Some Thing Wrong About Say Numer
this is my code in the lib_num2wav.vbs:
'name : CN_Digits
'info : Say the digits in the number In Chinese
'arg1 : Digits to be spoken In Chinese :
Function CN_Digits(byval arg1)
'returns a list of comma delimited wav files,
'with each wav file corresponding to a character
'in the supplied input string.
sDigits=Trim(arg1)
For i=1 To Len(sDigits)
sDigit = Mid(sDigits, i, 1)
If sDigit = "-" Then
sWav = "minus.wav"
Else
sWav = sDigit & ".wav"
end If
If sOut = "" Then
sOut = sWav
else
sOut = sOut & "," & sWav
End if
Next
Digits = sOut
End Function
I have do nothing but modify the name of Digits,but when i choice the opinion in the Say Num module.I can hear a wrong message bell .
maybe I should do something more to solve this problem,but I don't know what to do.
0828_1641_vgEngine.txt
lib_num2wav.txt
vg.txt
test23.txt
The last line in this new function should be:
CN_Digits = sOut
(instead of Digits = sOut )
Have you looked into modifying the vgLib_SayNumbers.dll instead? Full source code to vgLib_SayNumbers.dll is provided and you can can modify the functions there (or add your functions to it) and recompile.
The newly created vgLib_SayNumbers.dll then just needs to be placed in VoiceGuide directory (replacing previous file) and VoiceGuide will then use that DLL when generating the lists of .WAV files to be played when saying numbers/dates etc.
At first ,I try to make this funtion by DLL,but when I build the project,some problems come out.could you give me some advice about how to recompile. For example,before I build what I should add in this project.
Before building vgLib_SayNumbers.dll for the first time you need to ensure that it is referencing the vgServicesInterfaces.dll
vgServicesInterfaces.dll is in the VoiceGuide directory.
If you get any other errors when compiling please post the errors here and we can better advise.
Are you using Visual Studio or some other environment?
