Guest Ben Harper Report post Posted 11/10/2003 02:55 AM Wav files sound great when recorded. Massive amounts of static occur when played through Voice guide software / dialogic card. Recorded at specified format (11025Hz, 8bit, Mono) sounds great. Have taken a file from \system\voicedlgc and tested this, it also has alot of static. What could it be? Share this post Link to post
SupportTeam Report post Posted 11/10/2003 03:08 AM Don't know... maybe the card itself is faulty... Have you tried running Dialogic's TALKER32 sample app (as per install instructions at http://voiceguide.com/vghelp/html/InstallDialogic.htm ) and listen to the quality of it's playback... you can select it to play different files - Dialogic's own files as well as VoiceGuide's sound files... Share this post Link to post
