Guest zhangmin Report post Posted 09/12/2012 04:02 AM today voiceguide can not do any outbound ,i checked the logfile and find that "call progress detection not enabled. We'll wait till after connect" what should I do to solve this? outbound.zip Share this post Link to post
SupportTeam Report post Posted 09/12/2012 04:19 AM Trace shows that outgoing call was attempted bu then a DISCONNECTED event was received We would need to see the WireShark trace of the outgoing call to see why it was disconnected. 112758.218 4124 3 fn LineMakeCall(iLineId=3, iCallRequestId=0 (ignored), strNumberToCall=[2000@192.168.1.24], callprog=DX_PAMDOPTEN, timeout=60, params:0,0,cidtosend=[],opt=[]) 112758.328 5732 3 ev GCEV_DIALING crn=8000001 crn_lastMakeCall=8000001 112758.484 5732 3 ev GCEV_DISCONNECTED crn=8000001 "call progress detection not enabled. We'll wait till after connect" This is not an error message. Share this post Link to post
Guest zhangmin Report post Posted 09/17/2012 09:00 AM even I reinstall voiceGuide it still not work. attachment.zip Share this post Link to post
SupportTeam Report post Posted 09/17/2012 11:54 AM WireShark trace shows that a call was placed to 2000@192.168.1.24. The VoIP switch replies with "401-Unauthorized" It looks like CallerID was not set on outgoing call, so the "401-Unauthorized" response does not include what account should be used to authorize the call. Recommend that CallerID is set on the outgoing call, or the VoIP switch is set to not request authorization for calls being made from the IP address where the VoiceGuide system is installed. Please see: http://www.voiceguide.com/vghelp/source/html/dial_voip.htm Share this post Link to post
Guest zhangmin Report post Posted 09/18/2012 02:08 AM but i have do that in the config file. like this: <VoIP_Authentication> <Realm>asterisk</Realm> <Identity>sip:2000@192.168.1.24</Identity> <AuthUsername>2000</AuthUsername> <AuthPassword>zhangmin01</AuthPassword> </VoIP_Authentication> </VoIP_Authentications> could you tell me how to do?for example ,whice file i need to write and so on…… thanks Share this post Link to post
SupportTeam Report post Posted 09/18/2012 06:36 AM You have not set the CallerID on the outgoing call. As the VoIP switch was not told which account was going to be used to make the call, the VoIP switch did not know what account to request authentication for. You need to specify what account will be used to make he call, and have Authentication information for that account (if switch requests Authentication). When a VoIP Switch asks for authentication it asks for authentication of the a party that is making the call - it does not care whether or not you happen to have authentication information for the destination number. To describe it in another way: To be be able to start the call you need to be able to say SIP equivalent of: "Hi, I'm X. Let me make a call", to which then switch says "What is your password X?" and when X tells switch the password then the switch will place the call to wherever X wants to place the call. A week ago you were able to make outgoing calls with calls authenticating themselves here properly. Here is the post where you said that you can do it: http://voiceguide.com/forums/index.php?showtopic=9161&view=findpost&p=35651 Share this post Link to post
Guest zhangmin Report post Posted 09/19/2012 09:31 AM I can do transfer by add authentication information for 2000@192.168.1.24 in the config file. but it can not do outbound.I don't know what wrong with it. Share this post Link to post
SupportTeam Report post Posted 09/19/2012 10:42 AM A REFER transfer is different to an outgoing call. As mentioned before, your VoIP switch requires authentication to allow outgoing calls to be made through it, so you need to specify CallerID on outgoing calls, and provide authentication (or turn off this authentication requirement at the VoIP switch). Share this post Link to post
Guest zhangmin Report post Posted 09/21/2012 02:19 AM how to specify CallerID on outgoing calls,can you give me a example? thanks very much. I have set <CallOptions>2000</CallOptions> ,but it can not work. Share this post Link to post
SupportTeam Report post Posted 09/21/2012 02:39 AM Suggest trying: <CallerID>2000@192.168.1.24</CallerID> Please see: http://www.voiceguide.com/vghelp/source/html/dial_voip.htm Share this post Link to post
