Presales
I STARTED WITH VG 4.9 TRIAL VER.
THE CALLER ID WORKED OK
I INSTALLED VG 5.1.3011 AND CALLER ID NOLONGER WORKS
USING ZOOM V.92 PCI 3025
Q2
IF I PURCHASE CAN I MOVE FROM 4.9 TO 5.1 AND 5.1 TO 4.9
Q3
ARE UPGRADES INCLUDED FOR 1st YEAR
THANK YOU
The way in which VoiceGuide receives Caller ID info from modem/card has not changed between 4.9 and 5.1 so I'm not too sure why it would not work,
Could you please send us a copy of VoiceGuide's Debug Printout from v5.1 which captures an incoming call, this will allow us to see what is going wrong.
If you purchase now we can supply both v4.9 and v5.1 registration keys if you wish.
Point upgrades within the same major version are free and any versions which fix bugs in the version that you have purchased are free.
