clauschmidt Report post Posted 10/28/2011 01:36 PM Hello, In one script we are calling a WebService and getting the return. this call is too slow. is there another way to call a WebService that is faster? The code that we are using is bellow. set vg = CreateObject("vgServices.CommandLink") Set soapClient = CreateObject("MSSOAP.SoapClient30") soapClient.MSSoapInit("http://XXXXXXXXXXXXXX/WS/Functions.asmx?WSDL") par1="$RV[CodAprovacao]" par2="$RV[CodUsuario]" par3="$RV[idlog]" value = soapClient.ValidaInformacoes(par1,par2,par3) set soapClient = Nothing vg.RvSet $RV_LINEID, "value", value value1 = split(value, "|")(0) value2 = split(value, "|")(1) value3 = split(value, "|")(2) strResultVariables = "[ret]{" & value & "}[ret1]{" & value1 & "}[ret2]{" & value2 & "}[ret3]{" & value3 & "}" strResultVariables = replace(strResultVariables, ",", "") vg.Run_ResultReturn $RV_LINEID, strResultVariables vg.Run_ResultReturn $RV_LINEID, "Success" set vg = Nothing Share this post Link to post
SupportTeam Report post Posted 10/28/2011 09:03 PM You can insert some Admin_TraceLogAdd entries though out the script to gauge where the delays are. See: http://www.voiceguide.com/vghelp/source/html/com_admin_tracelogadd.htm Admin_TraceLogAdd will add a log entry to the vgEngine trace file. Looking at timestamps of the Admin_TraceLogAdd generated entries you will be able to see fast each portion of the script executes. Most likely the delay is in getting a response from the WebService itself. But if you can post the vgEngine trace excerpt capturing the script being executed we can then better comment on what is going on. suggest you ue code like this: set vg = CreateObject("vgServices.CommandLink") vg.Admin_TraceLogAdd($RV_LINEID, 0, "web service script started") Set soapClient = CreateObject("MSSOAP.SoapClient30") vg.Admin_TraceLogAdd($RV_LINEID, 0, "web service script soapClient object created") soapClient.MSSoapInit("http://XXXXXXXXXXXXX...tions.asmx?WSDL") vg.Admin_TraceLogAdd($RV_LINEID, 0, "web service script soapClient object initialised") par1="$RV[CodAprovacao]" par2="$RV[CodUsuario]" par3="$RV[idlog]" vg.Admin_TraceLogAdd($RV_LINEID, 0, "web service script soapClient object ValidaInformacoes call") value = soapClient.ValidaInformacoes(par1,par2,par3) vg.Admin_TraceLogAdd($RV_LINEID, 0, "web service script soapClient object ValidaInformacoes returned") set soapClient = Nothing vg.RvSet $RV_LINEID, "value", value value1 = split(value, "|")(0) value2 = split(value, "|")(1) value3 = split(value, "|")(2) strResultVariables = "[ret]{" & value & "}[ret1]{" & value1 & "}[ret2]{" & value2 & "}[ret3]{" & value3 & "}" strResultVariables = replace(strResultVariables, ",", "") vg.Run_ResultReturn $RV_LINEID, strResultVariables set vg = Nothing Please note that we removed the: vg.Run_ResultReturn $RV_LINEID, "Success" You should only call Run_ResultReturn once in your script. Calling it with a returned RV list already counts as as success. Calling Run_ResultReturn again can adversely affect the VoiceGuide script the has resumed execution as soon as the first Run_ResultReturn was called. Share this post Link to post
