Guest cechov Report post Posted 11/12/2003 05:52 PM Hi all, VG give me this log file. As you can see, it doesn't find the path {silence} and so hang up early. Have you any ideas? Tnx. 184843,05 6 linedevstate 2048 0 0 184843,06 6 callstate OFFERING 66287 0 4 184843,08 6 callinfo CALLEDID 184843,08 6 callinfo ORIGIN 184843,08 6 ring 0 184849,08 6 ring 2 184849,08 6 Answer the call at 12/11/2003 18.48.49 184849,08 6 lineAnswer(66287) => 66288 184849,61 6 callstate CONNECTED 66287,1,0 184849,62 6 WorkingModeTAPI@Connected= 184849,62 6 WorkingModeScript@Connected= 184849,65 6 Inband detection not enabled 184849,66 6 StartLoadedVgs at 12/11/2003 18.48.49 184849,66 6 tapi Reply (LineEvReply) ok 66288 0 184849,66 6 [Record 16] Recording 184849,70 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav] 184849,93 6 wb(64996200) 184849,98 6 Play End line[6] (id=649962) 184849,98 6 LsRecPlayBeep EV_PLAY_FINISHED 184849,00 6 RecSoundStart file[C:\prova.wav] ok 184850,01 6 RecFile[C:\prova.wav] 184857,71 6 monitortone 1 184857,71 6 LsRecRecording EV_SILENCE_DETECTED 184857,72 6 Silence Detected while recording. 184857,77 6 Record 16_RecLen100ms = 47 184857,78 6 path {silence} not found 184857,78 6 Hanging up call... [{silence} path not defined] 184857,79 6 RecSoundStop ok 184857,79 6 PlaySoundStop ok 184857,80 6 fnHangupCall end 184857,84 6 linedevstate 2048 0 0 184857,84 6 callstate IDLE 66287 0 0 184857,85 6 WorkingMode@Idle= 184857,98 6 tapi Reply (LineEvReply) ok 66253 0 184858,89 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 184858,89 6 ReinitTelephony due to IDLE start 184858,90 6 tapic lineDeallocateCall(MainCall:66287) 0 184859,06 6 lineOpen(6) => 0 184859,07 6 Waiting for a call... 184859,07 6 lineOpen(6)LineHandle=66270 184910,60 0 sys cleanup Start 184910,60 0 sys cleanup End Share this post Link to post
Guest Guest Report post Posted 11/12/2003 06:57 PM Don't look up...I solved the problem....now i have new one!! i run this VB Script after using the recording module dim Conn, rs, ado_stream set Conn=CreateObject("ADODB.Connection") Conn.ConnectionString="driver={SQL server};server=SRVName" Conn.Open() Conn.Defaultdatabase="dbName" filename="$RV[Record]" set rs = CreateObject ("ADODB.recordset") set ado_stream = createObject("ADODB.Stream") ado_stream.Type = 1 ado_stream.Open() ado_stream.LoadFromFile(filename) rs.LockType = 3 rs.Open "select top 0 * from table", Conn rs.AddNew "wavFile", ado_stream.Read() ado_stream.Close() rs.Close() conn.close() The script run...the new record is inserted but the path of the VB module is failed...why? Thanks a lot... Share this post Link to post
SupportTeam Report post Posted 11/12/2003 11:01 PM To take the "Success" path a result must be returned to VoiceGuide. Please see the COM interface function Run_ResultReturn. From VG Help file's section on VB Script module: Quote VB Script can send responses back to VoiceGuide while it is executing by calling one VoiceGuide's ActiveX/COM functions. The functions which are considered to return a result back to VoiceGuide are: Run_ResultReturn(), Script_Gosub(), Script_Goto(), Script_Return(). For more information on VoiceGuide's ActiveX/COM interface please see the COM Interface section of Help file. Once VoiceGuide detects that a VB Script has completed (and no COM response was received beforehand) then VoiceGuide will see if a "Result File" has been created by the script. If one has been created then VoiceGuide will read in it's contents and then determine what to do next based on the contents of the file. The syntax of the Result File is the same as that used by the Run Program module. The Result Files must be placed in VoiceGuide's data subdirectory. Please refer to the Run Program module Help file's section for more information. If the 'Wait until VB Script completes' option is selected, and no result file is created then the "Fail" path is taken after the VB script completes. ie: if the 'Wait until VB Script completes' option is selected then an explicit "Success" result must be returned to VoiceGuide in order for it to go down the Success path. Share this post Link to post
