 1kb.
The log below is from a script we setup simple to record for 20 secs then hangup.
Any ideas on why this is occurring?
It seems to work as it should although the resulting file is tiny.
Thanks,
Tim
164553.08 5 linedevstate 2048 0 0
164553.08 5 callstate OFFERING 65952 0 4
164553.08 5 Answer the call at 6/11/2003 4:45:53 PM
164553.09 5 lineAnswer(65952) => 65593
164553.09 5 Lev_CallerID [0423808106,]
164553.09 5 callinfo CALLEDID
164553.09 5 callinfo ORIGIN
164553.09 5 ring 0
164553.63 5 callstate CONNECTED 65952,1,0
164553.63 5 WorkingModeTAPI@Connected=
164553.63 5 WorkingModeScript@Connected=
164553.65 5 Inband detection not enabled
164553.65 5 StartLoadedVgs at 6/11/2003 4:45:53 PM
164553.65 5 tapi Reply (LineEvReply) ok 65593 0
164553.65 5 [Record 2] Recording
164553.66 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav]
164553.86 5 wb(51838300)
164554.86 5 Play End line[5] (id=518383)
164554.88 5 LsRecPlayBeep EV_PLAY_FINISHED
164554.88 5 RecSoundStart file[c:\mytest.wav] ok
164554.88 5 RecFile[c:\mytest.wav]
164609.80 5 LsRecRecording EV_TIMEOUT_GOTOMODULE
164610.80 5 RecSoundStop ok
164610.80 5 Record 2_RecLen100ms = 148
164610.81 5 Hanging up call... [Hangup Module]
164610.81 5 RecSoundStop ok
164610.82 5 PlaySoundStop ok
164610.82 5 fnHangupCall end
164610.86 5 linedevstate 2048 0 0
164610.86 5 callstate IDLE 65952 0 0
164610.87 5 WorkingMode@Idle=
164610.87 5 tapi Reply (LineEvReply) ok 65576 0
164611.82 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
164611.82 5 ReinitTelephony due to IDLE start
164611.83 5 tapic lineDeallocateCall(MainCall:65952) 0
164611.88 5 lineOpen(5) => 0
164611.88 5 Waiting for a call...
164611.88 5 lineOpen(5)LineHandle=65969
164631.84 0 sys cleanup Start
164631.84 0 sys cleanup End
Note: The file (mytest.wav) is actually 46bytes (not 1kb)
WAV details as follows
Audio format: PCM
Avergae data rate: 11.25Kb/second
Sample Rate: 11.25 kHz
Audio Sample size: 8 bit
Channels: 1 (Mono)
Please note that the system is currently playing WAV files correctly, it is just the recording that is not working.
Appears as if the Wave drivers from Dialogic are just not supplying any recorded data...
Could you please try re-installing the Dialogic's Wave drivers, and if this does not fix things could you please place the attached file in "C:\" then make another call and post the contents of the created C:\TapiWrapLogMMDD.txt file...
TapiWrapLogSelect.txt
no luck.
Adding that file to c:\ did not do anything.
e.g that file was not created.
I tried creating a blank file and calling again but no info was stored in it.
225948.727 ------------------------------------------------------------------------------
225948.727 TAPIWrap OCX v1.51.0, Oct 31 2003 18:34:43 [For Dialogic Analog]
225948.727 Started at 1106 225948.727
225948.727 init Trace Select file Found. Selected trace levels:
|ALL |
225948.867 linec lineInitialize(0x24f8bd8, 0x2050000, 0x2059970, TapiWrap, 0x24f8bdc) => 0x0
225948.867 tapic lineNegotiateAPIVersion(0x800003ff, 0, 0x10003, 0x20001, 0x219fe8, 0x12ef04)
225948.867 tapic lineGetDevCaps(0x800003ff, 0, 0x10003, 0, 0x2271e0) call
225948.867 tapic lineGetDevCaps(0x800003ff, 0, 0x10003, 0, 0x2271e0) => NO_ERROR (0)
225948.867 tapic lineGetIcon(0, 0, 0x219ff0)
225948.878 tapic lineNegotiateAPIVersion(0x800003ff, 1, 0x10003, 0x20001, 0x3ad0058, 0x12ef04)
225948.878 tapic lineGetDevCaps(0x800003ff, 1, 0x10004, 0, 0x2271e0) call
225948.878 tapic lineGetDevCaps(0x800003ff, 1, 0x10004, 0, 0x2271e0) => NO_ERROR (0)
225948.878 tapic lineGetIcon(1, 0, 0x3ad0060)
225948.878 tapic lineNegotiateAPIVersion(0x800003ff, 2, 0x10003, 0x20001, 0x3add260, 0x12ef04)
225948.878 tapic lineGetDevCaps(0x800003ff, 2, 0x10004, 0, 0x2271e0) call
225948.878 tapic lineGetDevCaps(0x800003ff, 2, 0x10004, 0, 0x2271e0) => NO_ERROR (0)
225948.878 tapic lineGetIcon(2, 0, 0x3add268)
225948.878 tapic lineNegotiateAPIVersion(0x800003ff, 3, 0x10003, 0x20001, 0x3aea468, 0x12ef04)
225948.878 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x2271e0) call
225948.878 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x2271e0) => NO_ERROR (0)
225948.878 tapic lineGetIcon(3, 0, 0x3aea470)
225948.878 fn TAPI_ERR: LINEERR_OPERATIONUNAVAIL
225948.878 tapic lineNegotiateAPIVersion(0x800003ff, 4, 0x10003, 0x20001, 0x3af7670, 0x12ef04)
225948.878 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x2271e0) call
225948.878 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x2271e0) => NO_ERROR (0)
225948.878 tapic lineGetIcon(4, 0, 0x3af7678)
225948.878 tapic lineNegotiateAPIVersion(0x800003ff, 5, 0x10003, 0x20001, 0x3b04878, 0x12ef04)
225948.878 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x2271e0) call
225948.878 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x2271e0) => NO_ERROR (0)
225948.878 tapic lineGetIcon(5, 0, 0x3b04880)
225948.888 tapic lineNegotiateAPIVersion(0x800003ff, 6, 0x10003, 0x20001, 0x3b11a80, 0x12ef04)
225948.888 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x22aeb8) call
225948.888 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x22aeb8) => NO_ERROR (0)
225948.888 tapic lineGetIcon(6, 0, 0x3b11a88)
225948.888 tapic lineNegotiateAPIVersion(0x800003ff, 7, 0x10003, 0x20001, 0x3b1ec88, 0x12ef04)
225948.888 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x22aeb8) call
225948.888 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x22aeb8) => NO_ERROR (0)
225948.888 tapic lineGetIcon(7, 0, 0x3b1ec90)
225948.888 tapic lineNegotiateAPIVersion(0x800003ff, 8, 0x10003, 0x20001, 0x3b2be90, 0x12ef04)
225948.888 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x22aeb8) call
225948.888 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x22aeb8) => NO_ERROR (0)
225948.888 tapic lineGetIcon(8, 0, 0x3b2be98)
225948.888 dlgc calling enabling CST Handler - not DTI boards found
225948.888 dlgc detected Dialogic boards: Dti:0, Voice:1
225948.938 dlgc opened channel dxxxB1C1 channum=1, chdev=1
225949.038 dlgc calling dx_setevtmsk on channel dxxxB1C1
225949.038 dlgc opened channel dxxxB1C2 channum=2, chdev=2
225949.038 dlgc calling dx_setevtmsk on channel dxxxB1C2
225949.038 dlgc opened channel dxxxB1C3 channum=3, chdev=3
225949.038 dlgc calling dx_setevtmsk on channel dxxxB1C3
225949.048 dlgc opened channel dxxxB1C4 channum=4, chdev=4
225949.048 dlgc calling dx_setevtmsk on channel dxxxB1C4
225949.068 ocxfn GetLineCount()
225949.068 ocxfn GetLineName(sLineId=8)
225949.068 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x3bc7f88) call
225949.068 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x3bc7f88) => NO_ERROR (0)
225949.078 ocxfn GetLineName(sLineId=7)
225949.078 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x3bc9df8) call
225949.078 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x3bc9df8) => NO_ERROR (0)
225949.078 ocxfn GetLineName(sLineId=6)
225949.078 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x3bc9df8) call
225949.078 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x3bc9df8) => NO_ERROR (0)
225949.078 ocxfn GetLineName(sLineId=5)
225949.088 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x3bc9df8) call
225949.088 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x3bc9df8) => NO_ERROR (0)
225949.088 ocxfn GetLineName(sLineId=4)
225949.088 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x3bc9df8) call
225949.088 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x3bc9df8) => NO_ERROR (0)
225949.088 ocxfn GetLineName(sLineId=3)
225949.088 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x3bc9e20) call
225949.088 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x3bc9e20) => NO_ERROR (0)
225949.088 ocxfn GetLineName(sLineId=2)
225949.088 tapic lineGetDevCaps(0x800003ff, 2, 0x10004, 0, 0x3bc9e20) call
225949.088 tapic lineGetDevCaps(0x800003ff, 2, 0x10004, 0, 0x3bc9e20) => NO_ERROR (0)
225949.088 ocxfn GetLineName(sLineId=1)
225949.088 tapic lineGetDevCaps(0x800003ff, 1, 0x10004, 0, 0x3bc9e20) call
225949.088 tapic lineGetDevCaps(0x800003ff, 1, 0x10004, 0, 0x3bc9e20) => NO_ERROR (0)
225949.088 ocxfn GetLineName(sLineId=0)
225949.088 tapic lineGetDevCaps(0x800003ff, 0, 0x10003, 0, 0x3bc9e20) call
225949.088 tapic lineGetDevCaps(0x800003ff, 0, 0x10003, 0, 0x3bc9e20) => NO_ERROR (0)
225949.088 ocxfn GetLineName(sLineId=-1)
225950.270 ocxfn LineOpen(sLineId=5)
225950.270 tapic lineNegotiateAPIVersion(0x800003ff, 5, 0x10003, 0x20001, 0x3b04878, 0x12e4c8)
225950.270 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x3fa84a0) call
225950.270 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x3fa84a0) => NO_ERROR (0)
225950.280 tapic lineGetIcon(5, 0, 0x3b04880)
225950.280 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x3fa84a0) call
225950.280 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x3fa84a0) => NO_ERROR (0)
225950.280 tapic lineOpen(0x800003ff, 5, 0x3b04874, 0x10004, 0, 0x3b04868, 0x4, LINEMEDIAMODE_INTERACTIVEVOICE | LINEMEDIAMODE_AUTOMATEDVOICE, 0)
225950.310 tapic lineGetID(0x10155, 0, 0, 0x1, 0x3fa84a0, wave/in) LINECALLSELECT_LINE hLineInfo
225950.320 tapic lineGetID(0x10155, 0, 0, 0x1, 0x3fa84a0, wave/in) => 0x0
225950.320 tapic lineGetID => 0
225950.320 tapic lineGetID(0x10155, 0, 0, 0x1, 0x3fa84a0, wave/out) LINECALLSELECT_LINE hLineInfo
225950.320 tapic lineGetID(0x10155, 0, 0, 0x1, 0x3fa84a0, wave/out) => 0x0
225950.320 ocxfn GetLineName(sLineId=5)
225950.320 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x3fa84a0) call
225950.320 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x3fa84a0) => NO_ERROR (0)
225950.320 wavec waveInGetDevCaps(0x0, 0x12e52c, 0x30) => 0
225950.320 wavec waveOutGetDevCaps(0x0, 0x12e4f8, 0x34) => 0
225950.330 wave IN:Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1 OUT:Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1, support=0x4
225950.420 ocxfn GetProviderInfo(sLineId=5)
225950.420 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x3fa9df8) call
225950.420 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x3fa9df8) => NO_ERROR (0)
225950.420 fn GetProviderInfo => Dialogic
225950.420 ocxfn SilenceDetectSet(sLineId=5, sTimeLen=0, sVolumeLevel=0)
225950.430 ocxfn DialogicScUnroute dxxxB1C1
225950.430 dlgc set DevType1 = LSI, sDlgcDevName=dxxxB1C1
225950.440 dlgc opened dxxxB1C1 as devh=5
225950.450 dlgc dx_getxmitslot dxxxB1C1(5) => 0
225950.450 dlgc ag_listen() for dxxxB1C1(5) ok
225950.450 dlgc closed dxxxB1C1 (devh=5) ok
225950.450 dlgc DialogicScUnroute finished
225950.450 ocxfn LineOpen(sLineId=6)
225950.450 tapic lineNegotiateAPIVersion(0x800003ff, 6, 0x10003, 0x20001, 0x3b11a80, 0x12e4c8)
225950.450 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x3fabef8) call
225950.450 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x3fabef8) => NO_ERROR (0)
225950.450 tapic lineGetIcon(6, 0, 0x3b11a88)
225950.450 tapic lineOpen(0x800003ff, 6, 0x3b11a7c, 0x10004, 0, 0x3b11a70, 0x4, LINEMEDIAMODE_INTERACTIVEVOICE | LINEMEDIAMODE_AUTOMATEDVOICE, 0)
225950.480 tapic lineGetID(0x10133, 0, 0, 0x1, 0x3fa9ee8, wave/in) LINECALLSELECT_LINE hLineInfo
225950.480 tapic lineGetID(0x10133, 0, 0, 0x1, 0x3fa9ee8, wave/in) => 0x0
225950.480 tapic lineGetID => 1
225950.480 tapic lineGetID(0x10133, 0, 0, 0x1, 0x3fa9ee8, wave/out) LINECALLSELECT_LINE hLineInfo
225950.480 tapic lineGetID(0x10133, 0, 0, 0x1, 0x3fa9ee8, wave/out) => 0x0
225950.480 ocxfn GetLineName(sLineId=6)
225950.480 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x3fabef8) call
225950.490 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x3fabef8) => NO_ERROR (0)
225950.490 wavec waveInGetDevCaps(0x1, 0x12e52c, 0x30) => 0
225950.490 wavec waveOutGetDevCaps(0x1, 0x12e4f8, 0x34) => 0
225950.490 wave IN:Dialogic Wave[dxxxB1C2] v16.0 format=0x1, channels=0x1 OUT:Dialogic Wave[dxxxB1C2] v16.0 format=0x1, channels=0x1, support=0x4
225950.490 ocxfn GetProviderInfo(sLineId=6)
225950.490 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x3fabef8) call
225950.490 fn GetProviderInfo => Dialogic
225950.490 ocxfn SilenceDetectSet(sLineId=6, sTimeLen=0, sVolumeLevel=0)
225950.490 ocxfn DialogicScUnroute dxxxB1C2
225950.500 dlgc set DevType1 = LSI, sDlgcDevName=dxxxB1C2
225950.500 dlgc opened dxxxB1C2 as devh=5
225950.500 dlgc dx_getxmitslot dxxxB1C2(5) => 1
225950.500 dlgc ag_listen() for dxxxB1C2(5) ok
225950.500 dlgc closed dxxxB1C2 (devh=5) ok
225950.500 dlgc DialogicScUnroute finished
225950.500 ocxfn LineOpen(sLineId=7)
225950.500 tapic lineNegotiateAPIVersion(0x800003ff, 7, 0x10003, 0x20001, 0x3b1ec88, 0x12e4c8)
225950.500 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x3fac828) call
225950.500 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x3fac828) => NO_ERROR (0)
225950.500 tapic lineGetIcon(7, 0, 0x3b1ec90)
225950.510 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x3fac828) => NO_ERROR (0)
225950.510 tapic lineOpen(0x800003ff, 7, 0x3b1ec84, 0x10004, 0, 0x3b1ec78, 0x4, LINEMEDIAMODE_INTERACTIVEVOICE | LINEMEDIAMODE_AUTOMATEDVOICE, 0)
225950.540 tapic lineGetID(0x10111, 0, 0, 0x1, 0x3fa9ee8, wave/in) LINECALLSELECT_LINE hLineInfo
225950.540 tapic lineGetID(0x10111, 0, 0, 0x1, 0x3fa9ee8, wave/in) => 0x0
225950.540 tapic lineGetID => 2
225950.540 tapic lineGetID(0x10111, 0, 0, 0x1, 0x3fa9ee8, wave/out) LINECALLSELECT_LINE hLineInfo
225950.540 tapic lineGetID(0x10111, 0, 0, 0x1, 0x3fa9ee8, wave/out) => 0x0
225950.540 ocxfn GetLineName(sLineId=7)
225950.540 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x3fac828) call
225950.540 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x3fac828) => NO_ERROR (0)
225950.540 wavec waveInGetDevCaps(0x2, 0x12e52c, 0x30) => 0
225950.540 wavec waveOutGetDevCaps(0x2, 0x12e4f8, 0x34) => 0
225950.540 wave IN:Dialogic Wave[dxxxB1C3] v16.0 format=0x1, channels=0x1 OUT:Dialogic Wave[dxxxB1C3] v16.0 format=0x1, channels=0x1, support=0x4
225950.540 ocxfn GetProviderInfo(sLineId=7)
225950.550 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x3fac828) => NO_ERROR (0)
225950.550 fn GetProviderInfo => Dialogic
225950.550 ocxfn SilenceDetectSet(sLineId=7, sTimeLen=0, sVolumeLevel=0)
225950.550 ocxfn DialogicScUnroute dxxxB1C3
225950.550 dlgc set DevType1 = LSI, sDlgcDevName=dxxxB1C3
225950.550 dlgc opened dxxxB1C3 as devh=5
225950.550 dlgc dx_getxmitslot dxxxB1C3(5) => 2
225950.550 dlgc ag_listen() for dxxxB1C3(5) ok
225950.560 dlgc closed dxxxB1C3 (devh=5) ok
225950.560 dlgc DialogicScUnroute finished
225950.560 ocxfn LineOpen(sLineId=8)
225950.560 tapic lineNegotiateAPIVersion(0x800003ff, 8, 0x10003, 0x20001, 0x3b2be90, 0x12e4c8)
225950.560 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x3facb38) call
225950.560 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x3facb38) => NO_ERROR (0)
225950.560 tapic lineGetIcon(8, 0, 0x3b2be98)
225950.560 tapic lineOpen(0x800003ff, 8, 0x3b2be8c, 0x10004, 0, 0x3b2be80, 0x4, LINEMEDIAMODE_INTERACTIVEVOICE | LINEMEDIAMODE_AUTOMATEDVOICE, 0)
225950.590 tapic lineGetID(0x100ff, 0, 0, 0x1, 0x3fabca8, wave/in) LINECALLSELECT_LINE hLineInfo
225950.590 tapic lineGetID(0x100ff, 0, 0, 0x1, 0x3fabca8, wave/in) => 0x0
225950.590 tapic lineGetID => 3
225950.590 tapic lineGetID(0x100ff, 0, 0, 0x1, 0x3fabca8, wave/out) LINECALLSELECT_LINE hLineInfo
225950.590 tapic lineGetID(0x100ff, 0, 0, 0x1, 0x3fabca8, wave/out) => 0x0
225950.590 ocxfn GetLineName(sLineId=8)
225950.590 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x3facb38) call
225950.600 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x3facb38) => NO_ERROR (0)
225950.600 wavec waveInGetDevCaps(0x3, 0x12e52c, 0x30) => 0
225950.600 wavec waveOutGetDevCaps(0x3, 0x12e4f8, 0x34) => 0
225950.600 wave IN:Dialogic Wave[dxxxB1C4] v16.0 format=0x1, channels=0x1 OUT:Dialogic Wave[dxxxB1C4] v16.0 format=0x1, channels=0x1, support=0x4
225950.600 ocxfn GetProviderInfo(sLineId=8)
225950.600 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x3facb38) call
225950.600 fn GetProviderInfo => Dialogic
225950.600 ocxfn SilenceDetectSet(sLineId=8, sTimeLen=0, sVolumeLevel=0)
225950.600 ocxfn DialogicScUnroute dxxxB1C4
225950.600 dlgc set DevType1 = LSI, sDlgcDevName=dxxxB1C4
225950.600 dlgc opened dxxxB1C4 as devh=5
225950.610 dlgc dx_getxmitslot dxxxB1C4(5) => 3
225950.610 dlgc ag_listen() for dxxxB1C4(5) ok
225950.610 dlgc closed dxxxB1C4 (devh=5) ok
225950.610 dlgc DialogicScUnroute finished
230030.397 dlgc cst_hdlr start
230030.397 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230030.397 dlgc Unknown CST Event (1) Received on dxxxB1C1
230030.397 tapie LINE_LINEDEVSTATE(5, 0x10155, 0x800, 0x0, 0x0)
230030.397 tapie LINE_CALLSTATE(5, 0x100cc, 0x2, 0x0, 0x4)
230030.397 tapic lineMonitorDigits(0x100cc, 0x2) => 0x0
230030.397 tapic lineMonitorMedia(0x100cc, 0xfc) => 0
230030.427 tapic lineGetCallInfo(0x100cc, 0x3fae580)
230030.427 ocxev CallerId(sLineId=5, hCall=0x100cc, strNbr=[0423808106], strName=[ ], strDialed=[0000])
230030.427 tapie LINE_CALLINFO(5, 0x100cc, 0x8000)
230030.427 tapic lineGetCallInfo(0x100cc, 0x3fae6b0)
230030.427 tapie LINE_CALLINFO(5, 0x100cc, 0x10000)
230030.427 tapie LINE_CALLINFO(5, 0x100cc, 0x100)
230030.437 tapie LINE_LINEDEVSTATE(5, 0x10155, 0x2, 0x0, 0x0)
230030.968 tapie LINE_CALLSTATE(5, 0x100cc, 0x100, 0x1, 0x0)
230030.968 tapic lineGetID(0x10155, 0, 0, 0x1, 0x3fae730, wave/in) LINECALLSELECT_LINE hLineInfo
230030.968 tapic lineGetID(0x10155, 0, 0, 0x1, 0x3fae730, wave/in) => 0x0
230030.968 tapic lineGetID => 0
230030.968 tapic lineGetID(0x10155, 0, 0, 0x1, 0x3fae730, wave/out) LINECALLSELECT_LINE hLineInfo
230030.968 tapic lineGetID(0x10155, 0, 0, 0x1, 0x3fae730, wave/out) => 0x0
230031.008 tapie LINE_REPLY(5, 0x0, 0x100bb, 0x0)
230031.008 tapie LINE_CALLINFO(5, 0x100cc, 0x8000000)
230031.128 ocxfn PlayMultiDelimited(sLineId=5, strFile1=C:\Program Files\VoiceGuide\system\voice\beep1.wav, lPlayId=0xdbb1d, lOptions=0x1, strOptions=)
230031.128 tr 5 ResetWavOutAndContinuePlay start
230031.128 play FileMmioOpenAndAscend start C:\Program Files\VoiceGuide\system\voice\beep1.wav
230031.168 play FileMmioOpenAndAscend end
230031.168 fn play wav format: wFormatTag=0x1, nChannels=1, nSamplesPerSec=11025, nAvgBytesPerSec=11025, nBlockAlign=1, wBitsPerSample=8, cbSize=0
230031.168 wavec waveOutOpen(0x0, 0x0, 0x3b04890, 0x0, 0x0, 0x1) => 0 (MMSYSERR_OK) - format query
230031.168 wavec waveOutOpen(0x3b048c4, 0x0, 0x3b04890, 0x1085c, 0x3b04868, 0x10002) => 0 (MMSYSERR_OK) ... hli->hWaveOut=0x3fae4cc
230031.168 wavec waveOutReset(0x3fae4cc) => 0 fn:PlaySoundStart
230031.168 tapic lineMonitorDigits(0x100cc, 0x2) => 0x0
230031.168 tapic lineMonitorMedia(0x100cc, 0x7c) => 0
230031.168 play FileMmioOpenAndAscend start C:\Program Files\VoiceGuide\system\voice\beep1.wav
230031.178 play FileMmioOpenAndAscend end
230031.178 play LoadCurrFileToPlay_IntoOneMainBuffer start
230031.178 play FileMmioOpenAndAscend start C:\Program Files\VoiceGuide\system\voice\beep1.wav
230031.178 iPlayListIdxCurr 0 wav format: wFormatTag=0x1, nChannels=1, nSamplesPerSec=11025, nAvgBytesPerSec=11025, nBlockAlign=1, wBitsPerSample=8, cbSize=0
230031.178 wavec waveOutWrite HeapAllocs bytes: DataToPlay=2053, WaveHdr=32, UserData=12
230031.178 wavehdr: lpData=0x3fd2d80, dwBufferLength=2053, dwBytesRecorded=0, dwUser=0x3f61fc0, dwFlags=0x0, dwLoops=0x0, lpNext=0x0, reserved=0x0
230031.178 play LoadCurrFileToPlay_IntoOneMainBuffer end
230031.178 tr fn ResetWavOutAndContinuePlay LoadCurrFileToPlay returned
230031.178 wavec waveOutPrepareHeader(0x3fae4cc, 0x3fb04e0, 0x20) => 0
230031.178 wavec waveOutWrite(0x3fae4cc, 0x3fb04e0, 0x20) => 0
230031.178 tr fn PostMessage WM_FIRE_PLAY_WDOG_SET_EVENT (all in 1 buffer) params: 5 89986900
230031.178 fn OnFirePlayPlayWdogSetEvent start
230031.178 ocxev PlayWdogSet(dwLineId=5, dwPlayId=0x55d1754, LenMsecs=186)
230031.178 tapie LINE_CALLINFO(5, 0x100cc, 0x8000000)
230031.379 ocxfn PlayStopSpecial(sLineId:5, lParam1:0x55d1754, lParam2(idcode):0, giving: dwPlayId=899869, iPlayIdx=0)
230031.379 wavec waveOutReset(0x3fae4cc) call fn:PlayStopSpecial
230032.390 wavec waveOutReset(0x3fae4cc) => 0 (MMSYSERR_OK) fn:PlayStopSpecial
230032.390 wavec waveOutReset(0x3fae4cc) call, caller: PlayStopSpecial
230032.390 wavec waveOutReset(0x3fae4cc) => 0 (MMSYSERR_OK), caller: PlayStopSpecial
230032.390 wavec waveOutClose(03fae4cc) call, caller: PlayStopSpecial
230032.390 wavec waveOutClose(0x0) => 0 (MMSYSERR_OK), caller: PlayStopSpecial
230032.390 wavee WOM_DONE(0x3fae4cc, 0x3fb04e0) (callback window message)
230032.390 wavee WOM_DONE(0x3fae4cc, 0x3bd, 0x3b04868, 0x3fb04e0, 0x0) psch
230032.390 fn psch hwo(0x3fae4cc) != hli->hWaveOut(0x0)
230032.390 fn psch lpUserData=0x3f61fc0 : dwPlayId=899869, hli=0x3b04868, iFileIdx=0x0
230032.390 fn psch hli=0x3b04868 : dwPlayId=899869, iPlayListIdxCurr=0x0
230032.390 fn psch clearing watchdog
230032.390 tr fn PlaySoundCallBackHandler calling PostMessage WM_FIRE_PLAY_WDOG_CLEAR_EVENT
230032.390 wavec waveOutUnprepareHeader(0x3fae4cc, 0x3fb04e0, 0x20) call non-unimodem
230032.390 wavec waveOutUnprepareHeader(0x3fae4cc, 0x3fb04e0, 0x20) => 5 (MMSYSERR_INVALHANDLE) non-unimodem
230032.390 fn OnFirePlayPlayWdogClearEvent start
230032.390 ocxev PlayWdogClear(dwLineId=5, dwPlayId=0x55d1754)
230032.390 ocxev PlayEnd(dwLineId=5, dwPlayId=0xdbb1d)
230032.400 ocxfn SilenceDetectSet(sLineId=5, sTimeLen=300, sVolumeLevel=0)
230032.400 ocxfn RecStart(sLineId:5, strFile:c:\mytest.wav)
230032.400 wavec waveInOpen(0x0, 0x0, 0x12e644, 0x2056240, 0x3b04868, 0x1) => 32 (format: 8k16m)
230032.410 wavec waveInOpen(0x0, 0x0, 0x12e644, 0x2056240, 0x3b04868, 0x5) => 32 (format: 8k16m, using WAVE_MAPPED)
230032.410 wavec waveInOpen(0x0, 0x0, 0x12e66c, 0x2056240, 0x3b04868, 0x1) => 0 (format: 11k8m)
230032.410 wavec waveInOpen(0x3b11a08, 0x0, 0x12e66c, 0x1085c, 0x3b04868, 0x10000) => 0
230032.410 wavec waveInPrepareHeader(0x3fae4cc, 0x3faa5a0, 0x20) => 0
230032.410 wavec waveInAddBuffer(0x3fae4cc, 0x3faa5a0, 0x20) => 0
230032.410 wavec waveInPrepareHeader(0x3fae4cc, 0x3fb04e0, 0x20) => 0
230032.410 wavec waveInAddBuffer(0x3fae4cc, 0x3fb04e0, 0x20) => 0
230032.410 rec WriteRiffChunk datasize=0
230032.410 wavec waveInStart(0x3fae4cc) => 0 (MMSYSERR_OK)
230032.410 linec lineMonitorTones(0x100cc, 0x12e694, 1) => 0x0
230034.012 wavee WAVE_WIM_DONE(0x3fae4cc, 0x3faa5a0)
230034.012 wavec waveInUnprepareHeader(0x3fae4cc, 0x3faa5a0, 0x20) => 0 (MMSYSERR_OK), bytes in buff:16000
230034.012 wavec waveInPrepareHeader(0x3fae4cc, 0x3faa5a0, 0x20) => 0
230034.012 wavec waveInAddBuffer(0x3fae4cc, 0x3faa5a0, 0x20) => 0
230034.814 dlgc cst_hdlr start
230034.814 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230034.814 dlgc Unknown CST Event (3) Received on dxxxB1C1
230035.174 dlgc cst_hdlr start
230035.174 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230035.174 dlgc Unknown CST Event (2) Received on dxxxB1C1
230035.294 dlgc cst_hdlr start
230035.294 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230035.294 dlgc Unknown CST Event (3) Received on dxxxB1C1
230035.515 wavee WAVE_WIM_DONE(0x3fae4cc, 0x3fb04e0)
230035.515 wavec waveInUnprepareHeader(0x3fae4cc, 0x3fb04e0, 0x20) => 0 (MMSYSERR_OK), bytes in buff:16000
230035.515 wavec waveInPrepareHeader(0x3fae4cc, 0x3fb04e0, 0x20) => 0
230035.515 wavec waveInAddBuffer(0x3fae4cc, 0x3fb04e0, 0x20) => 0
230035.695 dlgc cst_hdlr start
230035.695 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230035.695 dlgc Unknown CST Event (2) Received on dxxxB1C1
230036.326 dlgc cst_hdlr start
230036.326 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230036.326 dlgc Unknown CST Event (3) Received on dxxxB1C1
230036.386 dlgc cst_hdlr start
230036.386 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230036.386 dlgc Unknown CST Event (2) Received on dxxxB1C1
230036.846 dlgc cst_hdlr start
230036.846 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230036.846 dlgc Unknown CST Event (3) Received on dxxxB1C1
230036.927 dlgc cst_hdlr start
230036.927 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230036.927 dlgc Unknown CST Event (2) Received on dxxxB1C1
230036.997 wavee WAVE_WIM_DONE(0x3fae4cc, 0x3faa5a0)
230036.997 wavec waveInUnprepareHeader(0x3fae4cc, 0x3faa5a0, 0x20) => 0 (MMSYSERR_OK), bytes in buff:16000
230036.997 wavec waveInPrepareHeader(0x3fae4cc, 0x3faa5a0, 0x20) => 0
230036.997 wavec waveInAddBuffer(0x3fae4cc, 0x3faa5a0, 0x20) => 0
230037.097 dlgc cst_hdlr start
230037.097 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230037.097 dlgc Unknown CST Event (3) Received on dxxxB1C1
230037.537 dlgc cst_hdlr start
230037.537 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230037.537 dlgc Unknown CST Event (2) Received on dxxxB1C1
230037.708 dlgc cst_hdlr start
230037.708 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230037.708 dlgc Unknown CST Event (3) Received on dxxxB1C1
230038.178 dlgc cst_hdlr start
230038.178 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230038.178 dlgc Unknown CST Event (2) Received on dxxxB1C1
230038.279 dlgc cst_hdlr start
230038.289 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230038.289 dlgc Unknown CST Event (3) Received on dxxxB1C1
230038.449 dlgc cst_hdlr start
230038.449 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230038.449 dlgc Unknown CST Event (2) Received on dxxxB1C1
230038.489 wavee WAVE_WIM_DONE(0x3fae4cc, 0x3fb04e0)
230038.489 wavec waveInUnprepareHeader(0x3fae4cc, 0x3fb04e0, 0x20) => 0 (MMSYSERR_OK), bytes in buff:16000
230038.489 wavec waveInPrepareHeader(0x3fae4cc, 0x3fb04e0, 0x20) => 0
230038.489 wavec waveInAddBuffer(0x3fae4cc, 0x3fb04e0, 0x20) => 0
230038.569 dlgc cst_hdlr start
230038.569 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230038.569 dlgc Unknown CST Event (3) Received on dxxxB1C1
230038.719 dlgc cst_hdlr start
230038.719 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230038.719 dlgc Unknown CST Event (2) Received on dxxxB1C1
230038.809 dlgc cst_hdlr start
230038.809 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230038.809 dlgc Unknown CST Event (3) Received on dxxxB1C1
230039.470 dlgc cst_hdlr start
230039.470 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230039.470 dlgc Unknown CST Event (2) Received on dxxxB1C1
230039.550 dlgc cst_hdlr start
230039.560 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230039.560 dlgc Unknown CST Event (3) Received on dxxxB1C1
230039.891 dlgc cst_hdlr start
230039.891 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230039.891 dlgc Unknown CST Event (2) Received on dxxxB1C1
230039.961 dlgc cst_hdlr start
230039.961 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230039.961 dlgc Unknown CST Event (3) Received on dxxxB1C1
230039.971 wavee WAVE_WIM_DONE(0x3fae4cc, 0x3faa5a0)
230039.971 wavec waveInUnprepareHeader(0x3fae4cc, 0x3faa5a0, 0x20) => 0 (MMSYSERR_OK), bytes in buff:16000
230039.971 wavec waveInPrepareHeader(0x3fae4cc, 0x3faa5a0, 0x20) => 0
230039.971 wavec waveInAddBuffer(0x3fae4cc, 0x3faa5a0, 0x20) => 0
230040.061 dlgc cst_hdlr start
230040.061 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230040.061 dlgc Unknown CST Event (2) Received on dxxxB1C1
230041.463 wavee WAVE_WIM_DONE(0x3fae4cc, 0x3fb04e0)
230041.463 wavec waveInUnprepareHeader(0x3fae4cc, 0x3fb04e0, 0x20) => 0 (MMSYSERR_OK), bytes in buff:16000
230041.463 wavec waveInPrepareHeader(0x3fae4cc, 0x3fb04e0, 0x20) => 0
230041.463 wavec waveInAddBuffer(0x3fae4cc, 0x3fb04e0, 0x20) => 0
230041.764 dlgc cst_hdlr start
230041.764 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230041.764 dlgc Unknown CST Event (3) Received on dxxxB1C1
230042.214 dlgc cst_hdlr start
230042.224 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230042.224 dlgc Unknown CST Event (2) Received on dxxxB1C1
230042.304 dlgc cst_hdlr start
230042.304 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230042.304 dlgc Unknown CST Event (3) Received on dxxxB1C1
230042.945 wavee WAVE_WIM_DONE(0x3fae4cc, 0x3faa5a0)
230042.945 wavec waveInUnprepareHeader(0x3fae4cc, 0x3faa5a0, 0x20) => 0 (MMSYSERR_OK), bytes in buff:16000
230042.955 wavec waveInPrepareHeader(0x3fae4cc, 0x3faa5a0, 0x20) => 0
230042.955 wavec waveInAddBuffer(0x3fae4cc, 0x3faa5a0, 0x20) => 0
230043.176 dlgc cst_hdlr start
230043.176 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230043.176 dlgc Unknown CST Event (2) Received on dxxxB1C1
230043.246 dlgc cst_hdlr start
230043.256 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230043.256 dlgc Unknown CST Event (3) Received on dxxxB1C1
230043.406 dlgc cst_hdlr start
230043.406 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230043.406 dlgc Unknown CST Event (2) Received on dxxxB1C1
230044.437 wavee WAVE_WIM_DONE(0x3fae4cc, 0x3fb04e0)
230044.437 wavec waveInUnprepareHeader(0x3fae4cc, 0x3fb04e0, 0x20) => 0 (MMSYSERR_OK), bytes in buff:16000
230044.437 wavec waveInPrepareHeader(0x3fae4cc, 0x3fb04e0, 0x20) => 0
230044.437 wavec waveInAddBuffer(0x3fae4cc, 0x3fb04e0, 0x20) => 0
230045.930 wavee WAVE_WIM_DONE(0x3fae4cc, 0x3faa5a0)
230045.930 wavec waveInUnprepareHeader(0x3fae4cc, 0x3faa5a0, 0x20) => 0 (MMSYSERR_OK), bytes in buff:16000
230045.930 wavec waveInPrepareHeader(0x3fae4cc, 0x3faa5a0, 0x20) => 0
230045.930 wavec waveInAddBuffer(0x3fae4cc, 0x3faa5a0, 0x20) => 0
230046.721 dlgc cst_hdlr start
230046.721 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230046.721 dlgc Unknown CST Event (3) Received on dxxxB1C1
230047.101 dlgc cst_hdlr start
230047.101 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230047.101 dlgc Unknown CST Event (2) Received on dxxxB1C1
230047.422 wavee WAVE_WIM_DONE(0x3fae4cc, 0x3fb04e0)
230047.422 wavec waveInUnprepareHeader(0x3fae4cc, 0x3fb04e0, 0x20) => 0 (MMSYSERR_OK), bytes in buff:16000
230047.422 wavec waveInPrepareHeader(0x3fae4cc, 0x3fb04e0, 0x20) => 0
230047.422 wavec waveInAddBuffer(0x3fae4cc, 0x3fb04e0, 0x20) => 0
230047.532 ocxfn RecStop(sLineId:5)
230047.642 dlgc cst_hdlr start
230047.642 dlgc Unknown CST Event (3) Received on dxxxB1C1
230048.173 dlgc cst_hdlr start
230048.173 dlgc Unknown CST Event (2) Received on dxxxB1C1
230048.533 wavec waveInReset(0x3fae4cc) => 0
230048.533 linec lineMonitorTones(0x100cc, 0x0, 1) => 0x0 (disabling monitoring for silence/tones)
230048.533 tapie LINE_UNKNOWN(5, 0x3b04868, 0x3, 0x0, 0x0)
230048.533 wavee WAVE_WIM_DONE(0x3fae4cc, 0x3faa5a0)
230048.533 wavec waveInUnprepareHeader(0x3fae4cc, 0x3faa5a0, 0x20) => 0 (MMSYSERR_OK), bytes in buff:5660
230048.533 wavee WAVE_WIM_DONE(0x3fae4cc, 0x3fb04e0)
230048.533 wavec waveInUnprepareHeader(0x3fae4cc, 0x3fb04e0, 0x20) => 0 (MMSYSERR_OK), bytes in buff:0
230048.533 rec WriteRiffChunk datasize=0
230048.533 wavec waveInClose(0x3fae4cc) => 0 (MMSYSERR_OK)
230048.533 ocxev RecEnd(dwLineId=5, dwRecId=0x0)
230048.553 ocxfn RecStop(sLineId:5)
230048.553 wavec waveInReset(0x0) => 5
230048.553 linec lineMonitorTones(0x100cc, 0x0, 1) => 0x0 (disabling monitoring for silence/tones)
230048.553 ocxfn PlayStop(sLineId=5)
230048.553 fn PlaySoundStop start
230048.553 fn PlaySoundStop line not playing a sound file. 0x0
230048.553 ocxfn LineDrop(sLineId=5, sOpt=0)
230048.563 tapic lineDrop(0x100cc, , 0) call in ocxfn_LineDrop
230048.563 tapic lineDrop(0x100cc, , 0) => async:65706 (65706)
230048.603 tapie LINE_LINEDEVSTATE(5, 0x10155, 0x800, 0x0, 0x0)
230048.603 tapie LINE_CALLSTATE(5, 0x100cc, 0x1, 0x0, 0x0)
230048.653 tapie LINE_REPLY(5, 0x0, 0x100aa, 0x0)
230049.575 ocxfn LineClose(sLineId:5)
230049.585 tapic lineNegotiateAPIVersion(0x800003ff, 5, 0x10003, 0x20001, 0x3b04878, 0x12f1d4)
230049.585 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x3fb0508) call
230049.585 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x3fb0508) => NO_ERROR (0)
230049.585 tapic lineGetIcon(5, 0, 0x3b04880)
230049.585 ocxfn LineOpen(sLineId=5)
230049.585 tapic lineNegotiateAPIVersion(0x800003ff, 5, 0x10003, 0x20001, 0x3b04878, 0x12e99c)
230049.585 tapic lineOpen(0x800003ff, 5, 0x3b04874, 0x10004, 0, 0x3b04868, 0x4, LINEMEDIAMODE_INTERACTIVEVOICE | LINEMEDIAMODE_AUTOMATEDVOICE, 0)
230049.615 tapic lineGetID(0x10099, 0, 0, 0x1, 0x3fe9008, wave/in) LINECALLSELECT_LINE hLineInfo
230049.615 tapic lineGetID(0x10099, 0, 0, 0x1, 0x3fe9008, wave/in) => 0x0
230049.615 tapic lineGetID => 0
230049.615 tapic lineGetID(0x10099, 0, 0, 0x1, 0x3fe9008, wave/out) LINECALLSELECT_LINE hLineInfo
230049.625 tapic lineGetID(0x10099, 0, 0, 0x1, 0x3fe9008, wave/out) => 0x0
230049.625 tapic lineGetID => 0
230049.625 ocxfn GetLineName(sLineId=5)
230049.625 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x3fb0508) call
230049.625 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x3fb0508) => NO_ERROR (0)
230049.625 wavec waveInGetDevCaps(0x0, 0x12ea00, 0x30) => 0
230049.625 wavec waveOutGetDevCaps(0x0, 0x12e9cc, 0x34) => 0
230049.625 wave IN:Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1 OUT:Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1, support=0x4
230049.625 ocxfn SilenceDetectSet(sLineId=5, sTimeLen=300, sVolumeLevel=0)
Looks like there is a bug in the TAPIWRAP.OCX v1.51.0 when Silence detection level is set to 0.
To fix you can either:
1. set silence detection level to a value other the 0, or
2. replace TAPIWRAP.OCX with the attached one.
To replace OCX open up a DOS Command window and :
1. Go to Windows System 32 directory
2. run regsvr32 -u TapiWrap.ocx
3. copy new TapiWrap.ocx into the System32 directory
4. run regsvr32 TapiWrap.ocx
The attached OCX is for "Dialogic - Analog" type systems only.
Fixed OCX will be part of the v5.1.3 distribution onwards.
TapiWrap.zip
I forgot to reply that this worked great after we installed the files you provided.
Tim
