Script_Goto API issues
I have the same problem in another script/module, and in this case there is no intervention of lib_num2wav.vbs file. The module has 4 options as output Path. In case 1 and 4 do it correctly, but for case 2 and 3 forwards me the beginning of the script.
logs.zip
The call to Script_Goto API function has the parameters in wrong places.
Your VBScript is:
Select Case $RV[PayByPhoneMenu]
Case 2
	vg.RvSet $RV_LINEID,"Description","Pago por Telefono"
   	        vg.Script_Goto $RV_LINEID,"","PayByPhone.vgs","CodigoAPagar"
Case 3
   	        vg.RvSet $RV_LINEID,"Description","Pago por Telefono Programado"
   	        vg.Script_Goto $RV_LINEID,"","SchedulePayByPhone.vgs","SetDate"
End Select
Set vg = Nothing
WScript.Quit
see the syntax as per documentation:
http://www.voiceguide.com/vghelp/source/html/com_script_goto.htm
The line:
should be:
vg.Script_Goto $RV_LINEID,"PayByPhone.vgs","CodigoAPagar",""
and line:
should be:
vg.Script_Goto $RV_LINEID,"SchedulePayByPhone.vgs","SetDate",""
as this is an unrelated issue the post will be slit out into separate topic.
