Guest Jon Leren Schøpzinsky Report post Posted 12/10/2003 11:14 PM Hello I am trying to get an IVR system up and running using a D-Link DU-128TA+ ISDN modem running CAPI using ComISDN. But everytime a call is received, Voiceguide freezes when it tries to play the welcome message (Credit Card Example) I am currently trying the Demo as i am looking into several IVR products, and it would be cool to see an actual working VoiceGuide as i think it looks like a very promising product Regards Jon Leren Schøpzinsky Tele Group Europe Share this post Link to post
SupportTeam Report post Posted 12/10/2003 11:52 PM We have tested the VoiceGuide+ComISDN with AVM's and Eicon's cards. Sounds like there is some incompatibility between ComISDN and D-Link's implementation of CAPI that's causing problems here.. Could you please send us a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong. To capture a trace to VoiceGuide's \log\ subdirectory please modify VG.INI's LogToFile entry in [TraceLog] section to be: [TraceLog] LogToFile=1 Then start VG again and a log file will be created. Share this post Link to post
Guest Jon Leren Schøpzinsky Report post Posted 12/11/2003 10:12 AM Hey Here is the log: 1211vgm.txt Share this post Link to post
SupportTeam Report post Posted 12/11/2003 10:43 AM Trace shows that the call is answered OK, and yes it looks like after the commend is issued to ComISDN to play a file then nothing happens... Have you set the A-Law/u-Law encoding setting in ComISDN correct for your local area? Incorrect setting of these were previously leading to sound quality problems on other cards - maybe this could fix things on your setup. At this stage I'd recommend contacting ComISDN regarding this issue, they may be able to indicate what could be going wrong here... 110906,45 18 callstate OFFERING 65689 0 4 110906,45 18 Dont answer yet, wait for CallerID information. 110906,48 18 Lev_CallerID [22458405,] 110906,48 18 Answer the call at 11-12-2003 11:09:06 110906,48 18 lineAnswer(65689) => 65672 110906,48 18 ring 0 110906,48 18 tapi Reply (LineEvReply) ok 65672 0 110907,77 18 callstate CONNECTED 65689,0,0 110907,77 18 WorkingModeTAPI@Connected= 110907,77 18 WorkingModeScript@Connected= 110907,77 18 Inband detection not enabled 110907,80 18 StartLoadedVgs at 11-12-2003 11:09:07 110907,80 18 [Get Client ID] Number Input 110907,80 18 [Get Client ID] Playing (PayGetId.wav) Share this post Link to post
Guest Jon Leren Schøpzinsky Report post Posted 12/11/2003 11:26 AM Hey It is setup to run using A-Law, since i am in the EU. I am going to contact ComISDN. Thank you for the help so far Regards Jon Share this post Link to post
