Scripting Com Object Hangs
I have a 64 bit machine (2008 r2) running voice guide (current), all works well except I have made a com object in Visual Studio .Net 4.0 and registered it. I can create a vbs file and run it and the object works no problems. When I put it into a VBS script inside of Voice Guide the object simply hangs at that point and there is a Wscript*32 left running in the process list.
I have made the object 32 bit, and 64 bit. I have regasm.exe the object with both the 32 bit variant and 64 bit variant. Again, I have directly run c:\windows\syswow64\wscript.exe on a test script with the object and it works fine, only inside of Voice Guide is it not working.
Any ideas? (the script is below)
____________________________________________________________
this vbs script works from the command line or double clicking
set o = CreateObject("AccelTimeV2.Work")
s = o.InitCall()
msgbox o.RunModule("test", "0004", "9533", "employeedata")
this below is the voiceguide script that doesn't work
dim vg
dim o
dim sSession
dim emp_num
dim ssn
dim sRet
set vg = CreateObject("vgservices.CommandLink")
'hangs here on the create object
emp_num = "$RV[GetEmpNum]"
ssn = "$RV[GetSsn]"
vg.RVSet $RV_LINEID, "emp_num" emp_num
vg.RVSet $RV_LINEID, "ssn" ssn
sSession = o.InitCall()
vg.RVSet $RV_LINEID, "session" sSession
sRet = o.RunModule("test", emp_num, ssn, "employeedata")
vg.RVSet $RV_LINEID, "result" sRet
if InStr(1, sRet, "error") <> 0 then
vg.Run_ResultReturn $RV_LINEID, "error"
elseif InStr(1, sRet, "no employee") <> 0 then
vg.Run_ResultReturn $RV_LINEID, "not found"
elseif InStr(1, sRet, "Clocked In") <> 0 then
vg.Run_ResultReturn $RV_LINEID, "clockIn"
else
vg.Run_ResultReturn $RV_LINEID, "clockOut"
end if
set o = nothing
set vg = nothing
Have you used Admin_TraceLogAdd calls before and after the
line to confirm that the error occurs on the CreateObject line?
Can you .ZIP up the AccelTimeV2.Work Project directory and post it here?
Yes, it is clearly on the createobject call, I can not give you the source project, however, after more testing, it must be an installation issue with VoiceGuide as I am unable to createobject on any object. We are re-installing from scratch. Is is possible that VoiceGuide requires installation from the Administrator account only? We are a fully privlidged user, and the service is running under our account, but we are unable to createobject for something as simple as WScript.Shell
VoiceGuide needs to be installed as a user that has privileges to start system programs/services, create new objects etc. ie. an Administrator.
From http://www.voiceguide.com/vghelp/source/html/install_v7_dialogicsr60.htm :
Best approach is to just use the Administrator account when installing Dialogic Drivers. Note that a user that is part of the 'Administrator' group does not have the same privileges as the actual Administrator account. On many systems the actual Administrator account needs to be explicitly enabled first before it can be used.
