Guest Tim Report post Posted 11/21/2003 09:41 AM Hi. I have used your sample script, where a VBS file collects information from a website, stores it in a text file, and then the text file is read using TTS. eg iRet = WriteResultFile("[diarytext]{" & readWwwText & "}") then play sound file $RV[diarytext] I appear to have reached a limit of this method. If I retrieve too much information from a website, then only the first couple of hundred characters ever get read. Is this a known issue? Is there a work around? I need to be able to play many paragraphs of text using this method. The log file shows that the whole of the text it captured correctly, (all on 1 line, no carriage returns) I have counted the number of characters played and the limit appears to be 1000 characters. Thanks Tim Share this post Link to post
SupportTeam Report post Posted 11/21/2003 09:48 AM v5.1.3 and before have the 1000 character limit for TTS-ed text. This had been changed to be a MB - this change may make it into v5.1.4, but if not it will be in v5.1.5 Share this post Link to post
Guest Tim Report post Posted 11/21/2003 10:08 AM Thanks for the quick reply. How long are we looking? If a fix is due within days then I will do nothing. If it will be more than a couple of weeks I will write my own code to divide longer passages into 1000char chunks. Share this post Link to post
SupportTeam Report post Posted 11/21/2003 11:07 AM I was told about a week.... if it's easy to divide into 1000 char chunks I'd probably do it.... Share this post Link to post
