Guest Tom Storey Report post Posted 11/19/2003 10:04 PM I'm using 5.1.3305 now and when I opened the event trace log window it started printing the following error: 162759.66 0 ERROR 5.1.3305 DialListDbFindDueCall [Too few parameters. Expected 2.] 162759.66 0 ERROR 5.1.3305 DialListDbFindDueCall [Object variable or With block variable not set] How do I stop this? Also when I check the "to save" box and exit the window it does not save. Share this post Link to post
SupportTeam Report post Posted 11/19/2003 11:55 PM Delete the file OutDialQue.mdb from VoiceGuide's \data\ subdirectory - the old format file will give the new version of VG these problems. VG will re-create the fle on startup. (It's good idea to install the new version of VG in a new directory.) Also when I check the "to save" box and exit the window it does not save. Which window? Share this post Link to post
