invoso.com Report post Posted 02/27/2012 03:15 PM I'm using external tts program and want to know file is created. 133742.457 24 10 4 timer EV_TIMEOUT_CHECKONSTATE 133742.457 24 10 4 q scr add evScriptEvent 9007 EV_TIMEOUT_CHECKONSTATE 133742.457 6 10 4 q scr run evScriptEvent sCode=[EV_TIMEOUT_CHECKONSTATE] iActionID=0, crn=0[0|0|0|0|0][|||||] 133742.457 6 10 4 scriptevent EV_TIMEOUT_CHECKONSTATE 0|0|0 || 133742.457 6 10 4 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE lCode2Str=EV_TIMEOUT_CHECKONSTATE 133742.457 6 10 4 Process.HasExited error when test (Proces zakończył się, więc żądane informacje nie są dostępne.). Assume completed. 133742.457 6 10 4 task completed. vgm=460, iRunWait=1, iRunWait_ExeResult_NextVgm=0=[] 133742.457 6 10 4 ExeResult_NextVgm has not been set. check for Result file. 133742.457 6 10 4 no result file returned from program (VGRUNRESULT_10.TXT).C:\IVO\ivonacmd.exe -l -0 -t "$RV[wartosc0]" c:\komunikaty\$RV[session_id].wav 133742.457 6 10 4 FindNextVgmTitleInPathList: next module title is=[Play 119] So no success option is used, only fail. How to get information that process is finished and file exist (without prompt "file is not found")? How to check file existing? Share this post Link to post
SupportTeam Report post Posted 02/28/2012 05:04 AM Looks like you are running this command: C:\IVO\ivonacmd.exe -l -0 -t "$RV[wartosc0]" c:\komunikaty\$RV[session_id].wav and would like to know when process is finished? The only way that a Run Program module will take a success path is if the ran program creates a "result file" or one of VoiceGuide's APIs is called (eg: Run_ResultReturned) If the program that you run does neither then the fail path will always be taken. How to check file existing? You may want to run a batch file which does the ivonacmd.exe call, and then checks for existence of file, and creates a "result file" indicating whether the task succeeded (file exists) or failed (file does not exist). eg. a batch file would look something like this: set outfile=c:\komunikaty\%2.wav C:\IVO\ivonacmd.exe -l -0 -t "%3" %outfile% IF EXIST %outfile% GOTO ItExists set ResultReturned=fail goto WriteResultFile :ItExists set ResultReturned=success :WriteResultFile ECHO %ResultReturned% >> "C:\MyScript\VGRUNRESULT_%1.TXT" and be called like this from the Run Program module: mybatch.bat $RV_LINEID $RV[session_id] $RV[wartosc0] Share this post Link to post
