Guest DiegoBellini Report post Posted 01/24/2012 06:32 PM I can make transfers of calls to a numbers that are out of the PBX of the 4 telephone lines connecting the IVR? I should indicate that the number to call + the extension. How I specify that information in the transfer calls module? Thanks Share this post Link to post
SupportTeam Report post Posted 01/24/2012 08:56 PM Are you able to make such transfers yourself manually? If yes, then just specify in the transfer module the same sequence of codes/numbers that you press manually. Share this post Link to post
