Guest jewild_1 Report post Posted 11/30/2003 06:11 PM I have a Panasonic KX-TD1232. It installed fine. The next day the phones on lines 1-4 started ringing back. If you pick up to dial tone and then hang up, the system rings back to the extension you just hung up, otherwise the first four lines work fine. I switched to lines 5-8 and everything works fine now. Can anyone help me to figure out what is wrong with the first four lines ? NTMCSE@ix.netcom.com Thanks Share this post Link to post
SupportTeam Report post Posted 12/01/2003 02:56 AM This seems like a problem with the Panasonic KX-TD1232... probably best to ask Panasonic's support to help you with this... Share this post Link to post
