Hong Kong User Willing Build A 24 Port Ivr
Hi! This is Kent from Hong Kong. I'm going to purchase 2 D/120JCT and VG Professional(24 lines) to build an IVR system for my company use. I got some questions:
1) Anyone can share your success case for me located in Hong Kong?
2) Can I install 2 D/120JCT in a single system?...
3) How should I purchase the license if I want to build a 12 ports IVR system first? Can I just add 1 more D/120JCT and 12 more licenses at an existing VG IVR system?
Anyone can share with me? ^^ Thank you very much!
Please contact sales@voiceguide.com for relevant references/contacts.
Yes. The two cards will need to be connected together using a CT-Bus cable as well - so you will need to order the CT-Bus cable when ordering the two cards.
You can buy 12 ports now and 12 ports later. You should use VoiceGuide v7.
Yes.
Please let us know if you have any more questions.
