Vg Fails To Complete Blind Transfer
Below is the trace for the call.
VG is calling the second number to make the transfer; the phone at that station rings is picked up by me; but then VG seems to be taking the call back with a flash. The original caller hears the line ringing again and VG starts all over again like it is a new call. The transfer seems to get aborted because VG seems to be flashing the call back instead of just hanging up.
How do I get VG to simply hangup instead of flashing the line?
070813.07 5 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
070813.13 5 task completed (shellid=1416, process=1624)
070813.19 5 Found result file: VGRUNRESULT_5.TXT
070813.29 5 Run Result [success, ]
070813.45 5 PlaySoundStop ok
070813.55 5 [Transfer to Operator] Playing
070813.61 5 [Transfer to Operator] Playing (C:\VoicePrompts\transfer2.wav)
070813.77 5 PlaySoundStart ok [C:\VoicePrompts\transfer2.wav]
070813.82 5 RunModule PLAY end
070815.69 5 Play End line[5] (id=410865)
070815.74 5 LsPlayMsg EV_PLAY_FINISHED
070815.80 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
070816.26 5 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
070816.33 5 [Transfer Call] Blind Transfer to 9,620XXXX (Generate) 'a real number is actually here - I have replaced it with XXXX for this forum
070816.77 5 tapic lineGenerateDigits(66241,!,0) => 0
070817.47 5 generate LINEGENERATETERM_DONE
070818.43 5 LsXferStart EV_TAPI_GENERATE
070819.48 5 LsXferPlayVts EV_HOOKFLASHFINISHED
070819.74 5 tapic lineGenerateDigits(66241,9,620XXXX,0) => 0 'edited number for this forum
070822.93 5 generate LINEGENERATETERM_DONE
070823.88 5 LsXferPlayVts EV_TAPI_GENERATE
070824.96 5 LsXferPlayVts EV_TIMEOUT_HANGUP
070825.01 5 Hanging up call...
070825.10 5 RecSoundStop ok
070825.15 5 PlaySoundStop ok
070825.23 5 fnHangupCall end
070825.33 5 linedevstate 2048 0 0
070825.40 5 callstate IDLE 66241 0 0
070825.45 5 WorkingMode@Idle=
070825.72 5 tapi Reply (LineEvReply) ok 65848 0
070826.68 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
070826.73 5 ReinitTelephony due to IDLE start
070826.84 5 tapic lineDeallocateCall(MainCall:66241) 0
070828.15 5 lineOpen(5) => 0
070828.20 5 Waiting for a call...
070828.25 5 lineOpen(5)LineHandle=66223
070836.01 5 linedevstate 2048 0 0
070836.05 5 callstate OFFERING 65933 0 4
070836.11 5 Answer the call at 12/3/2003 7:08:36 AM
070836.16 5 lineAnswer(65933) => 66036
070836.22 5 callinfo CALLEDID
070836.28 5 callinfo ORIGIN
070836.32 5 ring 0
070836.70 5 callstate CONNECTED 65933,1,0
070836.75 5 WorkingModeTAPI@Connected=
070836.81 5 WorkingModeScript@Connected=
070836.88 5 Inband detection not enabled
070836.93 5 StartLoadedVgs at 12/3/2003 7:08:36 AM
070836.98 5 tapi Reply (LineEvReply) ok 66036 0
070837.05 5 [Greeting] Number Input
070837.10 5 [Greeting] Playing (C:\VoicePrompts\prompt1.wav,C:\VoicePrompts\prompt2.wav)
070837.20 5 PlaySoundStart ok [C:\VoicePrompts\prompt1.wav,C:\VoicePrompts\prompt2.wav]
Please disregard this post until I get back to you.
I have tried to forward a call manually and I am getting the same problem. At this point the problem seems to be with Verizon not VG.
I'll let you know what the problem was as I am talking to Verizon about it now.
Sorry for the inconvenience.
