Queue Calls
I want to be able to have a VBS in voiceguide that sets the next call for say a couple of days time..
I see your example and wanted to use the results variables from voiceguide to generate the date of the next call.... i have tried to use in 2 ways as a trial but neither way works...
first way i tried was simply getting an varialbe from my database called 'NextCall' but this gave me an error....
vg.Dialer_OutDialQueAdd "661180060", "$RV[NextCall_1_1]" , 930, 2030, "MOTUWETHFR", " ",
"c:\sendinfo\InfoMenu.vgs", "c:\sendinfo\CallBackDetails.wav", " ","60", 10, 60
set vg = Nothing
I also tried to set the date using the following but this does not work either.
3
$RV_MM
$RV_DD
0930
Please can you let me know how i can add multiple or just one results variables to this VB script please.
Matt
The "$RV[NextCall_1_1]" approach looks fine, but why is there an empty line in the middle of the Dialer_OutDialQueAdd function call? Maybe that's the cause of the error...
Also in v5.1 another parameter (sOnNotConnected) was added - so the function call should look like this:
vg.Dialer_OutDialQueAdd "661180060", "$RV[NextCall_1_1]" , 930, 2030, "MOTUWETHFR", " ", "c:\sendinfo\InfoMenu.vgs", "c:\sendinfo\CallBackDetails.wav", " ","60", 10, 60, ""
I tried your method and got the same error message please help
Line 2 Char 1
Type mismatch 'vg.Dialer_OutDialQueAdd'
Code 800AOOOD
Source: Microsoft VBScript Runtime error.
