Guest kent998 Report post Posted 10/19/2012 05:05 AM Hi! This is Kent from Hong Kong. I'm going to purchase 2 D/120JCT and VG Professional(24 lines) to build an IVR system for my company use. I got some questions: 1) Anyone can share your success case for me located in Hong Kong? 2) Can I install 2 D/120JCT in a single system?... 3) How should I purchase the license if I want to build a 12 ports IVR system first? Can I just add 1 more D/120JCT and 12 more licenses at an existing VG IVR system? Anyone can share with me? ^^ Thank you very much! Share this post Link to post
SupportTeam Report post Posted 10/19/2012 07:09 AM Quote 1) Anyone can share your success case for me located in Hong Kong? Please contact sales@voiceguide.com for relevant references/contacts. Quote 2) Can I install 2 D/120JCT in a single system?... Yes. The two cards will need to be connected together using a CT-Bus cable as well - so you will need to order the CT-Bus cable when ordering the two cards. Quote 3) How should I purchase the license if I want to build a 12 ports IVR system first? You can buy 12 ports now and 12 ports later. You should use VoiceGuide v7. Quote Can I just add 1 more D/120JCT and 12 more licenses at an existing VG IVR system? Yes. Please let us know if you have any more questions. Share this post Link to post
