Maintaining A Log In Vg
hi
is there any way by which i can maintain a log in VG for my MIS reports like no. of calls, average calls etc
tks - Hitesh
If the log files created by VG are insufficient then customized log files can be created from within the VG script itself.
You can create log files by:
- appending information to a text file using the ECHO command in the Run Program module, eg:
command.com /c echo $RV_DD, $RV_MM, $RV_CIDNAME, $RV_CIDNUMBER, $RV[GetNumbersCode], $RV_CALLLENGTH >> c:\CallLog$RV_YY$RV_MM.csv
-appending information to a text file using VB Script in the Run VB Script module, eg:
Const ForReading = 1
Const ForWriting = 2
Const ForAppending = 8
set tsFile = fso.OpenTextFile("C:\LogCalls.txt", ForAppending, True)
tsFile.WriteLine "$RV_STARTTIME, $RV_CIDNUMBER, $RV[EnterClientNumber]"
tsFile.Close
set tsFile = Nothing
set fso = Nothing
-appending information to a database using a DB Query module...
-calling your own logging programs/functions from with Run Program or Run VB Script modules...
Related posts:
http://voiceguide.com/forums/index.php?showtopic=493
http://voiceguide.com/forums/index.php?showtopic=233
