Dialogic Answers On All 4 Ports
Dialogic answers on all four ports even though there is one call coming in.
We are using D4/PCI.
Any ideas on why this is happening.
Has anyone come across this symptom.
VG Line status dialog shows that all 4 ports on our D4pci cards picks up one incoming call via our Panasonic KX TA-624 PBX.
Once the lines are picked up. the OGM begins to play and then the remaining 3 lines start to disconnect. This was not the case in version 4.9 before we upgraded to 5.14.
Also when dialing the desired extension. We have the script setup to do a blind transfer (log line 121122.80) and upon dialing 103 for example, Extension 103 does not ring and VG disconnects.
Line 121126.35 of the event trace indicates that the call has been placed on hold and the transfer is in process, but this is not true as it just disconnects.
Also the same script in version 4.9 had not provblems.
I have tried extension to extension transfers and they works, so the PBX does not seem to be the problem. VG to Extension transfers do not work.
What gives.
Here is the event trace
121102.86 7 linedevstate 2048 0 0
121102.87 7 callstate OFFERING 66372 0 4
121102.87 7 Answer the call at 12/7/2003 12:11:02 PM
121102.91 7 lineAnswer(66372) => 66355
121102.91 7 callinfo CALLEDID
121102.92 7 callinfo ORIGIN
121102.92 7 ring 0
121102.93 5 linedevstate 2048 0 0
121102.93 5 callstate OFFERING 66321 0 4
121102.94 5 Answer the call at 12/7/2003 12:11:02 PM
121102.94 5 lineAnswer(66321) => 66304
121102.95 5 callinfo CALLEDID
121102.95 5 callinfo ORIGIN
121102.96 5 ring 0
121103.44 7 callstate CONNECTED 66372,1,0
121103.44 7 WorkingModeTAPI@Connected=
121103.45 7 WorkingModeScript@Connected=
121103.50 7 Inband detection not enabled
121103.50 7 StartLoadedVgs at 12/7/2003 12:11:03 PM
121103.51 7 tapi Reply (LineEvReply) ok 66355 0
121103.53 5 callstate CONNECTED 66321,1,0
121103.54 5 WorkingModeTAPI@Connected=
121103.55 5 WorkingModeScript@Connected=
121103.55 5 Inband detection not enabled
121103.56 5 StartLoadedVgs at 12/7/2003 12:11:03 PM
121103.57 5 tapi Reply (LineEvReply) ok 66304 0
121103.58 5 [Welcome - Language Select] Playing
121103.58 5 [Welcome - Language Select] Playing (\english\Thank_you_for_calling_eZigma_no_bull_IT_company.wav)
121103.63 5 PlaySoundStart ok [E:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\\english\Thank_you_for_calling_eZigma_no_bull_IT_company.wav]
121103.63 5 RunModule PLAY end
121103.64 7 [Welcome - Language Select] Playing
121103.65 7 [Welcome - Language Select] Playing (\english\Thank_you_for_calling_eZigma_no_bull_IT_company.wav)
121103.68 7 PlaySoundStart ok [E:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\\english\Thank_you_for_calling_eZigma_no_bull_IT_company.wav]
121103.69 7 RunModule PLAY end
121104.13 6 linedevstate 2048 0 0
121104.14 6 callstate OFFERING 66286 0 4
121104.15 6 Answer the call at 12/7/2003 12:11:04 PM
121104.19 6 lineAnswer(66286) => 66269
121104.20 6 callinfo CALLEDID
121104.21 6 callinfo ORIGIN
121104.22 6 ring 0
121104.23 8 linedevstate 2048 0 0
121104.24 8 callstate OFFERING 66235 0 4
121104.25 8 Answer the call at 12/7/2003 12:11:04 PM
121104.26 8 lineAnswer(66235) => 66218
121104.27 8 callinfo CALLEDID
121104.28 8 callinfo ORIGIN
121104.29 8 ring 0
121104.72 6 callstate CONNECTED 66286,1,0
121104.73 6 WorkingModeTAPI@Connected=
121104.74 6 WorkingModeScript@Connected=
121104.80 6 Inband detection not enabled
121104.80 6 StartLoadedVgs at 12/7/2003 12:11:04 PM
121104.82 6 tapi Reply (LineEvReply) ok 66269 0
121104.83 6 [Welcome - Language Select] Playing
121104.86 6 [Welcome - Language Select] Playing (\english\Thank_you_for_calling_eZigma_no_bull_IT_company.wav)
121104.91 6 PlaySoundStart ok [E:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\\english\Thank_you_for_calling_eZigma_no_bull_IT_company.wav]
121104.92 6 RunModule PLAY end
121104.93 8 callstate CONNECTED 66235,1,0
121104.94 8 WorkingModeTAPI@Connected=
121104.95 8 WorkingModeScript@Connected=
121104.96 8 Inband detection not enabled
121104.97 8 StartLoadedVgs at 12/7/2003 12:11:04 PM
121104.98 8 tapi Reply (LineEvReply) ok 66218 0
121104.99 8 [Welcome - Language Select] Playing
121105.01 8 [Welcome - Language Select] Playing (\english\Thank_you_for_calling_eZigma_no_bull_IT_company.wav)
121105.05 8 PlaySoundStart ok [E:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\\english\Thank_you_for_calling_eZigma_no_bull_IT_company.wav]
121105.06 8 RunModule PLAY end
121108.24 5 wb(92532800)
121108.30 7 wb(92539800)
121108.36 5 Play End line[5] (id=925328)
121108.38 5 LsPlayMsg EV_PLAY_FINISHED
121108.39 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
121108.39 7 Play End line[7] (id=925398)
121108.41 7 LsPlayMsg EV_PLAY_FINISHED
121108.43 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
121108.45 7 [set English Language] Evaluate ["e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english"]
121108.45 7 .Eval(Cstr("e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english"))
121108.46 7 Eval Expr result:[e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english] stored in $RV[DIRSYSTEMVOICE]
121108.48 7 path {e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english} not found
121108.50 7 [Welcome] Playing
121108.52 7 RVreplace start: [e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\$RV[Get Language]\welcome_menu.wav]
121108.54 7 RVreplace end: [e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\\welcome_menu.wav]
121108.55 7 [Welcome] Playing (e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\\welcome_menu.wav)
121108.59 7 PlaySoundStart ok [e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english\welcome_menu.wav]
121108.61 7 RunModule PLAY end
121108.61 5 [set English Language] Evaluate ["e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english"]
121108.64 5 .Eval(Cstr("e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english"))
121108.64 5 Eval Expr result:[e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english] stored in $RV[DIRSYSTEMVOICE]
121108.66 5 path {e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english} not found
121108.68 5 [Welcome] Playing
121108.70 5 RVreplace start: [e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\$RV[Get Language]\welcome_menu.wav]
121108.70 5 RVreplace end: [e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\\welcome_menu.wav]
121108.73 5 [Welcome] Playing (e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\\welcome_menu.wav)
121108.79 5 PlaySoundStart ok [e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english\welcome_menu.wav]
121108.80 5 RunModule PLAY end
121109.55 6 wb(92661000)
121109.63 6 Play End line[6] (id=926610)
121109.64 6 LsPlayMsg EV_PLAY_FINISHED
121109.66 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
121109.66 8 wb(92676000)
121109.73 8 Play End line[8] (id=926760)
121109.75 8 LsPlayMsg EV_PLAY_FINISHED
121109.77 8 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
121109.79 8 [set English Language] Evaluate ["e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english"]
121109.80 8 .Eval(Cstr("e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english"))
121109.82 8 Eval Expr result:[e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english] stored in $RV[DIRSYSTEMVOICE]
121109.83 8 path {e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english} not found
121109.85 8 [Welcome] Playing
121109.86 8 RVreplace start: [e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\$RV[Get Language]\welcome_menu.wav]
121109.88 8 RVreplace end: [e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\\welcome_menu.wav]
121109.89 8 [Welcome] Playing (e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\\welcome_menu.wav)
121109.94 8 PlaySoundStart ok [e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english\welcome_menu.wav]
121109.95 8 RunModule PLAY end
121109.97 6 [set English Language] Evaluate ["e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english"]
121109.99 6 .Eval(Cstr("e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english"))
121109.00 6 Eval Expr result:[e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english] stored in $RV[DIRSYSTEMVOICE]
121110.02 6 path {e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english} not found
121110.03 6 [Welcome] Playing
121110.05 6 RVreplace start: [e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\$RV[Get Language]\welcome_menu.wav]
121110.06 6 RVreplace end: [e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\\welcome_menu.wav]
121110.08 6 [Welcome] Playing (e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\\welcome_menu.wav)
121110.13 6 PlaySoundStart ok [e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english\welcome_menu.wav]
121110.14 6 RunModule PLAY end
121115.23 5 callstate DISCONNECTED 66321,0,0
121115.24 5 LsPlayMsg EV_REMOTEPARTY_DISCONNECT
121115.27 5 Hanging up call...
121115.29 5 RecSoundStop ok
121115.34 5 PlaySoundStop ok
121115.36 5 fnHangupCall end
121115.41 5 linedevstate 2048 0 0
121115.43 5 callstate IDLE 66321 0 0
121115.45 5 WorkingMode@Idle=
121115.48 5 tapi Reply (LineEvReply) ok 66201 0
121116.39 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
121116.41 5 ReinitTelephony due to IDLE start
121116.44 5 tapic lineDeallocateCall(MainCall:66321) 0
121116.97 5 lineOpen(5) => 0
121116.99 5 Waiting for a call...
121116.00 5 lineOpen(5)LineHandle=66184
121117.02 6 callstate DISCONNECTED 66286,0,0
121117.04 6 LsPlayMsg EV_REMOTEPARTY_DISCONNECT
121117.06 6 Hanging up call...
121117.07 6 RecSoundStop ok
121117.14 6 PlaySoundStop ok
121117.16 6 fnHangupCall end
121117.17 8 callstate DISCONNECTED 66235,0,0
121117.19 8 LsPlayMsg EV_REMOTEPARTY_DISCONNECT
121117.21 8 Hanging up call...
121117.22 8 RecSoundStop ok
121117.29 8 PlaySoundStop ok
121117.31 8 fnHangupCall end
121117.32 7 dtmf 1 (66372,49,2)
121117.34 7 LsPlayMsg 1
121117.41 7 PlaySoundStop ok
121117.42 6 linedevstate 2048 0 0
121117.44 6 callstate IDLE 66286 0 0
121117.45 6 WorkingMode@Idle=
121117.48 6 tapi Reply (LineEvReply) ok 66150 0
121117.50 8 linedevstate 2048 0 0
121117.52 8 callstate IDLE 66235 0 0
121117.53 8 WorkingMode@Idle=
121117.57 8 tapi Reply (LineEvReply) ok 66133 0
121117.60 7 [Get Extension] Number Input
121117.62 7 RVreplace start: [e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\$RV[Get Language]\get_extension.wav]
121117.63 7 RVreplace end: [e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\\get_extension.wav]
121117.65 7 [Get Extension] Playing (e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\\get_extension.wav)
121117.69 7 PlaySoundStart ok [e:\Program Files\VoiceGuide\Scripts\eZigma Voicemail\english\get_extension.wav]
121118.50 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
121118.51 6 ReinitTelephony due to IDLE start
121118.54 6 tapic lineDeallocateCall(MainCall:66286) 0
121118.92 6 lineOpen(6) => 0
121118.94 6 Waiting for a call...
121118.96 6 lineOpen(6)LineHandle=66116
121118.97 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
121118.99 8 ReinitTelephony due to IDLE start
121119.01 8 tapic lineDeallocateCall(MainCall:66235) 0
121119.39 8 lineOpen(8) => 0
121119.41 8 Waiting for a call...
121119.44 8 lineOpen(8)LineHandle=66082
121120.42 7 wb(93939800)
121120.49 7 Play End line[7] (id=939398)
121120.52 7 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
121121.49 7 dtmf 1 (66372,49,2)
121121.51 7 LsGetNbrsRxDigits 1
121121.53 7 [Get Extension] Number Input 1
121121.56 7 path {1} not found
121122.34 7 dtmf 0 (66372,48,2)
121122.36 7 LsGetNbrsRxDigits 0
121122.39 7 [Get Extension] Number Input 10
121122.41 7 path {10} not found
121122.77 7 dtmf 3 (66372,51,2)
121122.79 7 LsGetNbrsRxDigits 3
121122.80 7 [Get Extension] Number Input 103
121123.14 7 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
121123.16 7 RVreplace start: [$RV[Get Extension]]
121123.18 7 RVreplace end: [103]
121123.21 7 [Transfer Call] Blind Transfer to 103 (TAPI)
121123.23 7 lineBlindTransfer(66372,103,0) in LsXferStart => 66048
121126.35 7 callstate ONHOLDPENDTRANSFER 66372 0 0
121126.82 7 linedevstate 2048 0 0
121126.84 7 callstate IDLE 66372 0 0
121126.86 7 WorkingMode@Idle=BlindTransfer
121126.90 7 tapi Reply (LineEvReply) ok 66048 0
121127.09 0 sys cleanup Start
121127.11 0 sys cleanup End
121127.83 7 LsXferStart EV_TIMEOUT_TIMETOREINITLINE
121127.85 7 ReinitTelephony due to IDLE start
121127.88 7 tapic lineDeallocateCall(MainCall:66372) 0
121128.20 7 lineOpen(7) => 0
121128.22 7 Waiting for a call...
121128.25 7 lineOpen(7)LineHandle=66047
121202.16 0 btn Exit (4 lines)
121202.18 5 line state =900
121202.20 6 line state =900
121202.23 7 line state =1900
121202.25 7 calling HangupCall
121202.27 7 Hanging up call...
121202.30 7 RecSoundStop ok
121202.32 7 PlaySoundStop ok
121202.34 7 HangupCall : lCallHandle& = 0 - lets close and open line
121202.37 7 ReinitTelephony due to IDLE start
121202.70 7 lineOpen(7) => 0
121202.72 7 Waiting for a call...
121202.74 7 lineOpen(7)LineHandle=66013
121202.77 7 Waiting for a call...
121202.79 7 fnHangupCall end
121202.82 8 line state =900
121202.84 5 Exiting...
121202.86 6 Exiting...
121202.88 7 Exiting...
121202.91 8 Exiting...
121207.85 0 calling TapiWrap.Shutdown
121209.73 0 Unloading Main Window
I'd appreciate a prompt response considering this is a live VG implementation.
You haven't by any chance plugged the same line into all 4 ports on the PCI card?
ie. connected all 4 ports 'in parallel' to the same phone line...
Every time in the past somebody reported this problem it turned out they have done just that...
Each port on the Dialogic card needs to be attached to a different phone line...
each line is pluged into port 7,8 and 15,16 on our panasonic pbx. These ports have been configured to answer all incoming calls as voice mail ports.
nothing has really changed but the version of voiceguide.
in version 4.9 everything worked fine. In version 5.0 it was good. Recently went to version 5.1.4 and have started having issues...
The trace shows that all 4 lines are RINGing:
121102.92 7 ring 0
121102.96 5 ring 0
121104.22 6 ring 0
121104.29 8 ring 0
I'd suggest connecting normal phone handsets to the 4 lines and you'll then see all 4 lines ringing... and VG answers any lines that RING, that's why you get all 4 lines answering at the same time...
It looks like the config of the switch is a bit different to what is expected - I'd suggest fixing that issue first and then looking into the call transfer issue - testing it using the same lies as are plugged into VG...
