invoso.com Report post Posted 10/13/2011 09:32 AM Hi, is possible to hide Caller Id in VG or configuring DIALOGIC card in outbound connection? I'm using D/600 JCT Share this post Link to post
SupportTeam Report post Posted 10/13/2011 01:05 PM You can set the CallerID on outgoing ISDN calls. But it is up to the Telco's Switch that is forwarding on the call to decide what CallerID to set on the following legs of the call, or whether to relay the CallerID tht you sent, or whether it is blocked. You should speak with Telco that supplies the E1 to see what they are willing to allow on these lines. Ask them that if they can set up the switch in such a way that if you set you set the CallerID to a specific number (eg: 0000000000) then they will then signal that CallerID should not be provided to end call recipient. Share this post Link to post
