Setting Up Vg With Hmp
I want to buy a HP server ProLiant DL380 G7, with intention to use HMP as the option during vg installation, I have read some thread that the server must support HPET, before purchase of server, how do I know if it has HPET particularly if its not written on the box
Ok thanks, I just installed HMP (two lines)and vg7 on my pc and I saw on the vg that the two lines are ready to receive calls, I want to setup the application on my pc first before i run same setup on the server.
1. is it possible to make a test call on the same single pc, I have x-lite and 3cx on the pc, or must i get another system locally connected to the vg pc before i can make a test call
I now have x-lite on another pc on same network with the vg pc, what will be the registration parameters I will enter in the x-lite account in other to make a test call to vg
vg pc, 192.168.1.15
x-lite pc, 192.168.1.16
we just setup and installed the dl380 server for use with vg7, and we installed windows server 2008 64bit, do you have any known issue with vg working well with 64bit systems before we proceed with hmp and vg7 installation...
Ben
ok,
when i run hpetool64 on the server i got this
"HPET is hardware & BIOS supported and is enabled on this system."
I assume it means its supported, right?
Do you have any updated script for chatline service or the link available on your site for the script is the only you have. I know we can modify to suite our unique requirement, but just asking if there is any newer chatline script...
Yes.
Regarding the sample chatline scripts please contact sales@voiceguide.com with your questions and requirements.
Ok,
Now i have installed hmp, i test a call into it, I saw the exactly the screen mentioned in the online help, which shows the calls came into it, but i didnt hear anything (the demo app)
Then i installed the vg, i saw the waiting for call for 2 lines and saw the inbound script as the credit card payment.vgs ok, but when I make the call into the IP sing the same sjphone, I saw the column (in/Out) changed to IN, on the line that the call came in, ok, but I did not hear anything still. When I hangup, i saw the time and date logged.
Please why is there no voice coming out after the call is successfully made into the vg,
Is there anything else installed on this system apart from Windows and HMP and VoiceGuide?
Can you try temporarily disabling the Firewall?
If you still encounter problems please post the ktTel trace file (please .ZIP it up before posting).
Please also install WireShark and use it to capture a trace of the call. The post the .pcap trace file (.ZIPped)
Yes, its newly setup server with windows 2008, and only hmp vg7 running on it now, we just want to run ms office and mssql server on it later today.
I tried disabling the firewall and made the call, but cant hear anything yet, but the call certainly get to the vg, because I can see the "IN" lable on the in/out coulum
attached is the log requested for both wireshark and ktTel
There were not included in the previous post. Can you please try attaching these .ZIPs again.
just a quick update, for whatever reason that i dont know now, the sound icon on the server says "no audio output device", and checked device manager, also really no sound device shown. This should be the reason why i cannot hear any voice when call is made successfully to the vg7, please confirm.
I'm trying to check with the supplier of the server and also in the get a PCI sound card in the mean time
Just to update, now I can hear vg application, I had to change the default IP on the HMP to use the server IP. The server has up to 4 IPs and the HMP defaults itself to a wrong one, so I had to change.
I'm still investigating though, but i noticed that the voice doesn't speak at everytime i call the script, if i called 5 times, I wil hear the voice 2 or 3 times only (even though the script run ok at all time)... I noticed that when i called the HMP Demo app only, it does the same thing too, the voice comes out to my phone alternatively, somtimes it will speak sometime it will not speak... any idea where to look for the fault...
Can you simplify this server configuration so that this server only has one IP address, and try testing when only one IP address is set up.
