Guest soshe Report post Posted 11/28/2003 10:21 PM Have tried everything to get call transferred using Modem - Call Does get transferred but back to the same internal line - I'd like it go to a cell (an external no). Any help is greatly appreciated Thanks Share this post Link to post
SupportTeam Report post Posted 11/28/2003 11:52 PM Are you using a PBX or the Telephone Company’s lines? Is your modem's hookflash length matched to what is expected on the line which is plugged into it? Share this post Link to post
Guest soshe Report post Posted 01/20/2004 06:59 PM I'm using the Phone Company's lines , have tried to contact them about the hookflash length - but got now where with them. Is there any other way to find out what that is ? Thanks Share this post Link to post
Guest soshe Report post Posted 01/20/2004 07:52 PM Here is the log generated - Notice it runs through the whole script then hangs up as it should - but actually brings caller back to the welcome module and does it all over again. Help is appreciated - Thanx Share this post Link to post
Guest soshe Report post Posted 01/20/2004 07:53 PM 142032.91 0 callstate OFFERING 65933 0 4 142032.95 0 Answer the call at 1/20/2004 2:20:32 PM 142032.96 0 lineAnswer(65933) => 65797 142032.96 0 ring 1 142032.96 0 callstate ACCEPTED 65933 0 0 142034.22 0 Lev_CallerID [4162446303,NEXUS IT] 142034.23 0 Lev_CallerID [4162446303,NEXUS IT] 142037.05 0 tapi Reply (LineEvReply) ok 65797 0 142037.06 0 callstate CONNECTED 65933,0,0 142037.06 0 WorkingModeTAPI@Connected= 142037.06 0 WorkingModeScript@Connected= 142037.07 0 Inband detection not enabled 142037.09 0 StartLoadedVgs at 1/20/2004 2:20:37 PM 142037.09 0 [Welcome] Playing 142037.09 0 [Welcome] Playing (C:\Program Files\VoiceGuide\Voice\other.wav) 142037.18 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Voice\other.wav] 142037.19 0 RunModule PLAY end 142041.60 0 dtmf 2 (65933,50,2) 142041.60 0 LsPlayMsg 2 142041.70 0 PlaySoundStop ok 142042.11 0 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 142042.11 0 [sales] Blind Transfer to 4166887067 (Generate) 142042.13 0 tapic lineGenerateDigits(65933,!,0) => 0 142042.64 0 generate LINEGENERATETERM_DONE 142043.64 0 LsXferStart EV_TAPI_GENERATE 142044.64 0 LsXferPlayVts EV_HOOKFLASHFINISHED 142044.64 0 tapic lineGenerateDigits(65933,4166887067,0) => 0 142048.18 0 generate LINEGENERATETERM_DONE 142049.16 0 LsXferPlayVts EV_TAPI_GENERATE 142050.16 0 LsXferPlayVts EV_TIMEOUT_HANGUP 142050.18 0 Hanging up call... 142050.19 0 RecSoundStop ok 142050.19 0 PlaySoundStop ok 142050.19 0 fnHangupCall end 142050.29 0 callstate DISCONNECTED 65933,1,0 142050.30 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT 142050.30 0 Hanging up call... 142050.31 0 RecSoundStop ok 142050.31 0 PlaySoundStop ok 142050.31 0 fnHangupCall end 142050.32 0 callstate IDLE 65933 0 0 142050.32 0 WorkingMode@Idle= 142050.34 0 tapi Reply (LineEvReply) ok 65729 0 142050.34 0 tapi Reply (LineEvReply) ok 65746 0 142051.25 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 142051.25 0 ReinitTelephony due to IDLE start 142051.26 0 tapic lineDeallocateCall(MainCall:65933) 0 142051.55 0 lineOpen(0) => 0 142051.56 0 Waiting for a call... 142051.56 0 lineOpen(0)LineHandle=65609 142056.32 0 callstate OFFERING 66515 0 4 142056.33 0 Answer the call at 1/20/2004 2:20:56 PM 142056.33 0 lineAnswer(66515) => 65694 142056.34 0 ring 1 142056.34 0 callstate ACCEPTED 66515 0 0 142100.46 0 tapi Reply (LineEvReply) ok 65694 0 142100.46 0 callstate CONNECTED 66515,0,0 142100.46 0 WorkingModeTAPI@Connected= 142100.48 0 WorkingModeScript@Connected= 142100.48 0 Inband detection not enabled 142100.48 0 StartLoadedVgs at 1/20/2004 2:21:00 PM 142100.48 0 [Welcome] Playing 142100.48 0 [Welcome] Playing (C:\Program Files\VoiceGuide\Voice\other.wav) 142100.57 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Voice\other.wav] 142100.57 0 RunModule PLAY end 142103.78 0 dtmf 2 (66515,50,2) 142103.79 0 LsPlayMsg 2 142103.89 0 PlaySoundStop ok 142104.29 0 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 142104.29 0 [sales] Blind Transfer to 4166887067 (Generate) 142104.30 0 tapic lineGenerateDigits(66515,!,0) => 0 142104.82 0 generate LINEGENERATETERM_DONE 142105.80 0 LsXferStart EV_TAPI_GENERATE 142106.80 0 LsXferPlayVts EV_HOOKFLASHFINISHED 142106.80 0 tapic lineGenerateDigits(66515,4166887067,0) => 0 142110.34 0 generate LINEGENERATETERM_DONE 142111.32 0 LsXferPlayVts EV_TAPI_GENERATE 142112.32 0 LsXferPlayVts EV_TIMEOUT_HANGUP 142112.32 0 Hanging up call... Share this post Link to post
SupportTeam Report post Posted 01/21/2004 03:48 AM From the trace we can see that VoiceGuide makes the transfer and then hangs up: 142050.18 0 Hanging up call... but then about 6 seconds later the PBX rings VoiceGuide's extension again: 142056.34 0 ring 1 This is probably because transfer to "4166887067" failed... many PBXs/switches will ring the extension from which transfer was made again if the transfer has failed and connect the original call again... When there is a ring on a line VG trats it as a new call - that's why the script starts at the [Welcome] module again... Share this post Link to post
Guest Guest_Soshe Report post Posted 01/22/2004 05:56 PM So is it something in the script , the hookflash lenght or some other phone company issue ? Sam. Share this post Link to post
Guest Guest_Chris Report post Posted 01/23/2004 01:24 AM I am also curious about this same issue. I have had no luck transferring to an outside line using the telephone companies lines. Any information on the subject would be REALLY appreciated! Share this post Link to post
SupportTeam Report post Posted 01/23/2004 01:50 AM So is it something in the script , the hookflash lenght or some other phone company issue ? In this case it looks liek the call was sent back to VG by the phone company - the hookflash length is OK and script worked OK as well: This is probably because transfer to "4166887067" failed... many PBXs/switches will ring the extension from which transfer was made again if the transfer has failed and connect the original call again... I am also curious about this same issue. I have had no luck transferring to an outside line using the telephone companies lines. Please see: http://voiceguide.com/forums/index.php?showtopic=1050 Share this post Link to post
