invoso.com Report post Posted 07/31/2012 06:15 AM After upgrading system from 30 up to 50 licenses new 20 (31-50) channels are blocked. I'm using DIALOGIC D/600 JCT-2E1 card. How to solve this problem? 0731_0638_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 07/31/2012 06:53 AM From trace it looks like channels 31-50 are all opened on the second E1 trunk (dtiB2). Have you confirmed that that second E1 trunk is working? ISDIAG should be used to confirm trunk operation. Please see : http://www.voiceguide.com/vghelp/source/html/configisdnsetup.htm Share this post Link to post
invoso.com Report post Posted 07/31/2012 07:57 AM how to test channels starting 31 channel? description suggest only 1-30 (isdiag 1 1 e s v) what to use to confirm that second channel working? Witch option in isdiag menu? Share this post Link to post
SupportTeam Report post Posted 07/31/2012 08:09 AM Running isdiag.exe with no parameters will bring up the documentation. There is an option there to select the 'board number', and the channel on the 'board'. First T1/E1 is board 1, second T1/E1 is board 2, etc. Share this post Link to post
invoso.com Report post Posted 07/31/2012 07:33 PM You're right. second PRI trunk was not right configured. Share this post Link to post
