Vg Skipping Play Module
VG don't play manager2\60041.wav message file
141226.218 22 17 6 d added czy jest zapowiedz_Input | 60041>0
141226.218 22 17 6 d added czy jest zapowiedz | True
141226.218 22 17 6 Eval Expr result:[True]
141226.218 22 17 6 path {True} found (at offset 36)
141226.218 22 17 6 FindNextVgmTitleInPathList: next module title is=[info placowki]
141226.218 22 17 6 t timer clear (force=False)
141226.218 22 17 6 RunModule start Play, [info placowki], iModuleIdx=283, previous: vgm=268, vgs=3:3
141226.218 22 17 6 [info placowki] VGMTYPE_PLAY run start
141226.218 22 17 6 CheckForAnyPlayActionsAndSetkeysIfNecessary no PlayActions, vgmidx=283, strPaths=on {timeout 0} goto [play MoH call]
141226.218 22 17 6 PrepareAndPlayWavAndTts start iModuleIdx=283, iPlayFileIdx=1, bMakeTtsFile=True, sSoundFileIs=
141226.218 22 17 6 rv replace start [$RV[manager]\$RV[insert_call_order_plik_$RV[kolejnosc]].wav]
141226.218 22 17 6 rv replace end [manager2\60041.wav]
141226.218 22 17 6 PrepareAndPlayWavAndTTS sPlayFile=manager2\60041.wav
141226.218 22 17 6 state [info placowki] Playing wav (manager2\60041.wav)
141226.218 22 17 6 FindSoundFile start [manager2\60041.wav]
141226.218 22 17 6 q tel add cmd_PlayStart 128875 ,\manager2\60041.wav []
141226.218 22 17 6 play start ok, playId=128875
141226.218 7 17 6 q tel run cmd_PlayStart 4|00:00:01.6250000
141226.375 9 remoting link constructor activated: vgServices_CommandLink
141226.390 9 17 6 rem Play_Stop
141226.390 9 17 CallExistsOnLine TRUE crn=2800365
141226.390 9 17 6 q scr add cmdPlayStop 0
141226.390 6 17 6 q scr run cmdPlayStop sCode=[] iActionID=0, crn=0[0|0|0|0|0][|||||] 56|00:00:08.2656250
141226.390 6 17 6 q tel add cmd_PlayStop [0,0,0,0,0][||||]
141226.390 6 17 6 play PlaySoundStop ok
141226.390 7 17 6 q tel run cmd_PlayStop 4|00:00:01.6250000
141226.406 9 17 6 rem Play_Start komunikaty\ring_multiple short.wav
I don't know why is playing Play_Start komunikaty\ring_multiple short.wav file because in play module is only "$RV[manager]\$RV[insert_call_order_plik_$RV[kolejnosc]].wav" declared.
In other places of VG script Play module working properly.
This can be seen in the trace:
Looks like you have some Play_Stop commands from other launched programs/scripts interfering.
This is the same issue that you had before with recording, which you reported in this thread:
http://voiceguide.com/forums/index.php?showtopic=8793
If you use "Run VBScript" modules to start VBScripts and, and issue Play/Record/Stop API commands in those VBScripts, and do not wait for them to complete, then commands issued from these VBScripts will interfere with rest of your script - as the VoiceGuide script has moved onto doing something else by the time the external VBScript gets around to issuing the Play/Record/Stop API commands.
If you use "Run VBScript" modules to issue Play/Record/Stop API commands then it is best to wait till those scripts complete before moving onto next module.
