Transfer Problem
I do a 3Way Conference Call-Blind in the Transfer call module,but it not works.
my sip server is Elastix.what I should do to config my Elastix server or pbx?
thanks
transfer.zip
The destination transfer number was not specified as an IP address.
On VoIP systems the destination numbers need to be specified as IP addresses.
The number specified was:
6000
It probably should be:
6000@192.168.1.24
Please .ZIP up any traces before posting them.
Also can you please add the following line to the VG.INI, in [Log] section:
Encoding=Unicode
This will save the vgEngine log files in Unicode, instead of ASCII.
Please include the ktTel and WireShark traces as well that capture the "Dial and Conference" attempt.
Encoding=Unicode
which file I need to set the CallerID on the outgoing call? config.xml is right?
by the way ,can you read chinese?
Traces show that CallerID on outgoing call was set to: 2000@192.168.1.24
The switch is rejecting the outbound call with a "401-Unauthorised", and HMP/VoiceGuide cannot authenticate 2000@192.168.1.24 as it does not have authentication information for it.
The only extensions that you have provided the authentication information for in Config.xml are the 5000@192.168.1.24 and 7000@192.168.1.24 extensions.
Suggest CallerId is set to one of the registered extensions (5000@192.168.1.24 or 7000@192.168.1.24), or add authentication information for 2000@192.168.1.24 , or set the VoIP switch to not require authentication on outgoing calls.
From traces:
174215.625  6               voip authentication data idx=0: realm:asterisk, identity:sip:7000@192.168.1.24, username:7000, ******
174215.625  6               voip authentication data idx=1: realm:asterisk, identity:sip:5000@192.168.1.24, username:5000, ******
174458.171  6   3   1       sRvOutboundLeg=, strDialoutOptions=<CallerId>2000@192.168.1.24</CallerId>
Screenshot of WireShark attached:
thanks I solve this problem by add authentication information for 2000@192.168.1.24
