Callerid Not Available Sometimes In T1 Connection
Dear support,
Our client switched to the new board D/480 JCT as they wanted to use T-1 connection.
Now the problem is that caller ID is only arrived to VoiceGuide when a call is made "within the system."
Most of cases, the callerID (RV_CIDNumber) value is empty.
The Telecom technician said it is avaialble but VoiceGuide is not capturing it because he sees the number in ChannelD. (I attached ChannelD log he sent. You can see the phone number 714393...., but not in the voiceguide log, "0504_1110_vgEngine.txt")
I also attached additional log that has captured one callerID. ("0504_0558_vgEngine_CIDCaptured.txt". the caller ID is ending 3998)
Please let me know what to do in order to see caller ID all the time.
I am not certain at this point if I have to do something on VoiceGuide Configuration, or ask them to check their phone lines.
I attach the VoiceGuide Config file just in case.
Thanks a lot for your great support in advance!
Log_CallerIDIssue.zip
Can you please explain in more detail what do you mean when you say "the call is made "within the system.""
Is the T1 trunk coming from the PBX, and the "within the system" calls are the calls that are made from a PBX extension?
If yes then this would suggest that the CallerID field is correctly read in, but the PBX is not forwarding the CallerID on when external calls are routed over to the T1 trunk.
With what tool/application was the ChannelDLog.txt ISDN trace file made?
Was the trace made on the T1 trunk that is plugged into the Dialogic card (ie. T1 between PBX and Dialogic), or on the T1 between Telco and PBX ?
The VoiceGuide traces show that the CallerID and DNIS values set on incoming calls were changing from call to call, but when CallerID data was supplied in ISDN SETUP message it was read in by VoiceGuide.
090535.986 6 2 1 cid LastCidMessage values [6512663998,,63466]
101018.404 6 2 1 cid LastCidMessage values [,,6179963466]
101054.998 6 2 1 cid LastCidMessage values [,,612816825063466]
110805.726 6 2 1 cid LastCidMessage values [,,63466]
The answer is "YES."
The client said that the trace was made from the PBX box and this log was made by a technician. (I could not ask him what application he used for.)
So, I guess CallerID is forwarded correctly from TemoCo to PBX, but not from PBX to the Dialogic card.
Is there any way that I can prove that the callerID is not made to the Dialogic card in these cases? (i.e. checking logs made by the Dialogic card?)
What would be your suggestion in this case? (I am trying to convince our customer to investigate/trace further signals between the PBX and the dialogic card.)
Thank you very much for your help.
VoiceGuide can tell Dialogic to start doing an ISDN trace report.
Please see: http://www.voiceguide.com/vghelp/source/html/configisdnsetup.htm :
VoiceGuide ISDN Tracing
VoiceGuide can also trace the ISDN D-channel messages. A file titled ktTelControl_TraceSelect.txt needs to be placed in "C:\" with the contents of the file indicating which Dialogic's board D-channel is to be traced. Example contents should be:
isdn_trace_dtiB1
which indicates which interface board should have it's D-channel traced.
VoiceGuide will create the traces in "C:\", with the traces named something like this: isdn_trace_dtiB1_0325_203334.log
Traces can be converted into readable format using Dialogic's ISDTRACE.EXE utility.
The trace is created by Dialogic drivers directly. VoiceGuide plays no part in creating that trace aside from telling Dialogic to start doing it.
The trace usually captures the first few calls after service is started.
Suggest starting a trace and making an external an internal call, and posting the Dialogic ISDN traces along with VoiceGuide's vgEngine and ktTel traces.
After the trace is captured delete the ktTelControl_TraceSelect.txt file and restart the VoiceGuide service, as this ISDN tracing should not be done on live system, its intended use is for testing/verification only.
The previously supplied VoiceGuide traces were showing that the format of CallerID and DNIS values set on incoming calls were changing from call to call, which may indicate that PBX settings that affect the way CallerID and DNIS is forwarded were being worked with as well(?). You may need to speak to customer's PBX administrator regarding this.
I tried to obtain the log from Dialogic by following the instruction you mentioned, but no file was created.
I created "ktTelControl_TraceSelect.txt" in "C:\", stopped both dialogic card and VoiceGuide.
Restarted Dialogic card and VoiceGuide, then called and hung up.
There was no file log file created in "C:\" folder.
What did I do wrong? I attached the TraceSelect.txt file and Config.xml file just in case.
Thanks.
ISDN_TraceNotWorking.zip
Could you please post the ktTel trace file which captures system startup while the ktTelControl_TraceSelect.txt file was present in "C:\" ?
Looks like the ISDN tracing option was for some reason disabled in version that is installed on your system.
Please update system to this version of VoiceGuide:
[old link deleted]
To update please stop VG service and install new version over the top of old one.
Then start the service, place the calls, stop the service and see if the trace file was created in C:\
Please post traces as before.
For reference, here is an example ISDTRACE generated readable trace showing incoming call with CallerID and DNIS
PROTOCOL TYPE : PRI NET5
TRACE START TIME (MM/DD/YYYY) : 5/9/2012, 11:2:52.62
Time Stamp : 5/9/2012, 11:4:40.462
RECEIVE
Command=1 SAPI=0x00
TEI=0x00
0x00 0x00 Information
Dest=0 CR=0x0001
SETUP(0x05)
1: SENDING COMPLETE(0xa1)
1: BEARER CAPABILITY(0x04)
2: IE Length(0x03)
3: 1------- Extension Bit
-00----- Coding Standard
---00000 Info. Transfer Cap.
4: 1------- Extension Bit
-00----- Transfer Mode
---10000 Info. Transfer Rate
5: 1------- Extension Bit
-01----- Layer 1 Indent
---00011 User Info. Layer 1
1: CHANNEL ID(0x18)
2: IE Length(0x03)
-0------ Interface ID Present
--1----- Interface Type
---0---- Spare
----1--- Preferred/Exclusive
-----0-- D-Channel Indicator
------01 Info. Channel Sel.
3.2: 1------- Extension Bit
---0---- Number Map
----0011 Channel/Map Element
-0000001 Channel Number/Slot Map
1: CALLING PARTY NUM(0x6c)
2: IE Length(0x0e)
3: 0------- Extension Bit
-010---- Type Of Number
----0000 Numbering Plan ID
3a: 1------- Extension Bit
-00----- Presentation Indicator
---000-- Spare
------00 Screening Indicator
456456456456 Number Digit(s)
1: CALLED PARTY NUM(0x70)
2: IE Length(0x09)
-010---- Type of Number
----0000 Numbering plan ID
12341234 Number Digit(s)
TRANSMIT
Response=1 SAPI=0x00
TEI=0x00
0x01 0x02 Receive Ready
TRANSMIT
Command=0 SAPI=0x00
TEI=0x00
0x00 0x02 Information
Orig=1 CR=0x8001
CALL PROCEEDING(0x02)
1: CHANNEL ID(0x18)
2: IE Length(0x03)
---0---- Spare
---0---- Number Map
RECEIVE
Response=0 SAPI=0x00
TEI=0x00
Time Stamp : 5/9/2012, 11:4:40.502
TRANSMIT
Command=0 SAPI=0x00
TEI=0x00
0x02 0x02 Information
Orig=1 CR=0x8001
CALL CONNECT(0x07)
RECEIVE
TEI=0x00
0x01 0x04 Receive Ready
RECEIVE
Command=1 SAPI=0x00
TEI=0x00
0x02 0x04 Information
Dest=0 CR=0x0001
CALL CONNECT ACKNOWLEDGE(0x0f)
TRANSMIT
TEI=0x00
Time Stamp : 5/9/2012, 11:4:50.502
RECEIVE
Command=1 SAPI=0x00
TEI=0x00
0x01 0x05 Receive Ready
TRANSMIT
TEI=0x00
Time Stamp : 5/9/2012, 11:4:53.822
RECEIVE
Command=1 SAPI=0x00
TEI=0x00
0x04 0x04 Information
Dest=0 CR=0x0001
CALL DISCONNECT(0x45)
1: CAUSE(0x08)
2: IE Length(0x02)
---0---- Spare
----0010 Location
-0010000 Cause Value
TRANSMIT
TEI=0x00
0x01 0x06 Receive Ready
TRANSMIT
Command=0 SAPI=0x00
TEI=0x00
0x04 0x06 Information
Orig=1 CR=0x8001
RELEASE(0x4d)
Thanks for the new version and the explanation.
I was able to run the patch and obtain the trace file from the dialogic.
Please take a look at the trace files.
You will see two phone numbers in "....170459.res" file and one in "...170625.res" file.
They look a bit different, but the it proves that the Dialogic card is cpaturing callerIDs even calls from outside of the PBX box.
(I could not obtain trace for calls within their system)
I also added VoiceGuide logs as an attachment.
FYI, this Dialogic card is 24 ports, but the VG license they bought is only for 12. (if this matters...)
Please let me know how I can make VoiceGuide detect the callerIDs.
Thanks.
VG_Trace.zip
The ktTel trace posted stops at 17:05:57
Could you please post the ktTel trace excerpt that covers the call made at 17:12:02 (for which we have the vgEngine and Dialogic traces) ?
Thanks for that.
We made some changes to software.
[old link deleted]
Then start the service, place the calls, and stop the service.
Please find the attached logs collected with the new version of VG as instructed.
Two calls were made as before: cid is still empty in the VG log, but the trace shows the caller IDs.
Thanks a lot.
VG_Trace_0510.zip
Are internal calls (calls from extensions on PBX) still result in CallerID being retrieved OK by Dialogic/VoiceGuide?
If yes then can you please make an internal test call (during which the CallerID is retrieved correctly) and post the Dialogic ISDN traces and ktTel traces.
We can then see what is the difference between the way PBX presents the CallerID details on internal and external calls.
Can you please advise the PBX Brand/Model ?
External call ISDN traces look fine, so it is a bit puzzling as to why the Dialogic API responds that it has not received the CallerID number.
Comparison with the traces from internal calls should show up the differences, hence the need to see traces from the working 'internal' calls.
The following next steps are proposed.
1. Make traces of internal calls on current system. Save the the ISDN and VoiceGuide traces as before.
2. Stop VoiceGuide and Dialogic services, exit all Dialogic programs and uninstall Dialogic drivers. Do NOT save Dialogic configuration at uninstall.
3. Restart system
4. Install Dialogic drivers again
5. Restart system.
6. Select NI2 as the ISDN protocol in DCM, and enable Dialogic tracing (see below). If any other changes are made to Dialogic config then please advise of those.
7. Make two calls into system - internal and external.
8. Collect system snapshot by running C:\Program Files\Dialogic\bin\its_sysinfo.cfg
9. Post Snapshot (.ZIPed), Dialogic RTF traces, ISDN traces, and VoiceGuide traces capturing the call.
Dialogic logging can be enabled by editing the file:
C:\Program Files\Dialogic\cfg\RtfConfigWin.xml
Backup RtfConfigWin.xml and then edit it,
setting all the entries to "1" in the sections:
<!-- Global Call Springware ISDN Translation Layer -->
<!-- ISDN Library -->
<!-- ISDN Technology Formatter Library -->
like below:
<Module family="SPWR" name="spwrgcis" state="1" technology="PSTN">
  <MLabel name="APPL" state="1"/>
  <MLabel name="DEBG" state="1"/>
  <MLabel name="INFO" state="1"/>
  <MLabel name="INTF" state="1"/>
  <MLabel name="WARN" state="1"/>
  <MLabel name="EXCE" state="1"/>
  <MLabel name="ERR1" state="1"/>
</Module>
<Module family="SPWR" name="libisdnr4.dll" state="1" technology="media">
  <MLabel name="ERR2" state="1"/>
</Module>
<Module family="SPWR" name="isdnspan" state="1" technology="media">
</Module>
Save modified file.
Issue command:
rtftool reload
after saving the file.
the log files will be saved in C:\Program Files\Dialogic\log\
(sample RTF trace attached that captures incoming call with CallerID number set)
rtf_isdn_incoming.zip
Phew~ that required quite an effort to collect all the requested data.
Please find the attached files: I saved them in separate folders.
The call ending "3433" is the one that shows callerID correctly. (it is from "within the system.")
Calls starting "714..." are outside their organization.
Other calls are called within their organization, but not within the PBX box.
The call by "3433" number was made around 2:41 PM.
I hope you could find a solution for this weired issue this time.
Thanks a lot!
Traces_0511.zip
Thanks for these, we'll look at them now.
Can you advise the PBX Brand/Model ?
I did not change anything but the ISDN protocal during installation as instructed.
One thing that bothered me though is that Windows Device manager did not find the correct driver for the board even after installing the driver, and the driver was marked with yellow exclamation mark. I had to click "update driver" then Windows found and installed it. (Not sure if it was a correct behavior.)
And because of the hardware issue (as I mentioned at the beginning of this thread), the client had to switch the power dial on the board when inserting to the ePCI slot, and Windows event viewer shows the following warning all the time:
"Genload.exe Power Requirement was not met but the user had the power override on, for board in slot0, bus 36, Power Required is 15, and actual power provided is 0"
I am not sure if these will interest you, but I am writing these things for just in case.
Thanks.
It is Windows 2003 Server.
I asked the customer PBX model: I will let you know when available.
There are a couple of differences between the ISDN flags set on the 'internal' and 'external' incoming calls
The 'external' calls (on which the CallerID is NOT read) have:
"Numbering Plan" set to "Private" (1001)
"Screening Indicator" is set to "User Provided Not Screened" (00)
The 'internal' calls (on which the CallerID is read in properly) have
"Numbering Plan" set to "National" (0001)
"Screening Indicator" is set to "Network provided" (11)
Can you please ensure that when the PBX sends the 'external' calls to Dialogic card the "Numbering Plan" is set to "National" (0001).
To make the SETUP messages CALLING PARTY NUM segment the same as on the 'internal' calls, the "Screening Indicator" should be set to "Network provided" (11) on 'external' calls as well, but this probably not necessary.
Extract of SETUP messages arriving into system:
Time Stamp : 5/11/2012, 14:25:58.728
 2:           IE Length(0x0c)
     ----1001 Numbering Plan ID
     ---000-- Spare
     7143932211  Number Digit(s)
 2:           IE Length(0x06)
     ----0001 Numbering plan ID
     63501  Number Digit(s)
Time Stamp : 5/11/2012, 14:29:48.608
 2:           IE Length(0x0c)
     ---000-- Spare
     6516953767  Number Digit(s)
 2:           IE Length(0x06)
     63466  Number Digit(s)
Time Stamp : 5/11/2012, 14:35:16.768
 2:           IE Length(0x07)
     -100---- Type Of Number
     ---000-- Spare
     62255  Number Digit(s)
 2:           IE Length(0x06)
Time Stamp : 5/11/2012, 14:37:23.248
 2:           IE Length(0x0c)
     ---000-- Spare
     7145976558  Number Digit(s)
 2:           IE Length(0x06)
Time Stamp : 5/11/2012, 14:41:38.568
 2:           IE Length(0x0c)
     ----0001 Numbering Plan ID
     ---000-- Spare
     ------11 Screening Indicator
     6512663433  Number Digit(s)
 2:           IE Length(0x06)
 1:           LOW LAYER COMP.(0x7c)
 2:           IE Length(0x03)
     -00----- Coding Stabdard
     ---00010 User Info. Layer 1
Time Stamp : 5/11/2012, 14:55:37.688
 2:           IE Length(0x0c)
     ---000-- Spare
     6517664000  Number Digit(s)
 2:           IE Length(0x06)
Time Stamp : 5/11/2012, 14:55:38.128
 2:           IE Length(0x0c)
     ---000-- Spare
     6517664001  Number Digit(s)
 2:           IE Length(0x06)
Time Stamp : 5/11/2012, 15:0:45.568
 2:           IE Length(0x0c)
     ---000-- Spare
 2:           IE Length(0x06)
Time Stamp : 5/11/2012, 15:1:19.448
 2:           IE Length(0x0c)
     ---000-- Spare
     6517482510  Number Digit(s)
 2:           IE Length(0x06)
VoiceGuide software log extract, showing for which calls Dialogic drivers were able to supply the CallerID number:
142558.718  5348   2 ev    GCEV_OFFERED crn=2800001 (ktTel_SR60 v7.3.1, May 10 2012 11:33:56)  (setting hli->crn for line 2)
142558.718  5348   2       not retrieved: UUI
142558.718  5348   2       not retrieved: ANI
142558.718  5348   2       not retrieved: ORIGINATION_ADDRESS
142558.718  5348   2       not retrieved: CALLNAME
142558.718  5348   2       ani:  orig:  name:  dnis: 63501 dest: 63501
142943.065  5348   2 ev    GCEV_OFFERED crn=280000d (ktTel_SR60 v7.3.1, May 10 2012 11:33:56)  (setting hli->crn for line 2)
142943.065  5348   2       not retrieved: UUI
142943.065  5348   2       not retrieved: ANI
142943.065  5348   2       not retrieved: ORIGINATION_ADDRESS
142943.065  5348   2       not retrieved: CALLNAME
142943.065  5348   2       ani:  orig:  name:  dnis: 63466 dest: 63466
143506.675  5348   2 ev    GCEV_OFFERED crn=280000e (ktTel_SR60 v7.3.1, May 10 2012 11:33:56)  (setting hli->crn for line 2)
143506.675  5348   2       not retrieved: UUI
143506.675  5348   2       not retrieved: ANI
143506.675  5348   2       not retrieved: ORIGINATION_ADDRESS
143506.675  5348   2       not retrieved: CALLNAME
143506.675  5348   2       ani:  orig:  name:  dnis: 63466 dest: 63466
143712.395  5348   2 ev    GCEV_OFFERED crn=280000f (ktTel_SR60 v7.3.1, May 10 2012 11:33:56)  (setting hli->crn for line 2)
143712.395  5348   2       not retrieved: UUI
143712.395  5348   2       not retrieved: ANI
143712.395  5348   2       not retrieved: ORIGINATION_ADDRESS
143712.395  5348   2       not retrieved: CALLNAME
143712.395  5348   2       ani:  orig:  name:  dnis: 63501 dest: 63501
144126.879  5348   2 ev    GCEV_OFFERED crn=2800010 (ktTel_SR60 v7.3.1, May 10 2012 11:33:56)  (setting hli->crn for line 2)
144126.879  5348   2       not retrieved: UUI
144126.879  5348   2       not retrieved: CALLNAME
144126.879  5348   2       ani: 6512663433 orig: 6512663433 name:  dnis: 63466 dest: 63466
145525.480  5348   2 ev    GCEV_OFFERED crn=2800011 (ktTel_SR60 v7.3.1, May 10 2012 11:33:56)  (setting hli->crn for line 2)
145525.496  5348   2       not retrieved: UUI
145525.496  5348   2       not retrieved: ANI
145525.496  5348   2       not retrieved: ORIGINATION_ADDRESS
145525.496  5348   2       not retrieved: CALLNAME
145525.496  5348   2       ani:  orig:  name:  dnis: 63466 dest: 63466
145525.933  5348   4 ev    GCEV_OFFERED crn=2800002 (ktTel_SR60 v7.3.1, May 10 2012 11:33:56)  (setting hli->crn for line 4)
145525.933  5348   4       not retrieved: UUI
145525.933  5348   4       not retrieved: ANI
145525.933  5348   4       not retrieved: ORIGINATION_ADDRESS
145525.933  5348   4       not retrieved: CALLNAME
145525.933  5348   4       ani:  orig:  name:  dnis: 63466 dest: 63466
150033.358  5348   2 ev    GCEV_OFFERED crn=2800012 (ktTel_SR60 v7.3.1, May 10 2012 11:33:56)  (setting hli->crn for line 2)
150033.358  5348   2       not retrieved: UUI
150033.358  5348   2       not retrieved: ANI
150033.358  5348   2       not retrieved: ORIGINATION_ADDRESS
150033.358  5348   2       not retrieved: CALLNAME
150033.358  5348   2       ani:  orig:  name:  dnis: 63466 dest: 63466
150107.216  5348   2 ev    GCEV_OFFERED crn=2800013 (ktTel_SR60 v7.3.1, May 10 2012 11:33:56)  (setting hli->crn for line 2)
150107.216  5348   2       not retrieved: UUI
150107.216  5348   2       not retrieved: ANI
150107.216  5348   2       not retrieved: ORIGINATION_ADDRESS
150107.216  5348   2       not retrieved: CALLNAME
150107.216  5348   2       ani:  orig:  name:  dnis: 63466 dest: 63466
Dialogic RTF log extract, for two calls, first which shows error returned when trying to retrieve CallerID, second that shows CallerID returned OK.
05/11/2012 14:25:58.718   5168        5348 spwrgcis                INTF         gcis                  dtiB1T1   <:::: gcis_GetANI(2, 0x80000001, 0xce1fe10) entry
05/11/2012 14:25:58.718   5168        5348 libisdnr..ll            APPL                   <:::: cc_GetANI(0x80000001, 0xce1fe10) entry
05/11/2012 14:25:58.718   5168        5348 libisdnr..ll            DEBG                   ----- IsdnGetCRNEntry(Crn:0x80000001, lpCallInfo:0xcbd9aec) returns TRUE
05/11/2012 14:25:58.718   5168        5348 libisdnr..ll dtiB1T1    DEBG         dtiB1T1   ----- cc_GetANI(CRN:0x80000001) on LineDev:2
05/11/2012 14:25:58.718   5168        5348 libisdnr..ll dtiB1T1    INFO         dtiB1T1   ----- IsdnSetLastError(LineDev:2, nNewError:0x303) returns success
05/11/2012 14:25:58.718   5168        5348 libisdnr..ll            ERR1         dtiB1T1   ::::> cc_GetANI(Crn:0x80000001) returns 0x303 due to (szNetworkANI[0] == '')
05/11/2012 14:25:58.718   5168        5348 spwrgcis                ERR1         gcis                  dtiB1T1   ::::> gcis_GetANI() returns -1 due to cc_GetANI(0x80000001) failed
05/11/2012 14:25:58.718   5168        5348 gc                      ERR1         gclib                 dtiB1T1   ::::> gc_GetANI(crn:0x2800001h, ani:) - returns:-1
05/11/2012 14:25:58.718   5168        5348 libisdnr..ll            DEBG                   ::::> cc_geterror() returns: 0x303
05/11/2012 14:25:58.718   5168        5348 spwrgcis                DEBG         gcis                  find_cclib_error_index(0x303) returns: 0x76
05/11/2012 14:25:58.718   5168        5348 spwrgcis                INTF         gcis                  gcis_ErrorValue() returns gc_error: 0x303 with cc_error:x89
05/11/2012 14:25:58.718   5168        5348 spwrgcis                INTF         gcis                  gcis_GetCallInfo(0x80000001, 0x107, 0xce1fe74) entry
05/11/2012 14:25:58.718   5168        5348 libisdnr..ll            APPL                   <:::: cc_GetANI(0x80000001, 0xce1fe74) entry
05/11/2012 14:25:58.718   5168        5348 libisdnr..ll            DEBG                   ----- IsdnGetCRNEntry(Crn:0x80000001, lpCallInfo:0xcbd9af0) returns TRUE
05/11/2012 14:25:58.718   5168        5348 spwrgcis                ERR1         gcis                  gcis_GetCallInfo() returns -1 due to cc_GetANI(0x80000001) failed
05/11/2012 14:25:58.718   5168        5348 gc                      ERR1         gclib                           ::::> gc_GetCallInfo(crn:0x2800001h, info_id:263) - returns;-1
05/11/2012 14:25:58.718   5168        5348 spwrgcis                INTF         gcis                  gcis_GetCallInfo(0x80000001, 0x102, 0xce1ffa0) entry
05/11/2012 14:41:26.879   5168        5348 libisdnr..ll            APPL                   <:::: cc_GetANI(0x80000010, 0xce1fe10) entry
05/11/2012 14:41:26.879   5168        5348 libisdnr..ll            DEBG                   ----- IsdnGetCRNEntry(Crn:0x80000010, lpCallInfo:0xcbd9aec) returns TRUE
05/11/2012 14:41:26.879   5168        5348 libisdnr..ll dtiB1T1    DEBG         dtiB1T1   ----- cc_GetANI(CRN:0x80000010) on LineDev:2
05/11/2012 14:41:26.879   5168        5348 libisdnr..ll dtiB1T1    APPL         dtiB1T1   ::::> cc_GetANI(Crn=0x80000010) return 0 (szANI:6512663433)
05/11/2012 14:41:26.879   5168        5348 spwrgcis                INTF         gcis                  dtiB1T1   ::::> gcis_GetANI() returns 0 with ANI:6512663433
05/11/2012 14:41:26.879   5168        5348 spwrgcis                INTF         gcis                  gcis_GetCallInfo(0x80000010, 0x107, 0xce1fe74) entry
05/11/2012 14:41:26.879   5168        5348 libisdnr..ll            APPL                   <:::: cc_GetANI(0x80000010, 0xce1fe74) entry
05/11/2012 14:41:26.879   5168        5348 libisdnr..ll            DEBG                   ----- IsdnGetCRNEntry(Crn:0x80000010, lpCallInfo:0xcbd9af0) returns TRUE
Numbering Plans:
Unknown = 0000
ISDN Numbering Plan E.164 = 1000
Data Numbering Plan X.121 = 1100
Telex Numbering Plan F.69 = 0010
National Numbering Plan = 0001
Private Numbering Plan = 1001
Reserved = 1111
Dialogic sample app gc_basic_call_model can be used as well to verify Dialogic cards reporting of CallerID.
The gc_basic_call_model app can be found in C:\Program Files\Dialogic\demos\basic_call_model
File gc_basic_call_model.cfg needs to be edited before running the demo app.
More instructions on gc_basic_call_model can be found here:
http://www.dialogic.com/~/media/manuals/docs/globalcall_demo_v2.pdf
Our client stated it is not possible to change the "numbering plan" as you have suggested, explaining their system as below. (Please see the quote box for the comment from their telecom technician)
Do you have any other solutions for this issue?
Our client says the signal carries CallerIDs to the Dialogic card, and you say Dialogic card does not provide CallerID to VoiceGuide, and we seemed to get lost here.
Would it also be possible for you to provide a direct communication channel (such as email) to our client as they want to discuss with you directly?
Thank your for your prompt support again.
Ramsey County telecom is using 11 pbx (Siemens cbx) for they telecommunications network.
The system are all integrated into 1 private system the end user can access other user through out the campus with 5digits dialing via of internal Isdn tie line (Cornet). This show the exten and name of the calling party at the called exten. The pbx where the server resides is off a remote pbx using the private network and is routing to the time server the call are being forward on a private network
M 05 SETUP
I 04 BEARER CAPABILITY.......Len= 3
90 Coding Standard...........CCITT
Transfer Capa.....3.1 kHz audio
90 Transfer Mode...........Circuit
Transfer Rate.........64 kbit/s
A2 Layer 1 Protocol..........u-law
I 18 CHANNEL ID..............Len= 3
A9 Indicated Channel.....Exclusive
Channel Selection............B1
Channel Identifier.....Not D-CH
I 1E PROGRESS INDICATOR......Len= 2
8A Coding Standard...........CCITT
Location.Network beyond interwo
rking point
83 Desc:...Orig call addr non-ISDN
I 6C CALLING PARTY NUMBER....Len= 12
29 Type of Address........National
Numbering Plan ID.......Private
80 Presentation Ind........Allowed
Screen Ind....user-not screened
6128168250
I 70 CALLED PARTY NUMBER.....Len= 6
A1 Type of Number..National Number
Numbering Plan ID..........ISDN
63466
Hex:02 01 0A 08 08 02 31 6D 05 04 03
90 90 A2 18 03 A9 83 81 1E 02 8A
83 6C 0C 29 80 36 31 32 38 31 36
38 32 35 30 70 06 A1 36 33 34 36
36
Can you please run Dialoigc's gc_basic_call_model sample application and place two calls into the system - one external and one internal.
(VoiceGuide service would need to be stopped first)
Then please post the gc_basic_call_model applications output.
To enable the ISDN channel it should be sufficient too make this change in the gc_basic_call_model.cfg file :
in this section "For ISDN Protocols" change this:
# For ISDN Protocols
# Board #1
#dtiB1T1          ISDN               In       NONE                 1234567        0
# Board #2
#dtiB2T1          ISDN               Out      NONE                 1234567        0
to this:
# Board #1
# Board #2
ie. just remove the "#" at the beginning of the "dtiB1T1 ..." line.
After placing the call just hang up after a few rings or when call is answered.
As this demo script opens the 1st channel on T1 only then you would need to ensure that calls arrive on the 1st channel. The traces showing previous calls show that it should.
Please post the results and any other questions/comments in this thread, so that all information regarding this issue is in one thread.
I have no problem running the sample application as you requested, but the point is: will it prove that our client's phone system is faulty or abnormal that they should change something?
I need to provide that kind of information in order to convince their Telecom Technicians.
Please let me know what this application is to prove.
I will try to do my homework in the meantime.
Thanks.
Running the Dialogic's own test application will confirm how the CallerID is received by Dialogic card/drivers when the incoming calls (internal and external) are made.
Forgot to mention before that we will also need to see the Dialogic RTF logs capturing the incoming (internal and external) calls while the Dialoigc's gc_basic_call_model sample application is running.
The gc_basic_call_model output and the RTF logs need to be viewed together. When we see those logs we can better see where the fault lies.
I was able to collect log files for an "External" call and post it here first.
I will try to collect files for an "Internal" call when our client is available.
Please let me know if you find anything new from this log.
Thanks.
GCLogs_ExternalCall.zip
We can see that when using Dialogic's gc_basic_call_model demo app the same issue is occurring.
On these 'external' calls where the Numbering Plan is set to 'Private' the Dialogic's drivers are not retrieving the CallerID information from ISDN SETUP message and/or not reporting the CallerID information when asked for it.
This would need to be raised with Dialogic, which is usually done through the card supplier.
As the Dialogic card that is used on this system was not purchased through VoiceGuide, the card supplier needs to be contacted and the issue raised with them.
Once card supplier can demonstrate Dialogic's gc_basic_call_model demo app correctly retrieving/reporting the CallerID information then VoiceGuide software will also be able to receive the CallerID information on those calls.
gc_basic_call_model trace extract:
05/18 15:28:21.338  [MISC]:		 ********* Received a GC event *********
05/18 15:28:21.338  [EVENT]:		 GCEV_OFFERED
05/18 15:28:21.338  [sTATE]:		 GCST_NULL is the current GC call state
05/18 15:28:21.338  [GC_APICALL]: gc_GetCallInfo(crn=0x2800001) Success - called party = 63501
05/18 15:28:21.338  [GC_APICALL]: gc_GetCallInfo(crn=0x2800001) Failure - calling party not available
05/18 15:28:21.338  [GC_APICALL]: gc_AcceptCall(crn=0x2800001, mode=EV_ASYNC) Success
05/18 15:28:21.338  [sTATE]:		 GCST_OFFERED is the new GC call state after processing the event
RTF log entry:
05/18/2012 15:28:21.338   5920        2912 isdnspan                INTF         isdnntfentry          dtiB1T1   <==== NTFI_GetAsyncResults: Calling Formatter Function IsNtf_Recv_WaitCall
05/18/2012 15:28:21.338   5920        2912 isdnspan                INFO         isdnntfentry          dtiB1T1   <---- DevArea Reply: 05 00 36 00 3a 00 03 81 - VarDataSize=272
05/18/2012 15:28:21.338   5920        2912 libisdnr..ll dtiB1T1    INTF         dtiB1T1   <==== IsdnWaitCallReplyHandler(2, 0x169110)
05/18/2012 15:28:21.338   5920        2912 libisdnr..ll            DEBG                   <---- IsdnFillIEData(0x169214, 58, 0x10eff28, 0x16a7c8, 0x824) entry
05/18/2012 15:28:21.338   5920        2912 libisdnr..ll dtiB1T1    DEBG         dtiB1T1   ----- IsdnFillIEData() on LineDev:2
05/18/2012 15:28:21.338   5920        2912 libisdnr..ll dtiB1T1    INFO         dtiB1T1   ----- IsdnFillIEData() with BEARER_CAPABILITY_IE
05/18/2012 15:28:21.338   5920        2912 libisdnr..ll            DEBG                   ----> IsdnCopyChannelIDIE(0x16921b, 0x16a7c8) returns
05/18/2012 15:28:21.338   5920        2912 libisdnr..ll dtiB1T1    INFO         dtiB1T1   ----- IsdnFillIEData() with CHANNEL_ID_IE
05/18/2012 15:28:21.338   5920        2912 libisdnr..ll            DEBG                   ----- IsdnCopyCalledNumberIE(0x169221, 0x16a7c8), ie_len:5
05/18/2012 15:28:21.338   5920        2912 libisdnr..ll dtiB1T1    INFO         dtiB1T1   ----- IsdnFillIEData() with CALLED_NUMBER_IE
05/18/2012 15:28:21.338   5920        2912 libisdnr..ll dtiB1T1    INFO         dtiB1T1   ----- IsdnFillIEData() - nNumIEs = 0,nTotalLength=36
05/18/2012 15:28:21.338   5920        2912 libisdnr..ll dtiB1T1    DEBG         dtiB1T1   ----- IsdnFillIEData() - lpIE_BLK->length=36
05/18/2012 15:28:21.338   5920        2912 libisdnr..ll dtiB1T1    DEBG         dtiB1T1   ----> IsdnFillIEData(LineDev:2) returns new event:0x824
05/18/2012 15:28:21.338   5920        2912 spwrgcis                DEBG         gcis_internal         dtiB1T1   <==== gcis_ProcessGCEvent(2, 0x824, 21, 0x10eff28, 0x0) entry
05/18/2012 15:28:21.338   5920        2912 spwrgcis                INFO         gcis_internal         dtiB1T1   ----- Sending GCEV_DETECTED before CCEV_OFFERED
05/18/2012 15:28:21.338   5920        2912 spwrgcis                INFO         gcis_internal         dtiB1T1   ----- Processed CCEV_OFFERED
05/18/2012 15:28:21.338   5920        2912 spwrgcis                DEBG         gcis_internal         dtiB1T1   ----- CC event:0x824 mapping to GC event:GCEV_OFFERED(0x824)
05/18/2012 15:28:21.338   5920        2912 spwrgcis                DEBG         gcis_internal         dtiB1T1   ----- Sending event:GCEV_OFFERED(0x824)
05/18/2012 15:28:21.338   5920        2912 spwrgcis                DEBG         gcis_internal         dtiB1T1   ====> gcis_ProcessGCEvent() returns 0
05/18/2012 15:28:21.338   5920        2912 libisdnr..ll dtiB1T1    DEBG         dtiB1T1   ====> IsdnWaitCallReplyHandler(LineDev:2, Crn:0x80000001) posts event:0x824(CCEV_OFFERED, EDT_SUCC) in (dwErrorCode=0) and (CW_Flag=FALSE)
05/18/2012 15:28:21.338   5920        2912 libisdnr..ll dtiB1T1    DEBG         dtiB1T1   ====> IsdnWaitCallReplyHandler(LineDev:2, Crn:0x80000001) returns.
05/18/2012 15:28:21.338   5920        5700 spwrgcis                INTF         gcis                  gcis_GetCRN(0x12ec88, 0x2f6f2b0) entry
05/18/2012 15:28:21.338   5920        5700 libisdnr..ll            APPL                   <:::: cc_GetCRN(0x12ec88, 0x2f6f2b0) entry
05/18/2012 15:28:21.338   5920        5700 libisdnr..ll            APPL                   ::::> cc_GetCRN(*Crn=0x80000001) return 0
05/18/2012 15:28:21.338   5920        5700 spwrgcis                INTF         gcis                  gcis_GetCRN() returns 0 with *crn:0x80000001
05/18/2012 15:28:21.338   5920        5700 spwrgcis                INTF         gcis                  dtiB1T1   <:::: gcis_GetUsrAttr(2, 0x12ecc4) entry
05/18/2012 15:28:21.338   5920        5700 libisdnr..ll dtiB1T1    APPL         dtiB1T1   <:::: cc_GetUsrAttr(2, 0x12ec48)
05/18/2012 15:28:21.338   5920        5700 libisdnr..ll dtiB1T1    APPL         dtiB1T1   ::::> cc_GetUsrAttr(LineDev:2) return 0
05/18/2012 15:28:21.338   5920        5700 spwrgcis                INTF         gcis                  dtiB1T1   ::::> gcis_GetUsrAttr() returns 0
05/18/2012 15:28:21.338   5920        5700 spwrgcis                INTF         gcis                  gcis_GetExtEvtDatap(0x12ec60, 0x2f6f2b0) returns 0 with *extEvtDatap:0x0
05/18/2012 15:28:21.338   5920        5700 spwrgcis                INTF         gcis                  gcis_GetCallInfo(0x80000001, 0x108, 0x12dfa8) entry
05/18/2012 15:28:21.338   5920        5700 libisdnr..ll            APPL                   <:::: cc_GetDNIS(0x80000001, 0x12dfa8) entry
05/18/2012 15:28:21.338   5920        5700 libisdnr..ll            DEBG                   ----- IsdnGetCRNEntry(Crn:0x80000001, lpCallInfo:0x12dec0) returns TRUE
05/18/2012 15:28:21.338   5920        5700 libisdnr..ll dtiB1T1    DEBG         dtiB1T1   ----- cc_GetDNIS(CRN:0x80000001) on LineDev:2
05/18/2012 15:28:21.338   5920        5700 libisdnr..ll dtiB1T1    APPL         dtiB1T1   ::::> cc_GetDNIS(Crn=0x80000001) return 0 (szDNIS:63501)
05/18/2012 15:28:21.338   5920        5700 spwrgcis                INTF         gcis                  gcis_GetCallInfo() returns 0
05/18/2012 15:28:21.338   5920        5700 spwrgcis                INTF         gcis                  gcis_GetCallInfo(0x80000001, 0x107, 0x12df28) entry
05/18/2012 15:28:21.338   5920        5700 libisdnr..ll            APPL                   <:::: cc_GetANI(0x80000001, 0x12df28) entry
05/18/2012 15:28:21.338   5920        5700 libisdnr..ll            DEBG                   ----- IsdnGetCRNEntry(Crn:0x80000001, lpCallInfo:0x12deac) returns TRUE
05/18/2012 15:28:21.338   5920        5700 libisdnr..ll dtiB1T1    DEBG         dtiB1T1   ----- cc_GetANI(CRN:0x80000001) on LineDev:2
05/18/2012 15:28:21.338   5920        5700 libisdnr..ll dtiB1T1    INFO         dtiB1T1   ----- IsdnSetLastError(LineDev:2, nNewError:0x303) returns success
05/18/2012 15:28:21.338   5920        5700 libisdnr..ll            ERR1         dtiB1T1   ::::> cc_GetANI(Crn:0x80000001) returns 0x303 due to (szNetworkANI[0] == '')
05/18/2012 15:28:21.338   5920        5700 spwrgcis                ERR1         gcis                  gcis_GetCallInfo() returns -1 due to cc_GetANI(0x80000001) failed
05/18/2012 15:28:21.338   5920        5700 gc                      ERR1         gclib                           ::::> gc_GetCallInfo(crn:0x2800001h, info_id:263) - returns;-1
05/18/2012 15:28:21.338   5920        5700 libisdnr..ll            DEBG                   ::::> cc_geterror() returns: 0x303
05/18/2012 15:28:21.338   5920        5700 spwrgcis                DEBG         gcis                  find_cclib_error_index(0x303) returns: 0x76
05/18/2012 15:28:21.338   5920        5700 spwrgcis                INTF         gcis                  gcis_ErrorValue() returns gc_error: 0x303 with cc_error:x89
05/18/2012 15:28:21.338   5920        5700 spwrgcis                INTF         gcis                  gcis_CRN2LineDev(0x80000001, 0x12de8c, 0x12de88) entry
I have been talking to the Dialogic support team and they mentioned the same thing that "Private" numbering plan is the issue.
They also suggested using another API (see below) as "work around."
The numbering plan being private is the reason why gc_GetCallInfo API is displaying number not available. Did you try using the gc_GetANI( ) API?
Entire contents of the ISDN SETUP message are now available to VG Script using $RV[iSDN_SETUP]
CallerID information can be extracted from $RV[iSDN_SETUP] regardless of the numbering plan used.
