infosolutionsource Report post Posted 07/29/2012 07:44 AM Hi, can you please send me syntax for Access query, for updating,select and insert? it is possibel to updating ,make two optional by using "and" "or" for examplle UPDATE database SET Id='1' WHERE ID='0' and Name='james' this query is possibel by using two option with "and"? How can i use also looping to check each records in the database? Thanks! Share this post Link to post
SupportTeam Report post Posted 07/29/2012 10:05 PM There are many resources out there that cover SQL query syntax. eg: http://www.w3schools.com/sql/default.asp http://msdn.microsoft.com/en-us/library/office/bb259125%28v=office.12%29 http://www.tutorialspoint.com/sql/sql-syntax.htm this query is possibel by using two option with "and"? Yes. AND, OR can be used. How can i use also looping to check each records in the database? The SQL command will be automatically carried out to affect all entries in database that match the WHERE clause. Share this post Link to post
