Guest dc103fm Report post Posted 02/28/2003 06:12 PM I have this question I want to voiceguide to play some info messages at a chosen module, I want to use multiple short wavefiles separated with the , . Now when I am hearing a certain wave file that interests me I want to press a key and use that wave as a variable to go to my next module. Is it possible to use the wave files as variables or do I have to use as many modules as wavefiles? Share this post Link to post
SupportTeam Report post Posted 03/02/2003 05:58 AM If you want to be able to detect during which Wave file was the key pressed by the caller then you will need to have each Wav file in a separate module. when you separate the filenames by "," the whole lot of files is queued to be played and there is no way of finding out which of the queued sound files was playing at the time when the key is pressed Share this post Link to post
