Guest RobG Report post Posted 02/24/2003 07:37 PM My script calls the VoiceMail script to record a message. On Return it should play another voice module. Instead I get an error that says I should check the format of the file. The format is correct for my situation (8000, 16-bit, mono). I believe the error is shown in the log as err=[7]: 11948 0 Play Start line[0] err=[7] file[C:\Documents and Settings\Robert\My Documents\Sound Files\Option3B.wav] How do I determine the meaning of err=[7]? Here is the pertinate part of the error log: 06340 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav] 06350 0 TimeoutClear 06360 0 wa(428,60629000) 06781 0 Play End line[0] (id=606290) 06781 0 LsVmLm_PlayWelc_Beep EV_PLAY_FINISHED 06811 0 RecSoundStart file[C:\Program Files\VoiceGuide\data\VmSave<!--POST BOX-->01_0224141801_1_0_.wav] ok 06811 0 TimeoutSet 60 EV_TIMEOUT_RECMAXTIME 06821 0 [0001] Recording Message 11858 0 tapie monitordigits 48 2 11868 0 LsVmLm_Rec [0] 11868 0 TimeoutSet 2 EV_REC_FINISHED 11878 0 RecSoundStopTruncBytes ok 11898 0 LsVmLm_Rec EV_REC_FINISHED 11898 0 TimeoutClear 11908 0 TimeoutClear 11918 0 [Name/Addr Verification] Playing 11918 0 [Name/Addr Verification] Playing (C:\Documents and Settings\Robert\My Documents\Sound Files\Option3B.wav) 11948 0 Play Start line[0] err=[7] file[C:\Documents and Settings\Robert\My Documents\Sound Files\Option3B.wav] 12199 0 TimeoutClear 12199 0 RunModule PLAY end 12209 0 wa(4401,61192800) 15624 0 tapie monitordigits 57 2 15634 0 LsPlayMsg [9] 16605 0 Play End line[0] (id=611928) 16615 0 LsPlayMsg EV_PLAY_FINISHED 16615 0 TimeoutSet 10 EV_TIMEOUT_HANGUP 16625 0 TimeoutSet 10 EV_TIMEOUT_HANGUP 26549 0 Timer fired 0, 9001 26559 0 LsPlayMsgFinished EV_TIMEOUT_HANGUP 26559 0 PlaySoundStop ok 26569 0 Hanging up call... 26569 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 26579 0 PlaySoundStop ok 26579 0 HangupCall lineDrop(0, 0) =>5 (5) 26589 0 fnHangupCall end Share this post Link to post
SupportTeam Report post Posted 02/24/2003 11:19 PM Which version of VoiceGuide are you using? An older version of VoiceGuide did have a bug when returning from Voicemail system back to script - please upgrade to current version and see if this fixes your issue. You will need to unustall your current verson and download and install the full intall from our WWW. (any registration codes will still work) BTW: did you insert: <!--POST BOX--> in the trace or was it there already? Share this post Link to post
Guest Guest Report post Posted 02/25/2003 05:46 AM Downloaded latest version and it worked ok. (Just did an install, not an uninstall/install... Do think that was big mistake?). The <!--POST BOX--> was in the trace, I did not add anything to the trace output. Share this post Link to post
SupportTeam Report post Posted 02/25/2003 10:03 AM In principle we recommend uninstalling first before installing a new version, but we have not come across problems when just installing a new version over the previous one. Glad to hear its all working ok for you now... Share this post Link to post
