Sql Query Results Direct Into $Rv?
Is possible to get sql query results direct to $RV?
I get sql query results and in next step I assigning evaluate expression module assigning to Variable.
Example:
SQL query:
SELECT typ_dzialania as akcja FROM infolinia_podstawowe WHERE id_projektu=$RV[iD_projektu]
215541.375 23 2 1 rv add [action type_akcja]{0}
215541.375 23 d added action type_akcja | 0 | ( 61 63 74 69 6f 6e 20 74 79 70 65 5f 61 6b 63 6a 61 | 30 | 45) id=2
215541.375 23 d added action type_akcja | 0 | ( 61 63 74 69 6f 6e 20 74 79 70 65 5f 61 6b 63 6a 61 | 30 | 75) id=2
215541.375 23 2 1 rv add [action type_1]{0}
215541.375 23 d added action type_1 | 0 | ( 61 63 74 69 6f 6e 20 74 79 70 65 5f 31 | 30 | 46) id=2
215541.375 23 d added action type_1 | 0 | ( 61 63 74 69 6f 6e 20 74 79 70 65 5f 31 | 30 | 76) id=2
215541.375 23 2 1 rv add [action type_akcja_1]{0}
215541.375 23 d added action type_akcja_1 | 0 | ( 61 63 74 69 6f 6e 20 74 79 70 65 5f 61 6b 63 6a 61 5f 31 | 30 | 47) id=2
215541.375 23 d added action type_akcja_1 | 0 | ( 61 63 74 69 6f 6e 20 74 79 70 65 5f 61 6b 63 6a 61 5f 31 | 30 | 77) id=2
215541.375 23 2 1 rv add [action type_1_1]{0}
215541.375 23 d added action type_1_1 | 0 | ( 61 63 74 69 6f 6e 20 74 79 70 65 5f 31 5f 31 | 30 | 48) id=2
215541.375 23 d added action type_1_1 | 0 | ( 61 63 74 69 6f 6e 20 74 79 70 65 5f 31 5f 31 | 30 | 78) id=2
215541.375 23 2 1 rv add [action type_RowCount]{1}
215541.375 23 d added action type_RowCount | 1 | ( 61 63 74 69 6f 6e 20 74 79 70 65 5f 52 6f 77 43 6f 75 6e 74 | 31 | 49) id=2
215541.375 23 d added action type_RowCount | 1 | ( 61 63 74 69 6f 6e 20 74 79 70 65 5f 52 6f 77 43 6f 75 6e 74 | 31 | 79) id=2
$RV[action type_akcja] or $RV[action type_1] I need as $RV[akcja_1]
It helps to find data without remember position of data in sql query results.
The Database Query module does automatically save the retrieved information as Result Variables (RVs). As you show yourself in the posted example, the Database Query module created the following RVs:
$RV[action type_RowCount]
$RV[action type_akcja_1]
$RV[action type_1]
$RV[action type_1_1]
the name of the automatically created $RVs are always prefixed with the name of the module which created the RVs.
So you can use this $RV later in the script:
or use this one:
the _1 suffix in the above RV just means that this is for the first row returned. This is done in case multiple rows are returned by the query.
If you want to store the data in $RV with another name then you will need to create this new $RV yourself.
This can be done using an Evluate Expression module (as it looks like you are doing now), or from a 'Run VBScript' module.
An Evluate Expression type module is the quicker option.
