Acces Query
can you please send me syntax for Access query, for updating,select and insert?
it is possibel to updating ,make two optional by using "and" "or" for examplle
UPDATE database SET Id='1' WHERE ID='0' and Name='james'
this query is possibel by using two option with "and"?
How can i use also looping to check each records in the database?
Thanks!
There are many resources out there that cover SQL query syntax. eg:
http://www.w3schools.com/sql/default.asp
http://msdn.microsoft.com/en-us/library/office/bb259125%28v=office.12%29
http://www.tutorialspoint.com/sql/sql-syntax.htm
Yes. AND, OR can be used.
The SQL command will be automatically carried out to affect all entries in database that match the WHERE clause.
